Question about BenQ FP71G+ 17" LCD Monitor
I have LCD monitor screen & windows xp as operating system.i cannot remove auto adjusting message box. it flashes on screen after every 2-3 seconds & due to this my screen will auto adjust at every 2-3 seconds. so what shoud i do 2 remove ? please help me as soon as possible..
    Master:
  • 325 Answers
May not be THE solution, but try turning your refresh rate in you video settings down to 60hz
to do this right click somewhere on the screen desktop
left click properties click settings tab click advanced click monitor tab there should be a screen refresh rate dropbox
select 60hz then apply
Posted on Mar 20, 2011
    Problem Solver:
  • 17 Answers
If your auto adjusting message box appears and you cannot choose exit button to close it, you may need to check the button on the monitor, make sure it is not in the pressed state. This has nothing to do with your Windows XP. To check the problem, you can turn your computer off and turn your mointor on, if it is still there, meaning it is a monitor hardware problem.
  • 922 Answers
The message is being created by the monitor not Windows. The only thing you can do is look for the option to disable it on the monitor's menu options. NEC-brand monitors will have something call "Onscreen Notification" which you can disable. Hopefully your BenQ will have a similar option.
Just installed a ZR24W monitor, screen blacks out after 10 minutes with a message saying 'Input signal out of range, change settings to 1920x1200-60hz'. The monitor was set to this resolution &...
You will need to adjust the refresh rate of your system.
1) Right click on the desktop and go to properties.
2) When the Display Properties window opens go to the Settings tab.
3) The go Advanced.
4) Once ni the advanced screen go to the Monitor tab.
5) Under screen refresh rate select around 60Hertz. (Make sure the box next to "Hide modes that this monitor cannot display" is ticked.
6) The click OK. And OK again to exit Display Properties.
May 26, 2011 | HP Smart Buy ZR24W LCD Monitor
In my windows xp the software window size is different. Vertical size in left and right is different.
Hi there.
What you need to do is to adjust the vertical placement of the screen "picture". This can be done directly on your monitor/LCD screen.
The method of adjustment is depending on the type of monitor/LCD screen.
Try to press buttons on the monitor an determine how to do.
regards
Oct 17, 2010 | Microsoft Windows XP Professional SP2
When I Increase the Resulotion 1027 X 768 then display a message box " Inpur not support" and move arround slowly on the screen . my Motherboad is Mercury i installed the vga but problem is same...
This means, that your operating system is not set to the recommended resolution of your monitor. Your monitor has a "fixed" resolution where the image will look best. You can change the solution in Windows XP if you right-click on a free space of your desktop, then choose "Properties". In the new window, that comes up, select the rightmost tab. There you can use the slider to adjust your resolution. Just try some different resolutions until the message disappears.If you use Windows Vista or Windows 7 you can access the resolution window by right-clicking on your desktop and selecting "Screen Resolution".
Jul 02, 2010 | AOC 19LVWK LCD Monitor
A flashing message saying auto adjustment. how do i get rid of it please
on your Monitor the should be an auto-adjust button. Press it. or try and change the screen resolution.
Jun 13, 2010 | Microsoft Windows Vista Home Premium...
Screen keeps going into auto adjusment flashes every 30 seconds
Install the cd that came along
Well try to go in menu after 20 min (warming up) after powering ur monitor & try to adjust
or
U may need to press a button on ur monitor to disable the message...
for e.g viewsonic screen is button num 2
Feb 06, 2010 | HP w1907 LCD Monitor
I bought this acer z193w monitor and everytime I fire it up I get a message saying . My computer runs on windows xp pro.as I haven't got the user's manual, I would like to know why it doen't work, and if...
1) Monitors do not care what operating system you are running, otherwise I wll not br able to fix the monitors if I need to have all the operating system installed in my PC or MAC. You must have correct driver for the video card installed in the your PC.
2) What message are you getting on the screen?
3) User manual: http://retrevo.com/support/Acer-X193W-Monitors-manual/id/7197ag005/t/2/
Jan 21, 2010 | Acer X193W LCD Monitor
I am looking for a monitor driver for Windows Vista for LT1919
Windows XP and Vista should "auto-detect" the capabilities of this LCD screen.
If not, access http://WindowsUpdate.Microsoft.com
and scan for updates.
When the scan is done, look for "optional hardware" updates.
If Microsoft has a driver, it will be offered for download.
Nov 20, 2009 | Mag Innovision Computers & Internet
AUTO ADJUSTMENT LOCKED BOX FLASHES ON THE SCREEN ALL THE TIME.
Depends of what seems to be a problem.
If you want to get rid of that message box, appearing by itself, then probably you need to take front panel PCB with buttons and replace "Auto" one, 'cause it's stuck.
If you want to unlock an Auto Adjustment and other functions in your monitor, then press and hold 'Enter' button for 5 seconds.
Sep 14, 2009 | Samsung SyncMaster 17" LCD Monitor
SyncMaster 2253 BW Samsung
Hi...there,
Have try open your monitor on screen display (OSD) and used the auto adjust settings.
Oct 13, 2008 | Samsung SyncMaster 2253BW LCD Monitor
BenQ FP71G+ 17" LCD Monitor Logo
275 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
