Question about Minolta DiALTA Di350 Laser Printer
How to reset the massage(change imaging unit) for minolta copier di 350
  • Minolta Master
  • 6,696 Answers
Replace the Image unit that will Do it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Feb 22, 2015
  • 12 Answers
SOURCE: Reseting counter after installing new image transfer roller unit
You need to go into tech rep mode to reset.
press: stop 0 0 stop 0 1, then 0 0 0 0 0 0 0 0, press enter, then press counter on the left, select life, then highlight image trans roller and press the C button, repeat for paper dust remover and exit tech rep mode
Posted on Apr 06, 2009
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Minolta Di 3010 Error code C0910
Sorry it took so long but I found it.
C0910 indicates that the 2nd drawer on your copier isn't lifting. Open the drawer and see if there is any jammed paper in there.
Posted on Sep 06, 2008
taran_2005
  • 10515 Answers
SOURCE: MInolta Di 183
Abnormally high toner density detected Black ATDC (auto toner density control circuit)
Replace black IU, check toner motors, make sure toner is loose not clumpy. Change dev reset toner level.
Thanks.
Posted on Mar 25, 2009
mr_kairo
SOURCE: Copier proplem
1. Reset the malfunction (i.e., turn OFF and ON the Power Switch).
or 2. If the same malfunction is still detected, check the EDH harness and, if it is okay,
change PWB-IB.
Posted on Jul 15, 2009
How to enter service mode
Code relates to:-
Abnormally low toner density detected black TCR sensor.
Why did you take unit out ????
Looks like you need a new IU
Dec 01, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Di 350 running continously without screen displaying configuration, what is the problem?
Check the toner cartridge and check the imaging unit life.The IU life is 40.000 copies,after 40.000 need to change or refill.
Apr 16, 2013 | Minolta DiALTA Di350 Laser Printer
Reset image unit (Magenta) Konica Minolta Bizhub C352
Change the chip or enter in service mode and change the imaging unit life duration to long life.The copier displayed continuosly Please change the image unit,press OK and ignore.
Feb 13, 2013 | Konica Minolta bizhub Office Equipment &...
Minolta Di 350 Error code C2557
Replace the image unit. open the right side cover pull out he old image unit and install the new one
Apr 11, 2012 | Minolta Di3010 Copier
Minolta bizhub 164 black and white, change drum
Remove the imaging unit from the copier. Unscrew the sides. Remove the old drum. Replace with the new one. Clean the blade and everything of imaging unit including the waste or recycle part.
Jan 23, 2012 | Minolta bizhub 350 Black and White Copier
Minolta di183 me aparece cof 32 que hago
Change the image unit or change the ATDC value 153 to164.
May 25, 2010 | Minolta DI-2010F Copier
How to reset a minolta Di 251 after replaceing Imanging unit
should when you replace the image unit with a new one, then the new one is not new
Jan 08, 2010 | Minolta Office Equipment & Supplies
C350 bizhub image unit counter won't reset after changing
using a post:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
2. Insert a suitable object into the hole to actuate the reset switch .
3. The code should clear and a message to close the front door should appear.
So all settings are RESET.
thanks for krishmaqvan
Dec 29, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 350 doesn't print at night.
Check the driver, you should have availability.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Aug 10, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Jan 17, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Minolta DiALTA Di350 Laser Printer Logo
207 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
