Question about HP Officejet J5780 All-In-One InkJet Printer
We are trying to print on a card stock ,110 lb. , 8.5x11 Paper keeps jamming. Will this printer work with card stock?
    Sergeant:
    Champion:
  • 234 Answers
It will only work if the printer supports feed through from the back. If the paper has to go in the same side of the printer that it comes out it will jam.
Posted on Mar 20, 2011
Flaherty@nbhealth.org I am trying to print on 110 lb cardstock and It keeps geeting stuck. I can't seem to find where I should change the paper type. Please advise.
Use the hand feed tray on the right side. When you put paper in this tray it usually will ask you to set the paper type. 110 lb. card stock is EXTREMELY difficult to copy onto. It might be better to bring this particular job to a copy center. This type of stock will put serious wear on your machines drum. Drums cost big money. Good luck.
Jul 15, 2011 | Minolta bizhub 200 Copier
I wish to use my HP Photosmart C8180 to print heavy weight cardstock... is there a setting that I can select to do this?
Step Three: Check the paper type Verify that only recommended paper is being used for printing. The recommended paper types and weights for most HP printers include:
  • Plain paper, 20 to 24 lb (75 to 90 gsm)
  • Legal size paper, 20 to 24 lb (75 to 90 gsm)
  • Card stock, up to a maximum of 110 lb (200 gsm)
  • Envelopes, 20 to 24 lb (75 to 90 gsm)
  • Photo paper, 145 lb (236 gsm)
NOTE: Supported paper weights and types vary by product. Check the Specifications sheet for your product for more information.
If you use card stock up to a maximum of 110lb then there should be no special mode to enter to print on this type of paper. Photo paper weighs in at 145 lb maximum which is heavier and can be printed on without selecting any special 'mode.'
Good luck on printing on heavy card stock.
Jan 21, 2011 | HP Photosmart C8180 InkJet Printer
We have an Oki 5200c and are printing color postcards on 110 lb card stock. The properties for the printer are set to heavy paper. We have tried using the regular drawer and almost immediately it stops...
Wrong size paper or paper setting in the software settings. Or the dreaded plastic gear/roller cam has warn down. You'll notice some parts are plastic designed to ware out.
Apr 17, 2017 | OKI C5200n Laser Printer
The printer wont print on heavy paper is there a special setting i need to do
Paper types you can use:
Plain paper - 20 to 24 lb / 75 to 90 gsm
Photo paper - 6.5 to 12 mils (up to 290 gsm)
Card stock - 110 lb / 200 gsm, max
Envelopes - 20 to 24 lb / 75 to 90 gsm
Transparencies - inkjet variety with white stripe
Labels - all commercially available inkjet varieties on 8.5 x 11-in. or A4 sheets
There is no setting to allow printing of thicker paper stock.
For more information on your printer, please see the ESP 7250 All-in-One Printer Knowledge Center:
http://wwwcaen.kodak.com/global/en/service/products/ekn036791.jhtml?pq-path=2300285
Dec 20, 2010 | Kodak ESP 7250 All-in-One InkJet Printer
I AM TRYING TO PRINT HEAVY STOCK CHRISTMAS CARDS -
If its heavier than 60 to 105 gsm (16 to 28 lb), then your printer can not take that type.
HP Specifications
Unless there is a manual feed on the back, the paper won't be able to bend well inside of the printer, hence the jam.
Nov 29, 2009 | HP Office Equipment & Supplies
Information on how to use rear feed
1. Prepare your doc/file for printing.
2. Insert card stock with narrow side of stock in slot in back of printer until it hits rollers and stops. Don't force in any card stock thicker than max. rated.
3. Change printer setup to feed from rear.
4. Print.
Depending on what software you print from, you may need to change this each time you print if you intend to keep printing from that "tray."
Mar 09, 2009 | HP Deskjet 1120c InkJet Printer
5610 will not print on color paper
I'm wondering if the paper weight and/or size is exceeding the printer's specifications. The paper tray specs on HP's site says it will take up to 110 lb card stock, but as far as paper stock, it can take only up to 24 lbs. Have a look at the printer's product specifications page and see if this could be the issue:
Product Specifications page
Sep 28, 2008 | HP Officejet 5610 All-In-One InkJet...
Paper keeps jamming
To print card stock you must us the manual slot in the front of the printer and feed one at a time. Also open the back flap door so the card stock can exit out the back instead of trying to bend around for the try. That will give you the staight paper path that your thick stock needs.
Jul 08, 2008 | Brother HL 1440 Laser Printer
Printing jammed on thicker paper
See the manual. It looks as if 120g/m2 is the heaviest paper it can use:
"Set Type to correspond to the paper loaded in the tray from
which you want to print. This will let you get the best quality
printout. If not, print quality may not be acheived as you want.
Thin: Less than 19 lb (70 g/m2) thin paper.
Thick: 24 lb to 32 lb (90~120 g/m2) thick paper.
Cotton: 20 lb to 24 lb (75~90 g/m2) cotton paper such as Gilbert
25 % and Gilbert 100 %.
Plain Paper: Normal plain paper. Select this type if your printer is
monochrome and printing on the 16 lb (60 g/m2) cotton paper.
Recycled: 20 lb to 24 lb (75~90 g/m2) recycled paper.
Color Paper: 20 lb to 24 lb (75~90 g/m2) color-backgrounded
paper."
Nov 22, 2007 | Samsung CLP 300 Laser Printer
HP Officejet J5780 All-In-One InkJet Printer Logo
214 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
