Question about Microsoft Wireless Optical Mouse
Helo i bought the Microsoft wireless desktop 5000, it works fine after i install it, but whenever i turn off my computer i have to reinstall everything, because it wont work anymore. Windows doest seem to recoknize the usb reciever for the mouse and keybaord, putting it in and out wont work. and im tired of keeping my computer on 24/7 or having to reinstall all the time, just got back from holidays. I have windows XP, a pentium 4 with 3.2 ghz
  • Microsoft Master
  • 1,830 Answers
Look to see what items are installed on your computer.
Look under Installed Programs. See if your mouse and your key board are installed.
Posted on Jun 26, 2017
Beni S-P
  • 1006 Answers
SOURCE: microsoft wireless notebook mouse model 1024 will not function.
1) One of your USB devices have faulted, or is causing a resource conflict (or similar)
-- Remove all USB devices, and reboot.
2) Your USB chip/ports have been damaged.
-- Find a spare HardDisk or bacjup your data and re-install Windows and see how that goes.
3) Your Power Supply Unit (PSU) isnt supplying enough power to your PC (usually caused by a Video card upgrade). Try a more powerful PSU ... 400watts should do the trick
4) Bad memory (RAM) can cause wierd problems. run memtest for an hour to make sure your memory is ok
It seems that many people are still getting the 'USB Device not Recognized' problem from time to time. Unfortunately there is no easy fix.
Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying .
Alternatively, removing all entries relating to USB in Device Manager and all associated USB drivers will force XP into refreshing the USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programs in Control Panel to uninstall any USB driver software. Next, boot up into safe mode and go to Device Manager. Once in device manager make sure 'Show hidden devices' is checked under the View menu. Uninstall all device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populate the Root Hubs & Host controllers again. Proceed to plug your USB devices back in, starting with your powered hub. Be aware that most USB printers and scanners need to have their drivers installed first before you plug them in.
Hopefully some of this may be of help, let us know how you get on.
Posted on Dec 07, 2007
  • 487 Answers
SOURCE: Microsoft Natural Wireless Laser Mouse 6000 doesn't work
If you take the batteries out there is a screw in there. unscrew and open (not easy) with flat knife in the edges wiggling.
attach and touch all the inside wires. I have had the same problem and it is an internal connector problem. Opening and closing aint easy and will take a little patience but it will work.
Good luck
Posted on May 03, 2008
  • 15 Answers
SOURCE: the wireless mouse works but the laser 5000
press connect on the wireless device...let go and then within 5 seconds press the button on the bottom of the keyboard. Repeat the same steps for the mouse whther its working or not. The problem usually is that the keyboard and mouse are on the same "Wireless Channel" and only resyncing them puts them on a seperate channel, hope this helps.
Posted on Dec 20, 2009
  • 435 Answers
SOURCE: I have a Microsoft Wireless Desktop Receiver 3.1
I have the same system. Mouse can be ordered, but not easily. Make sure mouse is not working.... i almost made tour same mistake. In my case, the mouse plug (from computer to wireless receiver) had become unhooked. All i could see is that mouse was communicating with wireless receiver but appeared to be frozen. If you can reset receiving channel, and see that receiver acknowledges presence of mouse, you may have my same problem. Also, if you can see that the laser light is working, mouse is probably ok, and batteries are good.
Posted on Feb 15, 2010
  • 76 Answers
SOURCE: where can you buy a replacement usb adapter for a
If this is a bluetooth mouse and keyboard, just exactly what I'm reading and your computer does not have bluetooth built in then this is what you need to buy.
You can get this at your local BestBuys or online.
Don't forget to vote for me, and give me a good rating.
Posted on Mar 25, 2010
Microsoft wireless keyboard 4000 and wireless mouse 5000. Installed software and recognizes mouse and keyboard but only funtion as standard devices, none of the bells and whistles work. open software and...
If you want to check if the software is installed correctly and the keyboard is working fine try using the multimedia key. If you are able to use the multimedia keys for reducing and increasing the volume or mute the sound that means it is working fine.
If you are trying to configure the Favorite keys then you will have to select the buttons from the software and link it to the particular program of your choice.
Open the software application
Select the button that you want to configure
Click on the browse button to select the program of your choice to open with that button.
Jul 21, 2010 | Microsoft Wireless Optical Desktop 5000...
Microsoft laser desktop 5000 vs Windows 7
The software might not be compatible. but for you to use the wireless keyboard and mouse you don't need a software just plug the wireless adapter and sync the keyboard and mouse . it will start working
Jan 17, 2010 | Microsoft Wireless Laser Desktop 6000...
Microsoft Wireless Laser Mouse 5000 Magnification Issue
Normal 0 Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. In the Left column is the button settings. The bottom one is the Right Button, which is set for Magnify. Whenever you hit the Right Side button the magnifier will turn on. To turn it off, hit the Right Side Button and off it goes. You can change any of the button settings by clicking on the drop down.
Hope this helps. Bud
Dec 17, 2009 | Microsoft Wireless Laser Mouse 5000
Wireless adaptor not installing after i wiped my hard drive
ok delete all the adapters in device manager and then uninstall your wireless adapter(after turning off the computer) turn the computer back on with adapter still uninstalled shut down the computer again and reinstall your wireless adapter start computer and it should find the wireless then if need be install drivers again
Dec 05, 2009 | Acer Aspire™ T180 PC Desktop
Can I make this work with Windows Vista?
  1. remove the battery and try to reset.
  2. enable legacy support for usb from bios settings
Oct 06, 2009 | Microsoft Wireless Optical Desktop 5000...
Stoped functioning
Normal 0 Turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try to see if it is working. If not try pressing the button on the receiver and then on the keyboard.
If your having trouble with the mouse also,
turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Dec 03, 2008 | Microsoft K5100141 Keyboard
Microsoft Wireless Keyboard 5000 keeps opening and closing the windows start menu once connected
Did you try the following.
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Oct 26, 2008 | Microsoft Wireless Optical Desktop 5000...
Inverted vertical scrolling
did u download latest driver form website maker site dont use cd
Jan 28, 2008 | Microsoft Wireless Laser Desktop 4000...
The Keyboard not working, MS Wireless, laser, desktop 5000
i don't like the sound of you taking the hard drive out of a old computer and loading it in your new one without reinstalling windows especially with windows XP your choice i guess.
Did you try and couple the keyboard and receiver by pressing and holding the button on the keyboard for a while?
Dec 08, 2007 | Microsoft Wireless Laser Desktop 4000...
Microsoft Wireless Optical Mouse Logo
35 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
