Question about Acer Computers & Internet
My @ is set on number 2 how do i change it - Acer Computers & Internet
    Master:
  • 325 Answers
Start control panel classic view (left blue pain if there) regional and language options Change English United states to English United kingdom everywhere available apply exit
Posted on Mar 20, 2011
Need to reset speed dial numbers but cannot get the cursor to appear.
Dear
Storing One Touch Dial Numbers 1Press Menu, 2, 3, 1. 2Press the One Touch key where you want to store the number. 3Enter a number (up to 20 digits), and then press Set. 4Enter a name (or leave it blank), and then press Set. 5Press Stop/Exit. Storing Speed Dial Numbers 1Press Menu, 2, 3, 2. 2Enter a three-digit (a two-digit for FAX-4100e) Speed Dial number, and then press Set. 3Enter a number (up to 20 digits), and then press Set. 4Enter a name (or leave it blank), and then press Set. 5Press Stop/Exit.
Thanks.
Feb 03, 2015 | Brother IntelliFax-4100e Fax
I have a Skytech 3301 for a propane stove with some thermostat problems.
Great question! It sounds to me like the Skytech's swing temp setting may be out of whack.
Here is a quick link to the product page with a link to the owner's manual at the bottom if you need: Skytech 3301 Fireplace Remote.
Below is an excerpt on how to check and modify the swing temp settings for the Skytech 3301. (I apologize if the copy/paste formats poorly).
The Thermo Mode on the transmitter operates the appliance whenever the ROOM TEMPERATURE varies a
certain number of degrees from the SET TEMPERATURE. This variation is called the "SWING" or
TEMPERATURE DIFFERENTIAL. The normal operating cycle of an appliance may be 2-4 times per hour depending on how well the room or
home is insulated from the cold or drafts. A smaller "swing number" increases the number of cycles so the room temperature is more
constant. A larger "swing number" decreases the number of cycles, which saves energy, in most cases. The factory setting for the "swing
number" is 2. This represents a temperature variation of +/- 2
0
F (1
0
C) between SET temperature and ROOM temperature, which determines
when the fireplace will be activated. The "SWING" number values are:
1=+ 1
0
F (.5
0
C), 2= + 2
0
F (1
0
C) and 3 = + 3
0
F (1.6
0
C).
SETTING THE TEMPERATURE SWING (TEMPERATURE DIFFERENTIAL)
1. To change the temperature "SWING" setting (1-3), press the TIMER/TIME and DOWN buttons
simultaneously to display the current "SWING" setting in the SET TEMP frame. The letter "S" will
display in the ROOM TEMP frame on the LCD screen.
2. Press the UP or DOWN button to change the temperature differential or "SWING" (1-3). See above
for 1-3 "SWING" temperature valves.
3. To store the "swing number press the SET button or allow 15 seconds to lapse, and the new "swing
number' will be automatically programmed.
MANUAL CHECK OF " SWING" OR TEMPERATURE DIFFERENTIAL
The operation of the factory set "THERMO SWING" can be checked by adjusting the SET TEMP 2
0
F above or below the room temperature.
This will cause the system to turn ON or OFF. Normally the system will only respond to temperature changes every two minutes. Manually
changing the SET temperature will activate the system in less than 10 seconds. IF the "SWING" is changed, then a new room temperature
differential will respond. Factory setting of "SWING" temperature is 2
0
F.
Jan 17, 2013 | Skytech 3301 Thermostatic Gas Fireplace &...
I need to set up a number on speed dial and delete one.. i have a brother intellifax 4750e
1 Press Menu, 2, 3, 2.
2 Enter a three-digit Speed Dial number, and then press Set.
3 Enter a number (up to 20 digits), and then press Set.
4 Enter a name (or leave it blank), and then press Set.
5 Press Stop/Exit.
Changing One Touch and Speed Dial Numbers
If you try to store a One Touch or Speed Dial number in a location where a
number is already stored, the LCD shows the current name stored at that
location, then prompts you to either
1 Press 1 to change the number, or press 2 to exit without changing it.
2 Enter a new number and then press Set.
If you want to erase the number, press Clear when the cursor is to the left of the
digits.
If you want to change a digit, use left arrow or right arrow to position the cursor under the digit
you want to change, then type over it.
3 Follow the directions beginning at Step 4 for Storing One Touch Numbers or
Storing Speed Dial Numbers.
Feb 28, 2011 | Office Equipment & Supplies
Have bought a Technika DAB 109 CRF radio and no instructions. 1. how do I tune it and SAVE to presets 2. How do I set the alarm? Thank you
To set alarm mode :- press Alarm 1 or 2 briefly to swtich between choices of Alarm On-Beep / DAB / FM / Off, keep pressing this alarm button until you get to the mode you want then stop pressing and leave to settle.
To set time: Press and HOLD Alarm 1 or 2 to change time. Minutes will flash first, use dial to change numbers, when you've got to the number you want press jog/select to change hour, use dial to change hour number. If you just leave it alone once you've reached the hour you want it will set where you left it, but...
If you want to specify preset channel/volume/beep tone etc keep pressing jog/preset after setting hour and use dial to set your preferences.
Feb 20, 2011 | Audio Players & Recorders
IntelliFax-4100e
go into menu, arrow over until you see 2. Fax hit set, then arrow until you see 1. one-touch speed dial, then hit set. touch the one-touch button you want to change, then the number 1 to change it, it will display the number, hit clear to delete it then dial the new number hit set and you're done.
Feb 11, 2010 | Brother IntelliFax-4100e Fax
HOW DO I CHANGE A SPEED DIAL NUMBER
1 Open panel cover 2 Press DATA REGISTRATION 3 Press V to display 2. TEL REGISTRATION 4 Press SET twice 5 Press ^ or v to find the number you want to change 6 Press SET twice 7 Enter new fax number 8 Press SET twice 9 If you don't want to change the name then enter SET once more. Otherwise enter the changed name using the number pad as if it were a mobile phone (2 = A, B, C etc) 10 To continue press DATA REGISTRATION 11 Repeat steps above for other numbers 12 To end press STOP
Feb 09, 2010 | Canon FAX-L350 Plain Paper Laser
Need to change the pickup from one ring to picking up on the 5th
This should do it:
Press the {Function} {6} then enter
the access code {2} {2} {2} {2}.
Then press {6} {1} and the {Yes} key
press the 'next' (right arrow) key until it displays "set number of rings" . Press "yes" (the current setting is displayed). Press "no" to change. Enter the desired number, then press "yes" to set. Press "function" to exit.
Please rate me :)
Mar 14, 2009 | Ricoh 2050L Laser Fax
Need help changing the speed dial ID numbers
In order to change #01 to #21 its best just to program the number into #21 slot and then clear the memory for #1.
Start by trying to store a number at a location already used Press Menu/Set, 2 (Fax), 3 (Set Quick-Dial), 2 (Speed-Dial).
Use the dial pad to select the three-digit location (001 – 200) in which you want to erase the number and press Menu/Set.
The screen displays the name or number currently stored there, then prompts you to either 1. CHANGE or 2. EXIT.
Press the Stop/Exit key when the cursor is to the left of the digits. Everything above and to the right of the cursor is deleted.
Hit he menu/set key.
This should save the speed dial number as a blank.
Apr 29, 2008 | Brother IntelliFax-2820 Laser Fax
Panafax UF560 - how to set so confirmation page is automatic ?
Function 7 4 set.
07 (Header Print)
Setting number 1 (Inside copy area) 2 (outside) 3 (none)
Set.
You can also set the header format with Parameter 08(Header Format) 1 is for your Logo and fax number. 2 is for From: to:
Feb 01, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Computers & Internet Logo
24 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
