Question about Whirlpool GU2700XTSB / GU2700XTSQ / GU2700XTST Built-in Dishwasher
Water not draining from basin Whirlpool gold GU2700XTSQ
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Posted on Mar 20, 2011
Whirlpool gu2700 dishwasher
Water is not heating. Could be bad heater, bad control board, or poor water circulation due to clogged, stuck, or bad pump.
Jul 27, 2014 | Whirlpool GU2700XTSB / GU2700XTSQ /...
Dishwasher whirlpool model number du1030xtkq2 will not finish cycle
Check the float to be sure it is unstuck. Sometimes this item [on the basin of the DW, looks like a mushroom. Measures the water level in the bottom of DW] is tricked in thinking it has water, or the water is not turned on, or the basin is full. Gently pull up on it and push down on it. Does it move freely?
Try to cycle again.
Nov 24, 2013 | Whirlpool Dishwashers
10 yr old quiet plus series wont drain
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Oct 01, 2010 | Whirlpool GU2700XTSB / GU2700XTSQ /...
I have a Whirlpool Gold dehumidifier with the hose set up for direct water release into a sink drain. I assumed once you hooked up the manufacturer hose provided it would be a direct drain process and...
I have a similar Whirlpool dehumidifier and a similar problem. Have you tried setting it to continuous mode? My understanding was that it would only divert the drainage to a side hose when in the continuous mode.
Jul 20, 2010 | Dehumidifiers
All the water won't drain out
check at the end of drain hose connected to the garbage disposal. take the hose clamp off and you may find food grease etc stopping up the drain hole. or you water pump could be going out.
May 09, 2010 | Whirlpool GU2700XTSB / GU2700XTSQ /...
The washer shows F2 and won't complete the cycle
- Clean out the drain pump catchment. Remove the bottom front panel and there is a white plastic catch basin with a large facing forward lid (peanut butter container sized). Remove it and Voila. Fairly easy fix-it job.
- Pull the suction boot off the drain pump, clean out any ****.
- Blow through the drain hose starting from the connection at the pump.
- If all else checks out, replace the pump.
Dec 27, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Aug 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold dishwasher
Either:
  1. not enough water gets into the dishwasher. check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
Good luck,
Vlad
First Choice Appliance
Mar 21, 2009 | Whirlpool GU2700XTSB / GU2700XTSQ /...
Whirlpool GU2700XTSB / GU2700XTSQ / GU2700XTST Built-in Dishwasher Logo
112 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
