Question about Compaq Evo D510 Minitower (Open Box) (OB4700432011) PC Desktop
Creepy 'USB' issues...
Does'nt matter WHICH USB port I plug into, it causes an immediate shut-down and reboot...what in the HELL would cause this ?
I redid entire sytem: Win-XP-Home (OEM disk) SP3, Live OneCare, 2gb Ram, 500 GB HD, Belkin internal USB card (5ports: 4 ext, 1 internal) Netgear Wireless pci adapter/card, Diamond 56k modem...nothing terribly radical. All obligatory Compaq/HP drivers (except Ethernet card) were downloaded and installed without any hassle.
I do not have the Compaq/HP restore disks available to me as this is 2nd hand machine.
  • carhearts Aug 05, 2008
    the only 'wire end' related to any USB devices would be the connection to the two external USB ports on front-side of the computer-case, and where it connects to on the motherboard...that particular wire/cable had solid (un-removable) 'blank' sections, which corresponded to certain brass (male) pins on both areas where the cable needed to go, so there was no room for error.
    Note: my Lyra mp3 player (with 2gb sd card installed) and web-cams work when plugged into front and rear USB ports...
    ...right now the 'issue' is my 2gb USB drive (Fat32) and external Hard Drive (80gb - NTFS) are the units which cause the pc to re-boot when hooked up. The 80gb external HD pins are set to 'slave', if thats of any help to anyone here...and without either of these external storage devices being able to transfer files between my laptop (which works fine with either attached) and my pc, I'm having to open the case and install the 80 gb HD by hand (as 'slave') in order to transfer/copy files as needed.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Re evo d510 USDT
after install sp24210.exe (USB2 driver), is ok for usb1 devices but shutdown/reboot winxp if any usb2 deice inserted.
I did fixed it by reinstall sp27532.exe (chip set driver).
I think the usb2 is for win98 or bugs for winxp.
Aussie James
Posted on Jun 20, 2012
  • jameschong
    jameschong Jun 17, 2014
    usb 2 can only detected/work on winxp sp2/3 not sp1. Aussie James
Allrighty...it's funny that you should bring that up because just before I installed the Compaq USB 2.0 driver...a funny voice in the back of my head told me NOT to...
...I cannot do a system restore now...because so much time has passed, and my sys restore is set to only about a month before...so the date where I orig installed the USB driver has LONG since passed...and that particular driver does'nt show up on Win-XP add/remove programs...
...so where does it reside ?
If this was my Dell laptop..I'd know right where to go, to delete the driver...but Compaq has to make things so 'obtuse', and I don't know where to look on C: drive...
Posted on Sep 29, 2008
I had the same problem as soon as i installed Compaq's USB 2.0 driver. Did a sytem restore and problem is now solved.
    Problem Solver:
  • 25 Answers
Check you USB wire end, if that center piece ( that white piece inside the connection) is missing that the problem. that white piece separates electrical connection, it it not there it causes a shorts curcuit and the pc shuts down
Posted on Aug 02, 2008
Laptop restarts after shutdown
This sounds like the On/Off program in the "Programs and Features" section of the computer. On newer computers, there is a feature called "On/Off", and what this does is it keeps power going to the USB ports on the computer so you can charge things and keep things plugged in. Sometimes, if you have certain things plugged into a USB port, and you shut down your computer, the USB ports will "wake" your computer up and turn it back on. Simple things like a wireless mouse will cause this, I know because I use a Logitech Trackball mouse and it's wireless. I had the same issue, and found out that simply flipping the switch on the mouse itself(turning it off), solved my problem. I would recommend either shutting the external devices off when you shut down, or just completely unplug everything from the USB ports(minus the keyboard).
Aug 26, 2016 | Dell Inspiron N7110 I17r-6434dbk...
My powered USB port on my Dell Latitude D410 shorted out. Can this be repaired/replaced?
The USB plug will need to be removed from the computer, if luck is with you the computer will work, if no part is available, use a none powered USB hub on a spare port if available to run your applications.
Jun 23, 2012 | Dell Latitude D410 Notebook
My computer restarts when i turn off the computer
Most Win XP shutdown problems reported thus far have been that it reboots when shutdown is attempted. This may be a global symptom emerging from several distinct causes, because, by default, XP executes an automatic restart in the event of a system failure. Therefore, more or less anything compromising the operating system during the shutdown process could force this reboot.
Disabling the “restart on system failure” feature may permit the exact cause to be isolated: Right-click on My Computer, click Properties, click the Advanced tab. Under “Startup & Recovery,” click Settings. Under “System Failure,” uncheck the box in front of “Automatically restart.”
Here are some of the things that may have produced this reboot-instead-of-shutdown symptom. Please refer below and perform the steps which are appropriate to your situation:
  • By now, the Roxio/Adeptec Easy CD / Direct CD software is well documented as being the major cause of this undesirable shutdown behavior. SOLUTION: Roxio has released new drivers (here) to solve this problem in both the Platinum and Basic editions of Easy CD Creator 5. As expected, at least half of the Win XP shutdown problems went away with the release of these patches.
    One warning about this patch comes from correspondent Bert Smith: Be sure to read the directions! “Roxio Easy CD Creator Platinum 5.0 can be a real hassle to get working under Win XP,” Bert wrote, “and there is the risk of your computer not booting if you blindly go ahead and install it without first consulting the Roxio Web site.” Bert also mentioned that Roxio’s “Take Two” backup program (normally part of Easy CD Creator 5 Platinum) is uninstalled when the Roxio patch is applied.
    • Direct CD. Many Easy CD users (but not all) found that installing Easy CD 5.0 does not cause the shutdown problem, provided they do not install the Direct CD component.
    • UDFRINST. Several people solved this reboot-on-shutdown problem by deleting the UDFRINST file. This file is part of the Roxio CD-RW software for systems not using Direct CD.
    • CDRALW2K.SYS. Correspondent Larry Blumette identified the CDRALW2K.SYS file (version 1.0.0.1048) as the Roxio file causing his shutdown problems and error conditions. When he deleted or renamed this one file, his problems went away. (Of course, you lose your CD functionality that way, too.)
    • Video Pack 5. Roxio’s Video Pack 5 causes the same problem because it contains includes the main parts of Easy CD 5. SOLUTION: Uninstall Video Pack 5 and also delete CDRALW2K.SYS (Tip from Christian Männchen). However, this solution may also have the side-effect of disabling access to your CD or DVD drive. SOLUTION TO THE SIDE-EFFECT: Apply one of the repair methods in MSKB Article 270008, Code 31 Messages Occur After Removing Adaptec Easy CD Creator 4.02c in Windows 2000 (Tip from Peter Kingsley).
  • Whether or not APM is enabled makes a difference — but the effect could go two ways. Some users report that XP reboots on shutdown if APM is enabled, but shuts Windows down just fine if APM is disabled. Other users report exactly the opposite behavior. According to Jack Dunne, this is similar to a known Windows 2000 problem. The issue seems related to the computer’s specific hardware or BIOS — so, as with all NT operating systems, stick to the Hardware Compatibility List where possible.
  • USB Connections As can be seen from remarks in the Misc. Hardware Issues section below, several different USB-related issues can impact shutdown. One of the most concrete examples was a “reboot on shutdown” problem contributed by correspondent Rick Bross. If his several USB devices (PDA cradle, flash card reader, etc) were plugged into the motherboard’s USB ports, his computer would reboot on an attempted shutdown; but when, instead, he plugged them into an external USB 2.0 hub, shutdown went just fine. (This was with Win XP Professional SP1 on a Supermicro X5DAE dual Xeon motherboard. The same devices plugged into an Asus A7M-266D dual AMD 2000MP system on the same OS worked without problem.)
  • “Wake on” power settings Power-management settings that have the computer “wake” on LAN, USB, modem, or (for that matter) probably anything else may also trigger a restart after shutdown. Correspondent Simon Wei provided this tip after a friend of his found an old old Logitech USB mouse would trigger “wake on USB” after every Windows shutdown. Their solution was to remove that particular mouse and all worked fine. The principle is much more far-reaching than this one example.
  • Hidden “wake on” power settings If you have an Ethernet card integrated into your motherboard, you may have hidden “wake on” settings that are harder to find. Site visitor Jim Porter found that his Asus P5GDC-V Deluxe motherboard had a “wake on” setting in Device Manager | Properties | Advanced rather than in the BIOS or Power Management settings. (The Asus P5AD2 and P5GD2 boards have this also.)
  • Y-SB3 Logitech Internet Keyboard can also cause this problem. If you use it as a simple generic keyboard, there’s no problem; but, if you install the Key Commander software that drives the special Internet functions, Win XP will restart instead of shut down. Unfortunately, Logitech has decided that they will not be updating this driver for this keyboard. (Tip from Jan K. Haak.)
  • Logitech MouseWare 8.6. Windows reboots when shutdown is attempted. The software caused a BSOD with KBDCLASS.SYS. Removing the software solved the BSOD the problem. (Tip from Pablo Cheng.) MouseWare 9.0 and 9.1 also have been linked to reboot-instead-of-shutdown in Win XP. Removing the software resolves the problem. (Tip from Aswin Kindts, Greg Williams, and others)
  • Webstar DPX USB cable modem. In the one case known to me, the problem was solved by switching the modem’s connector from the USB 1.1 port on the motherboard to the USB 2.0 PCI card. (The modem was provided by Telewest Broadband, manufactured by Scientific Atlanta.) (Tip from Ann L. Goonan.)
Jul 03, 2010 | Computers & Internet
My 5v logitech camera will not turn on and i have no idea whats up with it, any assistance would be helpful
Hello
Just a suggestion: Windows can disable the USB ports to save power. This setting is in Windows and it does not matter if the computer is a desktop or laptop. You can test to see if this is the cause. Turn the computer completely off, let it sit for 5 seconds or so and then power it back on. If the web camera turns on and works after the reboot, the Operating System is powering the USB ports down and causing the issue.
You can tell Windows to leave the USB port powered on all of the time. Click START, and go to the CONTROL PANEL. Double click the SYSTEM icon, go to the HARDWARE tab and then click the DEVICE MANAGER button.
This brings up a new window that lists all of the hardware that is in your computer. Click the + (plus sign) next to the UNIVERSAL SERIAL BUS CONTROLLERS entry. Scroll down to each USB ROOT HUB entry, right click each entry and click PROPERTIES.
This brings up a new window, click the POWER MANAGEMENT tab. Remove the check mark from the "Allow the computer to turn off this device to save power."
Repeat for all USB ROOT HUB entries, click OK to save your changes.
May 04, 2010 | Logitech Quickcam Chat Webcam
GT4016 hit pwr button comes on flashes three
Check the USB ports for damaged contacts. If the supply powers up and then shuts down immediately, you have a critical error. Damaged USB port contacts can cause this but so can graphics cards etc. Open the machine up and remove all cards and memory sticks and unplug all the drives but LEAVE THE CPU ALONE!! Now, turn it on. If it boots and starts beeping ( which it will with no memory installed) shut it down and reinstall each item you removed one at a time and turn it on after each single thing. When it stops booting and does whats its doing now then the last thing you plugged back in is the issue.
If it still doesn't power up with everything removed then the issue is in the mainboard. If this is th case, my advice is to seek professional advice..
Dec 02, 2009 | Gateway GT4016 Desktop PC
After accessing drive its shuts down and restarts pc
You may have already tried one or more of these things, but in case you haven't...
Plug the drive into other USB ports on the computer and see if it shuts down. If not, you have a bad USB port, so just don't use it.
If it shuts down, continue to second test.
The second thing would be to eliminate the disk drive as a problem. Try plugging it in to another available computer and see if you get the same problem. If it's okay, it would be a safe assmption to eliminate the drive as being responsible.
Next, eliminate any USB hubs you may have plugged in. Plug the drive directly into the USB port on the computer and see what happens. If it works without problem, the hub is most likely the problem. If you still have the problem, follow next.
Next, I would try using one or more other USB peripherals and plug them in and try using them. If that causes the same issue, you probably have a power supply issue (even if everything is powered fine) as one of the power leads may not be putting out the required voltage. Last possibility could be a problem with your motherboard.
Oct 18, 2009 | IBM USB Portable Diskette Drive (05K9276)...
When MN-510 adapter makes connection, video drops out.
Try to uninstall and reinstall the video driver. Make sure you note down the make / model first! The lastest driver may fix this issue.
GB Plus -
Mar 21, 2009 | Microsoft MN-510 802.11b (L21-00002)...
During setting up computer with drivers etc. System file could have become faulty some files not registered in System
You could have System file errors these files are the heart of O/S
whereas the reg is the blood if System file are faulty things do not work properly.
Go to C:\ right click properties / Tools / error check new box popsup
tick little box to fix errors and reboot
On reboot windows will check disk for errors and fix them
If this does not help please email me at thoughts001au@yahoo.com.au
Give a details description of what happens
Aug 27, 2008 | Compaq Evo D310M 845G P4 Motherboard
Creative Labs WebCam reboot problem
Normal 0 How much memory do you have installed in your computer? It may need to be, increased, as this is likely to be the cause of your computer freezing, rebooting, or shutting down.
Hope this is of some help. Bud
Jun 21, 2008 | Computers & Internet
Compaq Evo D510 Minitower (Open Box) (OB4700432011) PC Desktop Logo
294 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
