My daughter bought me a 5.6" digital Photo Frame. Item #N5-105 and I don't have the adaptor; input 100-240V, Output 5V. Could I get another and how much would it cost?
  • 604 Answers
On the back of the frame, it shoud say what voltage is required, or you could take the unit to radio shack, they have many ways to power various devices.
Posted on Mar 20, 2011
Testimonial: "thought I was going to have to pay, didn't think I'd get an answer. Appreciate the simple solution"
Looking for a new plug for a digital photo frame
All you need is an adapter with the following Specifications Output( DC V/A ) :5V 2A Max Power Output(W) :10W Input : 100 AC - 240 AC (50/60HZ, for example this one, copy and paste the whole link into your browser http://www.ebay.co.uk/itm/like/331238268334?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&chn=ps&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0-L&ff12=67&ff13=80&ff14=108&ff19=0
Dec 03, 2014 | PANDIGITAL 7" Digital Photo Frame With...
What kind of fuse does my mio moovr503t use in its charging unit
The fuse is to be found in the power adaptor
Fuse type : 1.0A / 250v
input: 10-30V/ DC , Max.1A
output: 5V / DC -- 1A
Len..
Oct 14, 2014 | Mio Moov R503T 5" GPS Receiver
Digital photo frame not switching on. Worked yesterday but not today. Would it be the adaptor or the frame itself, how can I find out?
If the adapter works with another device then the frame is bad. If the frame works with another power source then the adapter is bad.You can also measure the voltage between the contacts on the output end of the adapter to see whether you're getting any juice out of it when it's plugged in.
Apr 17, 2012 | Cameras
Where can i buy a switching adapter for our philips 10 in. digital frame? model DSA 12 PFA-05 FUS 050200 input 100-240 V output +5V
if you mean a switching adapter for your phillips 10 in. radio shack has an adapter set with multiple plugs and voltage and amps here is a link to one on amazon http://www.amazon.com/5V-1-2A-Universal-Power-Supply/dp/B001KU44HE that looking up your model should work. also walmart and best buy carry adapters with multiple plugs as well hope this helps let me know
Mar 14, 2011 | Philips Cameras
Hi...I have a problem with my HP Photosmart C7280...can you help ? the error message "Photo tray problem" keeps coming up, telling me to "lift the output tray, push the photo tray all the...
Photo tray problem
' Lift the output tray up and verify that the photo tray
' is pushed in until it stops, then lower output all the
' way down. Press OK button on the printer to
'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper tray and photo tray
3. Remove output duplexer (on back of printer)
4. Open input sheet feeder (on top of printer)
5. Open cartridge access door. (Basically lift up control panel and scanner section of the printer)
6. Turn on printer (Power button on now raised control panel)
7. Printer may display message "Performing printer alignment - Do not interrupt"
8. Wait for a few minutes until printer stops making all setup noises.
9. Close cartridge access door, close input sheet feeder, replace output duplexer, insert paper trays
10. Do a test print. All should be fine.
Mar 11, 2011 | Office Equipment & Supplies
My digital photo frame screen is black. I have checked the AC adaptor on another frame that I bought at the same time and it is transmitting current. It is a smartparts frame SP1000EF, Model no....
It tends to be the problem of internal circuit board in digital photo frame .If the adaptor is working fine with other digital photo frame then definitely it is problem of internal connection . So better replace the unit if it is under warranty . Else one more try is just tap on the sides of photoframe when you power on the unit .
Hope this helps .
Apr 22, 2010 | Smart Parts Digital Picture Frame
I misplaced the power adaptor, and found one the fits in, but don't know if has the coorect powers output.. the power adaptor I have for this I rocks IR 4300 is an eblue mainstay with an output of 5.0...
as per irocks page this is the power info for your device:
Power : Self Power : 5V
Adapter : (input)100~240 VAC , (output)5 VDC
you probably may want to check with someone at radioshack if the adapter you found matches above specs
info on your device can be found here
Dec 26, 2009 | i-rocks IR-4300 4-Port USB Hub
Hp Pavilion getting no power after relocating pc.
the Power transformer has diferent outputs, +5V,-5V,3V,12V and so on.., but has a standby output a low power 5v to power button function.
Your PC have Power supply Defective,
so your must find a usual spare power supply on the market, compatibilty as 115V input and more of 350W power, to have stabilty.
Nov 29, 2009 | HP Pavilion a1519h (EX271AA) PC Desktop
NEED SPECS FOR POWER SUPPLY OF DDV-1100X
have the adaptor you require....model AD2910-0207 INPUT :- 100-240VAC, 50/60HZ 0.3A OUTPUT:- 5V -2A....AC ADAPTOR hope this helps....hope you can help me i have no software (drivers) for this camera. can you assist. pete
Jan 17, 2009 | Cameras
29 people viewed this question
 Grubhead
Grubhead
