Question about Dryers
My problem is the dryer timer will not work and no heat at all.
  • Dryers Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Mar 20, 2011
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
My dryer model dv231aew/xaa Will not shut off unless you open the door....on/off & pause shows its working but its not
follow this steps and fix it. Merry Christmas
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replace it. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace the heating elements.
Dec 17, 2013 | Samsung DV231AEW 7.3 Cu. Ft. White...
Frigidaire AEQ8700FGO dryer will run (and heat) for about 30 to 60 seconds then stop. 3 lights above start button will flash rapidly. Depressing cancel and start buttons at same time will not work for...
follow this steps and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replace it If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace it
Sep 30, 2013 | Electrolux AEQ8700F Electric Dryer
Dryer wont stop buzzing
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and need replaced. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. replace the heating elements
Jul 09, 2013 | Dryers
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
Hotpointdryer timer problem
There are two coils in the heating element, and if one burns out, the timer will not advance in automatic dry. The timer should still advance when using manual (or timed) dry.
Jan 20, 2010 | GE DBSR453EBWW Electric Dryer
My dryer will not heat and timer works until the cooling stage
It's either the timer or insufficient air flow. check your vents to see if sufficient air is coming out.
Jul 07, 2009 | Dryers
Timer only works on Timed Dry Setting
Check your heating element. If one coil of the heating element is burnt out the dryer will heat on the remaining coil, but the timer will not advance in automatic dry.
Nov 13, 2008 | GE DBSR453EBWW Electric Dryer
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Dryers Logo
Top Dryers Experts
