Question about Intel D845GVSR Motherboard
Soundcard is not working in my system - Intel D845GVSR Motherboard
  • Tony Mar 20, 2011
    did you install the sound drivers?
  • Intel Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 20, 2011
Soundcard not working
Make changes in the BIOs regarding the Motherboard options. You can elect to disconnect the on board sound system and it will cancel out that portion, leaving all else in place.
Apr 15, 2014 | Computers & Internet
Sound drivers download
If it is a soundcard which is combined in the motherboard then find the name of the motherboard (use system information or speccy or siw) And then go to the motherboard manufacturers website and download from them direct.(Google!)
If it is a separate soundcard then find the name of the soundcard as before and go to the soundcard manufacturer's website and download
Mar 02, 2011 | Computers & Internet
I bought a used think pad...someone cleaned out everything and just re-installed the basics. it works great however there is no sound? how do I know if it has a sound card or not?
Hi there, in order for you to chcek if there is sound car installed in your system. Click on control panel then go to system then click device manager then search for sound devices. if theres none and you see unknown device with exclamation point on it (!) that could be your soundcard. all you need to do there is to install the soundcard driver. you can download the driver at www.lenovo.com if its a thinkpad PC. thanks!
Apr 06, 2010 | IBM ThinkPad Soundcard
I need drivers for SB0220 soundblaster
you need to update to windows 8 when you have updated you need to remove your soundcard and reinstall it.then you need to reboot your system windows will then find your soundcard and automatically update your drivers.hope this is of use.
May 16, 2009 | Creative Labs Creative Sound Blaster Live...
Configuring two soundcards for parallel functioning
a windows computer can only use one sound card for one function
you can use the internal sound card for output
you can use the usb sound card for input / recording.
you can't use both for both.
Start -> control panel -> sounds and audio devices properties
open up audio page
You can have one device selected on Sound playback
You can have one device selected on Sound recording.
you can change which sound card is used for which function on this page. if you want to use the internal sound card set both settings to the internal if you want to use the external change both settings to the external.
Jan 09, 2009 | IBM Lenovo ThinkCentre M55e PC Desktop
Windows does not play nicely with 2 sound cards. Perhaps one of these days Microsoft will get out of the stone age and recognize other options, but for now, the general consensus is that it is not feasible.
About the only thing I have seen is to turn off one sound card in the hardware profile, but that is not what you are trying to do.
Jan 09, 2009 | ASUS VIA Apollo Pro Plus Chipset P2V-B...
Software to install the soundcard
my soundcard not working after i format n finish installing windows xp
Nov 28, 2008 | Intel Premier Resources 4-Channel 32-Bit...
Soundcard
can you teach me how to find my missing computer soundcard , cause i try to find it in internet but still can work it,and course you know in internet to many soundcard driver in there, the correctly i'm don't know my sound card name. thanks for you help, 845GV-M
Aug 30, 2008 | Edirol UA-4FX External Sound System
The driver that connects the computer sound system is not working and I have no sound
If you can afford a soundcard place this in the pc and disable the onboard soundcard as this onboard soundcard requires updates from the manufatures website plus download the latest updates for motherboard this is the only help I can give on this problem.
best of luck in sorting your sound problems
Jul 08, 2008 | ASUS Computers & Internet
Speakers 2.0 durabrand not registering
If both sets work on one computer, but none of them work on the problem machine, then it's not the speakers that are at fault, but rather the computer you're plugging them into.
As you are getting a "No Audio Devices" message, and the speakers get their signal from your systems soundcard, the soundcard drivers may not be installed, or working properly (the USB plug, it seems, only serves to power the speakers, nothing else).
Open up Device Manager, and look for your soundcard, and/or any devices marked with a Question (?) or Exclamation (!) Mark. Install/reinstall the drivers for any of these that you see. If you don't see anything marked as such, locate your soundcard under the "Sound and Audio devices" header, and reinstall it.
(NOTE: You can get to device manager in Windows XP, by going to Start-> Run -> type in "Control", and press ENTER. From the window that pops up, make sure you're using Classic View, then go to System -> Hardware -> Device Manager.)
If you DON'T, however, see either unknown devices or your soundcard listed in Sounds and Audio Devices, reseat your soundcard in it's PCI slot or a different slot in your machine, boot up your computer, and see if it's recognized. if it isn't, or if you're using an onboard sound solution, you may have to replace your soundcard, as it's defective.
Hope this helps :~)
Dec 31, 2007 | Audio Players & Recorders
Intel D845GVSR Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
