We have a Tecnolec TFL 1206 w-u, it has started making a clanking noise when it spinns
    Brigadier General:
  • 6,277 Answers
(try this!)
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Mar 20, 2011
I have a 2012 cbr 250 and when starting it makes a loud sound like meatal on metal. It also makes that sound when idle but when I rev the engine it doesnt make that noise. What could be wrong
It may be piston slap if your idle speed is particularly low, but that's a bit strange for a new-ish bike. Hard to diagnose online - why not drop in to your dealer for a quick appraisal by one of the mechanics?
Dec 03, 2013 | 1998 Honda CBR 250 RR
My 97 bmw is hard to start and when it does it makes a loud clanking noise
To be honest I believe it could be your starter and/or battery's. If its makes a clanking noise from what I know it should be the starter.
Oct 05, 2013 | 1997 BMW 328
Clanking noise coming from Allison Transmission on a 2001 Chrevrolet Silverado 8.1 Liter engine
this does sound like theres a loose line tapping the engine/frame,during warm up the engine idles faster which could make it vibrate faster causing the the clanking or tapping noise,if this has started after trans fluid change,then check the lines running from the trani to radiator sometimes the service person might bang into something causing plastic clips that hold the lines to break,try getting under it and have someone start the truck and listen to see where it's coming from also hold the lines & see if the noise stops,the service guy could have unbolted something & never put the bolt back causing the clank ex.line may have a clip holding it thats bolted to the trani pan ?good luck
Dec 29, 2012 | 2001 Chevrolet Silverado 2500HD
Spinn cycle made LOTS of noise won't spinn any longer
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt">Hi,<br />When my washer did that, I found that the shocks that hold the tub were bad...<br /><br />Check out this tip I wrote about the noise and vibration that front load washers can make..<br /><br />Washer Problems Washer noise when spinning<br /><a href="http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when" target="_blank">http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when</a><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span><span style="FONT-FAMILY: Arial; COLOR: black; FONT-SIZE: 10.5pt"></span><br />
Aug 25, 2010 | Frigidaire ATF6000ES Front Load Washer
Driver side front....here a clanking noise especially when i go over bumps and when in reverse...just did pads and roters about 2 weeks ago...any ideas?
I would start with sway bar links because they do make clanking noises when worn. plus they are usually cheaper than a strut or a cv shaft...
Oct 26, 2009 | 2002 Mercury Cougar
91 buick regal 3.8L is making a loud clank noise in belt area
It sound to me like you have a bad belt tentioner check to see if it's real easy to move by hand if so change it problem solved .Hope this helps you out!!!
Jun 03, 2009 | 1991 Buick Regal
Clanking noise under front drivers side - small bumps and turns...
CV joints yes look at the rubber boots for damage. You can get a replacement boot but if you do remove all the old grease to remove any dirt that is cousing your problem.
Apr 30, 2009 | 1999 Ford Explorer
Loud clanking noise in dishwasher
Most likely the motor as food caught in the sump would not make a noise you described.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Dishwashers
Mah3000 aww making extremely loud, clanking, grinding during spin
Gotta admit tonytools albeit not cheap has the best easiest tool to do that rough difficult repair.
Jan 01, 2009 | Maytag Neptune Washer
Washing Machines Logo
134 people viewed this question
Top Washing Machines Experts
