It is very much carrier dependent but you can forward SMS or MMS messages to your email by simply entering your email instead of a phone number. Easiest way to do that is to create a contact in your phone for the email that you use and use that contact when forwarding.It is very much carrier dependent but you can forward SMS or MMS messages to your email by simply entering your email instead of a phone number. Easiest way to do that is to create a contact in your phone for the email that you use and use that contact when forwarding.
You can't post conmments that contain an email address.
As far as I know there is no forwarding of text messages.
You might be able to go into the text message and long press on the text in question to copy it. You may need to highlight the text before you select copy too. Than start a new text and do a long press in the text box and select paste. I no longer have an iPhone but this does work on my Android phone.
There is no text display on a 1640 also this model doesn't have voice capability. Now, in order for the compass to properly function the unit does need to be calibrated. There is a sticker on the bottom of the unit that gives step by step instructions.
Follow the steps:
1. Open the message, which you want to forward.
2. Highlight message to be forwarded.
3. Go to menu then select forward option.
4. Enter the number to which it should be forwarded.
5. Then send it.
From what I understand, most cell phone companies require a court order requesting release of text messages. Sprint used to let people access them online but they stopped allowing that...w/out the order.
THIS PROBLEM ONLY HAPPENS WHEN EIGHTER OF THE CALLER AREIN MOTION I MEAN ARE TRAVELLING OR ARE VERY NEAR ANY RIVAL NETWORKS TOWER...............DONT WORRY,ITS NOTHING!!
First open your phone. Press upper right (-) key to get menu. Press joystick up 1 time to get Messaging. Press joystick center select button 1 time, then down 1 time for "Inbox" (or down 3 times for email). Press center select 1 time, joystick down 1time for Inbox, center select for first message. Press upper right (-) key for "More", then joystick down 2 times to get "Forward", press center select. Press upper left (-) key to "Continue", press joystick up 1 time to get "enter email addr." Press joystick center select button, and enter the email address you want to forward the message to. After you have typed in the email address, press upper left (-) key "OK" 2 times to "Send", if you normally enter a password, type it now, press upper left (-) key for "OK" and your message will be sent. Hope this helps. -Mike
