Question about Masterbuilt 20050106 Propane Smoker
I have a masterbilt propane smoker with no decent instructions. Do I still have to use charcoal?
    Brigadier General:
  • 4,736 Answers
No, no charcoal is necessary. If you used charcoal, you'd go from low and slow smoking, to high and fast grilling. That's not something you want or can do with a propane smoker. For more information and recipes go to www.masterbuilt.com
Posted on Mar 20, 2011
Does MasterBilt make a conversion kit to Natural gas from Propane> I need the proper orifice.
I take my burners etc. to a propane business who is licensed to convert. They sometimes have the jets on hand or can order for you. They have the knowledge to plug and redrill the jet you have for correct btu's,,,, should that be the only course.
Jun 22, 2015 | Grilling
HOW DO i CONVERT A CHARCOAL SMOKER TO A LP sMOKER
My advice would be: go to Landsman Smokey Mountain/search parts lists for their propane smoker/order the proper burner, mounts, regulator and hose. Assemble according to the Parts diagram. install a wood chip box. Happy Smoking.
Dec 15, 2014 | Landmann Smoky Mountain Two Drawer Easy...
Need instruction manual for Master Forge Vertical Charcoal Smoker and a thermostat
Hi bishop mi...
Go to the following webpage and download your FREE user manual for Master Forge Vertical Propane Smoker.
Use to cooking guide inside for thermostat settings.
Please take time to rate me
http://www.masterbuilt.com/pdf/manuals/7%20in%201%20Smoker.pdf
Sep 01, 2011 | Grilling
I have purchased model #20050611. Can I smoke with wood chunks only and not use charcoal? Do I put the pre-soaked wood in the flame disk bowl or the water bowl? I am used to a double barrel wood smoker...
Wood only. No Charcoal. If you're using wood chips - soak them first. No sure wood chunks will work, as they will have a tendency to flare up & burn rather than smoke.
The presoaked wood chips go in the flame disc bowl, below the water bowl. The water bowl goes on the first shelf bracket from the bottom up.
I was going to send you a copy of your Owners Manual, but the Model Number you listed does not match up with any Masterbuilt Smokers?
Enjoy your smoker,
Apr 21, 2011 | Masterbuilt 20050106 Propane Smoker
Does this require charcoal? Can you use charcoal if not required
Normally,it's not recommended, as it can get to hot and burn out the bottom of the pan. Use chunks of wood designed for smoking instead. They'll burn longer and temp is easier to control.
Feb 20, 2011 | Masterbuilt 20050106 Propane Smoker
30" Masterbilt smoker won't get over 60 degrees. I
I am having the same problems with mine. I have rebuilt the connection, three times.
I am going to pull the element out and replace it with a single-burner heating element like the Proctor-Silex 34101. That will be plenty of heat for the smoking I do.
Jan 31, 2011 | Masterbuilt Electric 30inch Smokehouse ...
There was no users manual with the smoker. do i use charcoal or lava rocks and where do i put them
I have used a number of propane smokers and your propane burner will be located at the bottom of the smoker cabinet and you should have a wood / charcoal box above that in which you can place your charcoal or wood.
I have attached a picture that shows the wood / charcoal box. It's not the same smoker but it will give you an idea.
Hope this helps.
Cheers,
Nov 25, 2010 | Masterbuilt 20050106 Propane Smoker
ADD CHARCOAL AND LIT PROPANE, BUT CAN'T GET TEMPERATURE UP ABOVE 225. OPEN TOP VENT TO GET TEMP TO RISE, BUT WOODCHIPS DON'T LAST AS LONG
This is a smoker and typically they you dont want it that hot unless it is stated otherwise in the manual. Smokng is an art, and requires patience. You should be smoking most thing for a whole day, if not days.
Jan 11, 2010 | Masterbuilt 20050106 Propane Smoker
I need a manual for may brinkmann propane smoker
If you were unable to find one at the link offered below, try contacting Brinkmann directly at:
* The Brinkmann Corporation
Attn: Customer Service
4215 McEwen Road
Dallas, TX 75244
Toll Free:
(800) 468-5252
Local:
(972) 716-4262
OR you may send them an email through this link:
http://brinkmann.net/Customer%20Service/ContactUs.aspx
Apr 14, 2009 | Brinkmann All-In-One Gas and Charcoal...
Masterbuilt 20050106 Propane Smoker Logo
218 people viewed this question
Top Masterbuilt Grilling Experts
Paul Carew
Simon Flummox
Simon Flummox
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
