Question about Vizio VO47L 47 in. LCD TV
I have a VO47L. I have sound but no picture..Can u helpme?
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 20, 2011
  • 11,361 Answers
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Mar 21, 2011
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: vizio vo47L 47" LCD. No
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
More specifically on #1 and #2 - capacitors either bulging, leaking, or exploded.
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!@#$
Posted on May 27, 2011
Vizio E472VL has sound but no picture
TRY THIS LINK .... http://www.ehow.com/list_7461529_reasons-power-but-picture-sound.html
Oct 17, 2013 | Vizio VO47L 47 in. LCD TV
Fuse location's on vizio VO47L FHDTV10A
the inverter has failed which is a very commom problem. You can get the replacement inverter from www.tvcircuitboards.com
Jun 03, 2012 | Vizio VO47L 47 in. LCD TV
I only have sound on my vizio and no picture
Backlight inverter board might need replacement.
May 23, 2012 | Vizio VO47L 47 in. LCD TV
47" vizio has sound but
Clean the LVDS cable connectors to get rid of the oxidation. This may do the trick.
Mar 01, 2011 | Vizio VO47L 47 in. LCD TV
Vizio vo47L 47" LCD. No
2. Power Supply
3. Backlight
Thanks!@#$
Feb 04, 2011 | Vizio VO47L 47 in. LCD TV
I did not find Audio out for installation of additional sound system (external)
The VO47LF has two output options: a SPDIF Digital Optical and a tradition stereo audio out port.
The following site has instructions and pictures on locating the two options.
http://www.televisioninfo.com/content/Vizio-VO47L-LCD-HDTV-Review-598/Connectivity.htm
Thanks
Dustin
Jan 12, 2011 | Vizio VO47L 47 in. LCD TV
It turns on no sound or picture,not even a rainy signal on the screen!
Are you sure that this monitor is properly grounded?
-a.
Aug 14, 2010 | Vizio VO47L 47 in. LCD TV
Sound on tv but no picture.
Replaced the LCD inverter it dead.Replaced that board u will get picture back.It usally a long board..
Jan 19, 2010 | Vizio VO47L 47 in. LCD TV
Vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
May 18, 2009 | Vizio VO47L 47 in. LCD TV
Vizio VO47L 47 in. LCD TV Logo
942 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
