Question about Packard Bell Computers & Internet
Donry day I have a little problem as they put the disc into a computer that I do not read at all what the problem is what I do and I have a Packard Bell EasyNote computer LJ65
  • Packard Bell Master
  • 27,725 Answers
Make sure that the cd rom is getting enough power test all leads that are attached to the cd drive including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if your computer came with a motherboard disc the sound drivers could be on it
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
if these fail to fix the problem
It could be a problem withthe lens, you should try cleaning the lens, it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the acpower 3. remove powercable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected
Posted on Mar 20, 2011
Computer running so slow
GO TO START MENU. all programs, accesories, system tools, disc cleanup and run that tool. that will clean up all items on your computer thaT dont nee to be there. after its do check all boxes in little window that pops up and delete files
Feb 23, 2013 | Packard Bell Computers & Internet
I need an wireless installation disc
you can get the drivers for you wifi on Packard bell support site
look up you laptop model on site and it will give you all the drivers for you laptop just download the wireless install it or put it on usb to move it to another laptop /computer
Dec 27, 2012 | Packard Bell EASYNOTE A8 COMPATIBLE LAPTOP...
Remove cdrom drive
Removing the cd rom drive will not make your computer start up. Or are you saying the cd rom drive will not start up? CD rom drives are very sensitive on the disks they read. Most of them have a problem reading some of the discs that someone created on another computer. Make sure you're trying to read store bought discs.
Removing the cdrom drive is very simple. Turn the laptop over and you will normally see a screw with the icon of a circular cd on it. remove that screw then you can grab the cd rom unit by the door and pull it outl
Mar 19, 2012 | HEWLETT-PACKARD Pavilion dv7-1247cl...
Hp g62 wont play or eject
The first thing you can try is to put a paperclip into the small hole in the front face of the dvd drive to pop open the tray (if you can't get it open). If you put in a CD, and it won't read it, and put in a DVD and it won't read it, then chances are your DVD drive is no longer working, and needs to be replaced.
Jan 16, 2012 | HEWLETT-PACKARD Hewlett Packard HP G62 -...
The disc tray wont close
Try removing the CD-ROM drive from Device Manager and restarting the computer so that it will find the driver again and re-install it automatically.
Otherwise I'd explore getting a new drive. They are very cheap these days.
Aug 01, 2011 | Packard Bell (ATXMH28AP) Full Tower Case
Nero express will not load on windows 7 T4300 Packard Bel on trying to install . The computer will not read the properties to open the disc to get the .exe file So I cannot list the file to install via...
The Disc must be full of scratches so there must be Problem reading CD. Borrow Nero 6 CD from your friend and then install. Nero 6 sometimes also comes in Motherboard Drivers CD, try to find it.
May 18, 2011 | Ahead Software Nero Express 6.0 (NERO6OEM)...
I do not know where to put the little round flat black and white disc that came in the box with my 255W
You put it i your computer. The computer reads the disc to set up your GPS system. If I'm wrong Read the manual.
May 04, 2011 | Garmin nuvi 255W GPS Receiver
I recently rebooted my computer and my friend tells me the reason i have no sound is because i have no sound driver, i havea packard bell computer : MODEL : UTOW - RIO
if your computer came with a disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control
panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 01, 2010 | Packard Bell (030069) Sound Card
PACKARD BELL CD/RADIO/MP3 PLAYER. MODEL PB OP 10
This is not for connecting an MP3 player, but rather for playing MP3-CD's. Using your computer and a CD burner, you can burn a CD with up to about ten hours worth of MP3s on it. The procedure for creating the disc varies depending on your burning software. In Nero, for example, you would select "Music" and then "MP3 Disc" and then select the songs you want to put on the disc. For other software you just select "burn a data disc" and then select the MP3 files you want.
Once you have a CD full of MP3s, put it in the Packard-Bell stereo's CD player, and you will be able to play all the MP3 files that are on the CD. THe advantage, of course, is being able to put ten hours on one CD instead of only 80 minutes.
Feb 13, 2008 | Audio Players & Recorders
Computers & Internet Logo
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
