Question about Ulead Videostudio 8 for PC
Ive installed my driver for the easycap and the video editing software but when i connect from my vcr output to my easycap i cant capture it says no input. i cant even get a picture on my pc just black and grey lines. any ideas?
    Master:
  • 344 Answers
Make sure you are using the correct channel on your capture device and/or on your VCR.. Once upon a time VCR's used to only work on channel 3 or 4. There should be a toggle switch in the back of your VCR that will say Ch.3 ' Ch.4. Then check the software on your capture device also. One more thing. Some tapes have a copy protection on them which can do a number of things to trip up what you are doing. If you are sure everything is correct, double back and recheck. Then look into a decoder/unscrambler for VHS. Should be a simple Co-Axile pass-through with a frequency modulating knob on it.
Posted on Mar 20, 2011
How To Install EasyCap On Windows 7
easycap was not meant to used on windows 7 (i think). but i have uploaded all my easycap drivers for you,.... as always right click exe's and in compatibility mode for windows xp service pack 2. if it still not working after driver install go device manager try update drivers from there.
easycap reccomend - ulead video studio for video editing.
the rar file has no passwords. easycap driver and stuff
Apr 22, 2016 | DekCell EasyCap USB 20 Video Capture...
How do I watch tv on laptop with easycap?
The easycap is not the best software to watch tv on laptop ,
There is much more better softwares , check out this link for the best satellite software ever.
Jun 14, 2012 | DekCell EasyCap USB 20 Video Capture...
Have a device called EasyCap to capture and edit video to the computer, only trouble is every time I connect it to either Camcorder or VCR I get static over the audio please help
It sounds as if the audio is not connected properly. Check that the you are using the correct audio output from your VCR or Camcorder. One way to do this would to connect to a TV with the same leads.
Nov 03, 2009 | Electronics - Others
EasyCap DC60 Vista 32 bit Driver
hi : i get the same problem but i solve it ............ how ?
i uset tow kind of cables in the same time : the svedio cable and the av cable
from the source connect the svedio normally to get a vedio and the av
cabe tow of them : the red and the white in their same color jacks .
to the easycap connect the svedio normally and the red av to the red and the white to the white and leave the yellow
but unfortunetlly this way work vey perfect withe me only on widows xp sp3 and im still keep trying to make it work on vista .
good luck to all .
Jun 22, 2009 | Ulead Videostudio 8 for PC
Have EasyCap video capture device and vista x86
I have windows vista and my drivers load fine. Plug in the unit and the drivers load. I have the 4 camera easycap and the VCR easycap. Install drivers first before plugging in the unit. Restart computer, plug in unit, check device manager if there is a stk1150 loaded under image. My problem is getting small files from the recordings. I converted 2 mins of my daughters dance solo and it turned out 1.7gb AVI file without sound. Changing the options to mpeg or WV files will crash the program becuase something doesn't match. I need to play with it more to understand it better.
Jan 20, 2009 | Ulead Videostudio 8 for PC
EasyCAP USB video capture device problem
Did you disbale your FIREWALL whilst you installed the driver, I found this most important. After installation enable your firewall again. I had alsorts of problems till I did this. Even so I feel these devices are somewhat unstable
Hope this helps
Jul 06, 2008 | Video Cameras
EasyCap Video Capture
Hi
I had the same problem. No picture and no sound.
Here is what I did to solve it.
1. I Un-installed the software and restarted the computer.
2. Placed the installation CD (that came with the product) back in the CD drive.
3. Click on "Install Driver" (this only installs the USB 2 drivers so that the computer can see the device)
Make sure you do not attach the Easycap Device before you have installed the USB Driver (as above).
4. Once USB Driver has been installed then plug in the Easycap USB Device, windows should then detect the new device, to make sure:-
5. Right Click "My Computer" "Properties" "Hardware" "Device Manager" check "Imaging Device" (which is where my STK1150 Driver was installed) and make sure it has no yellow exclamation mark next to it.
6. Go back to CD and "install the Uplead Software", you then have to Restart the computer.
Once all installed you can then connect your external device VHS Player/Camcorder etc to the Easycap device, using the Red/Yellow/White leads.
I like many before me, tried and I tried to get the image to play on the software "Capture" screen but all to no avail, I was pulling my hair out, I wasted two days on it, I finally decided that this product was a total load of rubbish and I had wasted my money and it had to go.
Then a major break through, some smarty pants made the comment about INPUTS & OUTPUTS, my prayers along with many others could have been answered ??....
I had actually plugged the Red/Yellow/White leads into the INPUT terminals of the external VHS Player, when they should be plugged into the OUTPUT terminals of the external VHS Player/Camcorder.
On a Camcorder the RED/Yellow/White terminals are usually Output terminals but on a VHS Player they are usually always Input only !!....
I tried running my Camcorder through the software and Hey Presto that worked a treat.
So in order to get my VHS to play through the software I ended up having to buy a Scart OUT (very important "OUT") Red/Yellow/White adapter (see link for product image)
http://www.maplin.co.uk/Search.aspx?criteria=scart%20out&source=15&SD=Y
Once all connected I pressed play on the VHS Player and I have to say that nearly fell off my chair "IT WORKED - IT WORKED - IT WORKED"
Sep 30, 2007 | Ulead Videostudio 8 for PC
Ulead Videostudio 8 for PC Logo
412 people viewed this question
Top Ulead Computers & Internet Experts
d3yavu3
Alun Cox
Karan Sethi
Are you an Ulead Computer and Internet Expert? Answer questions, earn points and help others
