Question about Maytag 21.9 Cu. Ft. Bottom-Mount Refrigerator - White
My maytag bottom-mount refrigerator is not making ice and it has a grinding noise. i have checked for water flow and I have good water pressure. the water line on the back of the refrigerator is not iced and I can squeeze the line. it seems like I have a small amount in the ice tray. before I had this problem I was getting a brown icicle but I really didn't think to much about it. any ideas?
peyton32034
  • 410 Answers
SOURCE: refrigerator
it has a bad main control board call maytag they will most likely repair it in warranty for you
Posted on Dec 11, 2007
TJBENGR
  • 121 Answers
SOURCE: maytag side by side water/ice dispencer
Sorry, mine does it also..bad engineering.
Posted on Apr 22, 2008
  • 1462 Answers
SOURCE: MY MAYTAG REFRIGERATOR
remove back panel inside freezer and there is a tray at the bottom with a drain hole in the middle. this is blocked with ice. melt off with a hairdryer and follow up with hot water till it flows waay freely
Posted on Oct 02, 2008
ginko
  • 19396 Answers
SOURCE: Ice Maker will not release the frozen ice cubes from tray
The icemaker use an avaporator system with an heatinc coil and a fan to release cubes.
In your case either the heating coil or the fan in the icemaker must be replaced.
parts can be purchased from partselect.com.
Posted on May 31, 2009
  • 30 Answers
SOURCE: Ice maker quit making ice
There are repair instructions available for this particular ice maker at www.AnyoneCanFixIt.com Specifically, you should locate it at www.anyonecanfixit.com/household.htm
Posted on Sep 23, 2009
I have a Maytag refrigerator MFI2266AEU about 7 years old. The ice and water dispenser do not work as well as the controls. What might be the problem?
Basic diagnostics: make sure there is water supply line running to the unit and has water. If this is the case check to make sure the water supply line isn't crimped and is charged (has water pressure). If this is the case look for line blockage in the internal lines of the fridge. Make sure that all fuses are intact, there are no ground faults, and there is power to the control board. Make sure all ribbons are in tact and there are no breaks. Check for water damage on any of the sensors or other electronics which could be kicking fuses or internal breakers.
Jan 28, 2015 | Maytag MFI2266AEU Refrigeration :...
Ge refrigerator ice maker has stopped making ice
The water valve on the back of the refrigerator is bad, one controls water for the ice maker and one controls water for door water
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
May 11, 2014 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
Water line that feeds the icemaker is holding pressure at the flow tube to the ice tray and keeps blowing the line off
First...some questions: Is it making ice cubes OK while the line is holding? Have you measured he pressure in the line...if so what is it? What's the condition of the line...is it deteriorated? What's the condition of the hose/tube/line connector...does it appear to be intact?
Apr 15, 2013 | Maytag Refrigerators
Water under fridge and giant frozen ice covering freezer bottom
need a water Pressure Regulater to control excessive water pressure
Aug 28, 2011 | Maytag 21.9 Cu. Ft. Bottom-Mount...
I have a Maytag side by side w/ ice and water dispencer. Have been having intermittent problems with unit not dispencing water and not making ice(water not filling in to ice tray)unit is now making ice but...
YOU COULD HAVE A BAD WATER VALVE OR YOUR TANK IS CLOGGED UP AND STOPPING THE WATER FLOW THROUGH THE LINES. MOST MODELS HAVE A TANK IN THE BACK OF THE SHELVES ON THE REFRIGERATOR SIDE DOWN AT THE BOTTOM. IT WILL BE LOCATED BEHIND A PANEL YOU WOULD HAVE TO REMOVE SHELVES AND SCREWS TO GET TO IT BUT FIRST CHECK VALVE SOME SYSTEMS HAVE MULTI VALVES WHERE ON CONTROLS THE ICE MAKER AND THE OTHER ON THE DISPENSER.
Dec 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
Icemaker is very slow in making ice
Hello, When an ice maker is producing ice poorly or when it produce a few cubes or none or when the cubes are too small, it is usually because of a clogged water line or a defective water inlet valve.
Firstly, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve, then remove the water line from the back of the refrigerator. Next place the water line into a bucket and momentarily turn the water valve back on to test the flow, If the flow is poor you need to, repair, clean or replace the tubing or the shut-off valve that supplies the water. If the flow is good you may have to replace the water inlet valve.
Thanks
Jun 21, 2010 | Maytag 25.1 Cu. Ft. Bottom-Mount...
When water dispenser is pushed the water supply line rattles and very little water comes out. The water supply line has good pressure and the ice maker works. I also changed the filter.
Our water dispenser will work for about half a glass then the pressure immediately stops and the water flow goes to a small stream. Maytag MDZ2667HES Wide by Side. HELP! Filter was changed approx 3 months ago.
Oct 12, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag MFD2560HES - water flow restricted - noisy fridge
The flow of water is controlled by a solenoid. Thus magnetic -- rather electromagnet which mones the vale from open & close, both in the ice-maker & the water dispenser.
Thus the valve which is activated when door closes, must have lost its earlier condition and must be making an irritable buzz whenever its on. Simply get the Valve assembly replaced, preferably from their authorized service center closest to your place of residence.
Sep 25, 2009 | Maytag MFD2560HES Bottom Freezer French...
Maytag side by side water/ice dispencer
Apr 22, 2008 | Maytag MZD2766GES Side by Side...
Maytag 21.9 Cu. Ft. Bottom-Mount Refrigerator - White Logo
44 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
