Question about Zanussi ZDC5350W Electric Dryer
I have a Zanussi TCE7227w condenser dryer. The dryer will start, runs for 10-20 secs, then the program stops and the light which signifies the finish of the program lights up and the finish program beeps start. The belt turn OK, the water reservoir is empty. Any suggestions as to the cause of the fault?
5 Suggested Answers
SOURCE: Water leak on Zanussi tc7102 dryer
I had a similar problem. There is a 'o' ring on the plastic part that keeps coming out. This 'o' ring is not big enough, you need to replace it with a thicker one, preferably one made from a harder material.
Posted on Mar 01, 2009
jyackle5
  • 8197 Answers
SOURCE: Zanussi TCE71277W Condenser Dryer, switching
Im sorry we can not help you fix the problem You will need to call a repair person
Posted on Dec 07, 2010
SOURCE: I HAVE A ZANUSSI CONDENSER THAT AFTER STARTING
We have the same issue and i have turned the machine upside down today to find there is a condenser valve inside the connecting pipe that connects to the reservoir tank to allow it to fill. This valve has come adrift as an 'O' ring has come off of the end. I need to source a new 'O' ring from a hardware store or DIY store, which should solve the problem.
Posted on Dec 11, 2010
Machine is set to drain out, but Drain Light wont stop flashing
sounds like the drain is plugged and wont drain all the way check the drain line and see if it is clogeed with something
Nov 20, 2014 | EuroTech EDC158 Electric Dryer
My zanussi dryer has been working for four years and now its suddenly stopped. I tried cleaning the condenser which didn't work.How will i get it in proper condition again?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 19, 2011 | Zanussi ZDC37100W Electric Dryer
Zanussi 7102 won't start. Power is ok. Condenser tank full light remains partially on even when tank is removed. When startbutton is pressed condenser full light illuminates fully. Water pours out pipe...
Pat, Have you found a solution to this yet? I have got exactly the same fault today ! Having taken the top & left side of the dryer off, I found what looks like a broken drive belt - not the main drum drivebelt which is fine, but a shorter one (about 18cm diameter loop) with no obvious place for it to have come from. Any clues would be appreciated. Dave (drdave@fsmail.net)
Dec 31, 2010 | Zanussi TC7102W Electric Dryer
Dryer modle Tc7102w/t5c7102s was working ok but drum won't rotate
Theres two things to look at, the brushes on the motor, replaceable and cheap, if they are are healthy then there is one or sometimes two large capacitors, these give the motor the ooomf to get it rotating, these fail which is a common problem with washing machines and dryers, again about £5= on ebay.
Mar 25, 2010 | Zanussi TC7102W Electric Dryer
Zanussi ZWD1261 works fine except doesn,t turn off at end.
There is an issue with the timer . Needs to be replaced if it worries you.
Sep 20, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi zdc46130w Fault.
I think you should read the instruction manual . 3 beeps means some information to begin a solutin.
Feb 15, 2009 | Zanussi TC7114W Electric Dryer
Wash Machine WA950SCJ won't fill up
Washer dryers often have cold water valves with 3 separate solenoids. One for the main wash and rinses (which is clearly ok) and one for the condition rinse (to take the fabric conditioner down) which is probably ok too, and the 3rd one is for the dryer. It's possible this 3rd solenoid has failed.
Washer dryers need on a steady trickle of cold water running into the condenser chamber to convert the steam into water, which then gets pumped down the drain.
e10 means that there is a problem with the water supply.
a condenser dryer needs cold water to operate properly. the e10 code will appear if:
1. the water is turned off
2.the water pressure is too low.
3.the solenoid valve is open circuit
4.there is a problem with the pressure switch (least likely)
Cold valve is at the end of blue inlet pipe remove lid and you will see it.
f E10 is only appearing when trying to dry, the problem almost certainly is the condenser valve solenoid open circuit. The green solenoid on the inlet valve. Should read about 4000 ohms.
My money would be on the solenoid coil being open circuit. The coil can be canabalised from most valves although you may have to modify the connections. For simpler repairs - contact Zanussi and get the entire triple inlet water valve to swap out.
http://www.zanussi-electrolux.co.uk/files/unitedkingdom_english/0-999/zanussi%20error%20codes.swf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 20, 2009 | Washing Machines
Zanussi TCE 7276 W Condensing Dryer
hi i have a problem with the zanussi 7276w model all lights are on ready to start but the tumble dryer will not start
Sep 21, 2008 | Zanussi TC7114W Electric Dryer
Zanussi ZDC5350W Electric Dryer Logo
108 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
