I have an Iogear CS 102U KVM switch. I have hooked it up to a MAC mini and an XP PC. I am getting video switching with no problem but the keyboard and mouse are not working on either machine. I have tested the USB ports on the computers and they are ok. Is there a way to test the keyboard and mouse connections to see if they are bad? I have not connected anything other than the video cables--ie not the USB cables with the video cables. Thanks for any help! tlepac@gmail.com
Sphynkter
  • 221 Answers
SOURCE: 2-port KVM switch mouse & keyboard connected to wrong display
I have installed several of these KVM switches before... that's not normal. It sounds like there's a manufacturer's defect which is causing the video to link up with the wrong keyboard/mouse cables. If you just bought it, I'd recommend returning it and getting a replacement.
Posted on May 16, 2009
SOURCE: COM Port issue with 4600 and 4800
You tell Pip to put back on the K/B wedge and make programers - u know program it to work [8^) lol
sorry for the false positive
Posted on Sep 17, 2009
  • 5603 Answers
SOURCE: repeated IOGear KVM switch failures
As a wild guess, it sounds like a static discharge MIGHT be affecting the switcher causing it to crash.
Try increasing your humidity to 40% and grounding yourself before touching the keyboard... This is the season for these static electricity problems... get nipped all the time and you MAY not even feel it to be enough to zap the switch.
Posted on Jan 11, 2010
Testimonial: "Great idea, Fredy. I am having static problems all the time in my office. I will make a ground pad on my desk top. Thanks"
Keynan
  • 977 Answers
SOURCE: I have at Mini KVM
Hi there!
I can't tell you for sure, but 95% of the KVMs use the Scroll Lock button to switch between the different machines.
You should DOUBLE-CLICK on Scroll-Lock, then you have 2 choices:
1) Click the number of the desired machine (for ex. the "1" or "3" buttons).
2) Wait until it'll switch to the desired machine, then press the Scroll-Lock button ONCE again.
Old KVMs use the Control (CTRL) button instead. Try DOUBLE-CLICKING it, then use the numbers or the arrow keys.
Best regaeds and good luck,
Pelu.
Posted on Dec 27, 2010
  • 5 Answers
SOURCE: Hi, I need to connect
I'm not one hundred percent sure on this, but it does look like you need a separate phone line since VOIP revolves around using your internet as a gateway for making phone calls. And since majority of VOIP uses ethernet connections, or wireless, there is no phone line to use.
Posted on Mar 01, 2011
New IOGear GCS632U KVM inop
First, disconnect the KVM switch from the computer(s). Disconnect also the keyboard and mouse from the KVM switch, including speakers (if there is). Leave the KVM disconnected for 5 minutes.
Before you reconnect the KVM switch, make sure that the computers are turned off. Re-connect the KVM switch to the computers, and then reconnect the keyboard and mouse.
Turn on the first computer, followed by the second one. If you are still not getting any light indicator, then the KVM switch is dead.
You may contact IOGEAR through 866-946-4327.
Thank you for using FixYa!
Jun 08, 2010 | IOGear GCS632U 2-port KVM Switch
How in the Hell is one supposed to understand the instructions for the IOGear GCS932UB. I cannot get the unit to detect my powered usb hub. No information is displayed when you try any function so I never...
If you trying to use the USB hub through the mouse port of the KVM make sure the mouse emulation has been turned off. This can be done by tapping Scroll Lock + Scroll Lock + m + Enter. This turns the mouse emulation off and causes that port to act like a direct USB connection to the computer. Instructions for this can be found in the user manual on page 14.
http://www.iogear.com/support/manual/GCS932UB_Manual.pdf
Apr 24, 2010 | IOGear Computers & Internet
Repeated IOGear KVM switch failures
Jan 11, 2010 | IOGear MiniView GCS62 2-port KVM Switch
IOGear (GCS632U) 2-port KVM Switch problem. All functions well it seems after connecting for first time Mac Mini and XP Windows Dell PC except when switching to Mac I get a blank dark screen. Another side...
The IOGEAR GCS632U is designed to work with VGA computers and monitors. Using the Mini DVI to VGA adapter is not guaranteed to work with this KVM switch.
The Mini DVI to VGA adapter can only convert the port, but it does not have an ability to convert the signal from digital to analog when it's connected to the KVM switch.
What you need to have is a DVI to VGA SIGNAL converter. Unfortunately, I don't have a model number handy, so I would suggest to contact IOGEAR, because I'm sure that they already have a work around with this issue.
Thank you and good luck!
Oct 11, 2009 | IOGear GCS632U 2-port KVM Switch
Hooked up a iogear cgs62 wont allow me to log onto
II had one of those with no problem at all other than many KVM's dont allow you to use some of the many extra keys you get on some of the better keyboards. If thats what you mean by connect to internet then its a common drawback of cheaper end KVM's even some of the better ones dont support fancy keyboard buttons.
Aug 09, 2009 | IOGear MiniView GCS62 2-port KVM Switch
GCS62 - both computers must be on for this thing to work?
It seems that you KVM switch is not working properly. computers connected to a KVM switch are not dependent to each other. you should be able to work on any of your computers while the others were turned off.
Jun 06, 2009 | IOGear MiniView GCS62 2-port KVM Switch
KVM will only switch one way
Please make sure that the keyboard is hooked up on the KB port of the KVM. check underneath the GCS632U for the correct console port. you will see a keyboard and mouse icon. Make sure that the keyboard is connected to the keyboard port. tap scroll lock key twice to switch between computers.
May 13, 2009 | IOGear GCS632U 2-port KVM Switch
Wobbly screen on mac laptop
are you using a Mac Mini-DVI to DVI adapter or any adapters? This is a VGA video output type of KVM switch so probably the problem is with the adapters involved to it.
Nov 19, 2008 | IOGear MiniView GCS62 2-port KVM Switch
KVM troubles
Belkin.com....Switching software update.
Dec 04, 2007 | IOGear GCS632U 2-port KVM Switch
Mac and Vista
Operating System doesn't deal anything on your problem. The problem depends on the brand of you computers or the type of keyboard you are using.
The GCS632U is designed to work with standard USB keyboard and mouse only. And wireless and gaming keyboards and mice are not guaranteed to work correctly with this KVM switch. If any one of you is using the new Mac Aluminum keyboard, this keyboard will not work with the older version of the GCS632U. But IOGEAR releases a new batch of GCS632U that would work with the Apple Aluminum keyboard.
If you have an Apple Aluminum keyboard that does not work with the GCS632U, you may contact the IOGEAR Tech support and they will process a Return Merchandize Authorization (RMA) if your device is still under the warranty period.
To resolve your keyboard issue, try to power cycle the KVM switch by disconnecting it from the computers, disconnect also the keyboard and mouse from the KVM switch. Leave it disconnected for two minutes. After two minutes, reconnect everything and reboot the computers.
Oct 20, 2007 | IOGear GCS632U 2-port KVM Switch
Computers & Internet Logo
35 people viewed this question
Alun Cox
David Payne
David Payne
