Question about Intel Motherboard
Motherboard I was told that my motherboard was destroyed is it possible to retrieved the data on the computer?
    Guru:
  • 1,342 Answers
Yes, the data is on the hard drive. You can retrieve it by putting it in another pc as a slave drive or you can purchase an external hard drive case and retrieve it that way.
Posted on Aug 02, 2008
I have no local c drive how can i reinstall
Either:
* the existing disk-drive is not connected (power, data) to the motherboard;
* the existing disk-drive is "dead";
* there is no disk-drive at all inside the case;
* the motherboard has been told to "ignore" the device.
So, either:
* connect (power, data) the disk-drive to the motherboard;
* remove the existing "dead" drive, and install a new one;
* buy a new disk-drive, and install it;
* enter the motherboard's "BIOS SETUP" mode,
and use the "auto-detect disk drive" tool to "add" the drive.
Oct 15, 2010 | Dell Computer Refurbished DUAL PROCESSOR...
What IC contains the contact list? Will not power up for retrieval after transplant to new case. Can contact list be retrieved?
The contact list is in your hard disk, not on a particular IC on the motherboard.
You can retrieve it by trasfering the harddrive to another computer or placing it in a USB external HDD box.
The contact list's file depends on the email program you are using to read and send emails. In case you are using Outlook Express, the folder C:\Documents and Settings\<YOUR_USER_NAME_HERE>\Application Data\Microsoft\Address Book
contains the file.
Anyway, you check the wires from the power supply to the motherboard. You're missing some cable connection and that's why your computer cannot start. Check the long power connector with many colored wires, check the additional power "ATX" connector with 2 yellow and 2 black wires, check the thin 2-wire cable from the Power button to the appropriate pins on the motherboard. Also your power supply may be faulty and you can try to replace it with your old one from the old case.
Aug 21, 2010 | Computers & Internet
My Dell desktop motherboard doesn't work. Is it possible to transfer information to my new desktop-also a Dell ? Is there a creature called a motherboard dock?
Hi!
Yes it is possible to transfer all your data and information to your new desktop computer. Just get the hard disk drive out from your old computer and then plug it to your computer.
And with the motherboard dock you mention, a system casing is probably the best to dock your motherboard.
Thank you for reaching us.
Have a nice day!
May 31, 2010 | Dell (E210882) Motherboard
My compaq computer lost all power after I replaced dvd hardware. I'm told by knowledgeble people that this is most likely a motherboard problem and that it can be difficult to replace them in this brand....
One thing to check is, you knwo the power cable that goes into the dvd player, this some times can go in upside down. if it has its blown your board , but there is a chance it hasnt make sure its the right way, and try again.
Dec 02, 2009 | Compaq (283983-001) Motherboard
I have a Lacie external HD 500G which we installed approx. one year ago. It was working great . However recently the mother board in our computer failed and was replaced with a new m-board. Essentially we...
Kevin, Yes you will loose al data if you format it.DO NOT FORMAT as you have your data on it. What I suggest is to get the motherboard of same old model that you replaced. Sometimes the motherboards do not play up with all the hardware. Get the same model motherboard that you replaced. Once that works, copy all data to some other HDD. Or better still send the data in bits by email to yourself. The data would be safe on the email server. And can be retrieved later when all is well. OR attach the drive to some other computer where it works and send emails to yourself. Long and tedious job, but will save your data. And when the drive has started working with your new computer after formatting or otherwise, you can retrieve all the data. and delete the emails from the server.
Nov 16, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
E MACHINE CRASH
Try harddrive in different computer provided other computer do have same os version .thats how you can r retrive all your data data.
May 25, 2008 | E-Machines T2240 PC Desktop
Can data be retrived when mother board is broken?
I am sorry but there is no way to retrieve the data. If the numbers were saved on the sim then you will still have the number.
May 14, 2008 | Sony Ericsson K750i Cellular Phone
Motherboard
Try dismantling your laptop and one by one remove the module components like the Wifi card, Lan modem module (if possible) and try booting it up again and see if this problem will be solved.
What did you do prior to experiencing this particular problem?
Apr 04, 2008 | Toshiba Satellite M65-S9092 Notebook
Compaq laptop display not working
Have you tried an external monitor? Plug one in while the laptop is off, then turn it on. If no video on the external monitor, then there's a hardware issue somewhere else. Such as ram, motherboard or possibly cpu.
Oct 26, 2007 | HP Compaq nx5000 Notebook
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
