Question about Haier BC112G Wine Cooler
My unit stays cool but makes a very loud noise when the compressor kicks in and while running.
  • clancycottma Mar 20, 2011
    The noise is not a grinding but loud whirring. I should not have said VERY but louder than normal. Brushes?
  • 4,924 Answers
The loud and strange noise while is running can only be present cause the cooler it is not perfectly aligned in horizontal plan ...I suggest to check the surface where it is ..and if you have a bubble level ...put it on top ..and adjust the base legs (if they are adjustable ) under until the unit is on perfect horizontal plan ...or ...insert something under and make it be even in horizontal plan ...
Posted on Mar 21, 2011
  • 17,970 Answers
This noise could occurs when the bushes in the motor start to wear, keep in mind that the motor is an evaporator fan motor. The motor is not in effect repairable but has to be replaced.
Hope this helps; keep us updated.
Posted on Mar 20, 2011
Whilepool model gs6shamb00, Why a few second after the compressor shut off, the compressor knock loudly? The evap coil also shakes for 30 seconds to 1 minute. charlie T
I had accidentally overcharged a unit with freon one time (r410a freon), and when the unit stopped, the compressors rotor would spin backwards and make a loud "knocking" noise. This was on a scroll compressor, not a reciprocating compressor. Also, most compressors have a check valve, allowing freon to circulate in 1 direction only. And if it fails, when the compressor stops, the freon will rush opposite its normal direction of flow, and will sound off as a knocking noise(again, I've seen that on a scroll comp). That may make your indoor coil shake. I've seen/heard that make the copper lines shake but never the coil. Hope this helps! And FYI... Most ac service techs can check "superheat and subcool" as well as freon pressures. Without checking these 2 temperature measurements, we are just guessing as to how much freon is in the system. Make sure to ask politely beforehand for your service tech to do so PROPERLY when he checks the freon levels per factory specs, which should be on the units technical data located on the outdoor unit.
Feb 17, 2017 | Whirlpool Heating & Cooling
Norcold de828 dual compressor
Thermistor on starter winding could be faulty Re: Jeff
Nov 07, 2013 | Refrigerators
New A/C Unit makes loud noise when it starts up
It shouldn't be too loud. You don't explain where the noise is coming from? The air handler/furnace or the outdoor unit.
Jun 13, 2013 | Heating & Cooling
I have a continental elec port. air. Not sure of model. Cools great but when compressor kicks on unit make a loud whistling noise. Cleaned filter no help.
although annoying, at this time i would not mess with it, the fan motor needs oiling (zoom spout oiler ) works the best .. you can find how in my other postings.. try running the unit on a lower fan speed... some cool is better than NONE
Jul 28, 2011 | Continental Electric Portable Air...
All of a sudden our refrigerator freezer and refrigerator stopped freezing and cooling.. The fan is working, cleaned the coils, but when the compressor kicks on it only runs for about 10-15 seconds before...
UNPLUG and remove the compressor relay...if it rattles when you shake it..its bad, if not, it could be the compressor..it takes alot of specialized training and tools and material to replace a compressor. Its not a job that can be done by the average person..
Jan 28, 2011 | Maytag MBR2256KES / MBL2256KES
Window air conditioner loud when compressor kicks in
Possible that compressor motor internal mountings broke.
Apr 07, 2010 | Heating & Cooling
I have a single room 8000 btu kennmore air conditoner was making loud squealing noise when compressor kicks on and now it makes no noise and does not cool at all please help
sounds like the compressor may have died on you. the compressor isnt running you might as well trash it sorry for the bad news but it probably isnt worth trying to replace a compressor in a system like that it would drive you crazy and take forever if it could even be done.
Sep 17, 2009 | Kenmore 8000 BTU Single Room Air...
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
True T-49 side by side is noisey
is unit cooling? if not suspect a deficient compressor. if it likes makes a rattling noise really loud suspect compressor wear hope it can help.
Apr 18, 2008 | True T-49 Side by Side Refrigerator...
Haier BC112G Wine Cooler Logo
337 people viewed this question
Top Haier Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
jasbo
jasbo
Are you a Haier Furniture Expert? Answer questions, earn points and help others
