Question about Car Audio & Video
Hi I have a sony CDX-GT500U car radio. The problem is that when i turn the volume up over 20 it cuts out. What can i do to fix this problem?
  • 27 Answers
Check pos and neg wires on speakers and radio they may be crossed.Does the radio have bass to it or sound like tweeter
Posted on Mar 20, 2011
Sony CDX-5005 factory installed in a Bryant boat... no out put in any mode to speakers. What replacement unit will fit and hook up to existing harness?
Any DIN style radio will fit onto the existing cut out.
Stay with Sony CDX family. The connect and color code will be the same.
Do you still has the remote control for this Sony CDX-C5005?
This remote has an "ATT" (almost like mute) //// lower left hand button.
Aim the remote to the radio and press the ATT button and see is the volume restore to normal.
Click HERE (skip to page 6) for a sample picture of the remote.
Jul 28, 2011 | Sony CDX-C5005 CD Player
Sony CDX-GT500U failure message
sounds like a problem with the optical pick up, can you explain the problem closer please...
May 23, 2011 | Sony CDX-GT500 CD Player
Sony cdx m610 resets itself at half volume
You have a shorted speaker or speaker wire. If a wire is touching metal lightly it may not have full continuity (short) and will work until more voltage (volume) is sent to the speaker and causes the short. Disconnect all speakers at the radio then turn the unit back on. Turn up the volume and see if it cuts out. If it stays on, re-connect speakers one at a time and test. Once you find the problem speaker, disconnect the wire at the speaker then test again. This will eliminate the speaker itself as the problem. Test again. If it still shorts, trace the wire from dash to speaker and look for a cut in the sheathing exposing the wire. Repair or replace the wire and you should be good to go. If the unit cuts out with all speakers disconnected, the problem is internal and will need to be serviced. Before you repair/ or replace the unit either check all the wiring and the speakers or have someone do it for you so it does not give you a repeat performance. Hope this helps.
Oct 01, 2009 | Sony CDX-M610 CD Player
Radio cuts off and back on seems to be vol related
This is cause by many things one of which is a faulty speaker that is going short when operated at high volume. Another is the wiring supply the power to the radio is not "thick" enough hence not able to supply the demand for extra current. Had this same problem with Golf II which I replaced the main supply wire and after that it went to full volume with no cutting off.
May 12, 2009 | Sony Car Audio & Video
Clock set
try turning the radio off and hold down one the buttons until it blinks then adjust
Dec 29, 2008 | Sony CDX-R3000 CD Player
Need to fix the time
I have the the sony cdx gt 400 and the manual is of no help but I figured it out. You have two options...option 1 is wait until 1 o'clock and hit the small reset button on the radio behind your detachable face, or option 2 is a even better option. Press and hold the volume button in and options will appear...then by tapping the volume button you will cycle through the various options until you find "clock adjust" then press the small "display" button below the volume knob and also right next to the "source" button...the hour will flash turn the volume knob to desired hour then tap the volume knob or display button and the minutes will flash then turn the volume knob to the desired minutes, and you are done...hopefully this helps
Nov 14, 2008 | Sony CDX-GT400 CD Player
Sony cdx r3300 Won't play...simply scrolls a message
_half fixed, use the remote -@least can get more life outa the unit!
Nov 11, 2008 | Sony CDX-R3300 CD Player
How to set time on sony CDX-GT50W
press and hold the volume control dial. when a menu appears press the volume control button until clock adj appears. then press seek to change from hours to minutes. to adjust the hours and minutes just rotate the volume control dial
Apr 22, 2008 | Sony Xplod CD Player w/MP3 Playback...
Sony CDX-C480 radio
I need the wireing dig for a sony cdx c480
Oct 21, 2007 | Sony CDX-C480 CD Changer
Sony cdx -m8800
Remove the radio, disconnect the blue wire, and connect the blue/white wire in its place. This should fix your problem.
Sep 08, 2007 | Sony CDX-M8800 CD Player
Car Audio & Video Logo
161 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
