Question about General Electric Ge Simon Xt Wireless Security System
How do you set Simon XT to sound instant alarm once door or window has been breached withough having to wait the 30 second disarm allowance? I have a couple of doors that already sound alarm when opened and a couple of others that allow time out.
ford_67
  • 34 Answers
SOURCE: GE Simon Security System - help!!
The default for option 10 is 30 seconds and option 11 is 60 seconds.
It sounds like option 10 is turned off because when turned off the entry delay is set to 005 seconds. All entries must be 3 digits.
You ca set option 10 and 11 from 005-254 seconds. Hope this helps
Posted on Aug 24, 2008
WirelessGreg
  • 14 Answers
SOURCE: goes off even when disarmed!
This is from page 19 of the Simon3 manual found here:
http://www.safemart.com/manuals/simon3.pdf
It appears you have the "CHIME on Motion" enabled. Follow the Option 41 steps to disable it.
Option 41 - Voice Chime
The panel will verbally announce which chime sensor has been tripped if the chime
feature is on.
Add enables chime voice.
1. Open panel cover. Panel announces, Use numbered keys to enter ID.
2. Enter Access Code using the numbered keys. Panel announces, Please select from
Start Menu.
3. Press Add from the Start menu. Panel announces, Select from main menu
4. Press Option #. Panel announces, Option 1, press again for next option or done to
select.
5. Press 41. Panel announces, Option 41, press again for next option or done to
select
6. Press DONE. Panel announces, Option 41 is on.
Delete disables chime voice. The panel will not announce which chime sensor has
been tripped but will still chime 2 times for doors and 3 times for motion sensors when
a given sensor is tripped.
Start Menu.
3. Press Delete from the Start menu. Panel announces, Select from main menu
select.
delete
6. Press DONE. Panel announces, Option 41 deleted.
Posted on Dec 29, 2008
SOURCE: Disarming / Access Code/ Resetting
Ask seller or previous owner the code, or read in the manual how to reset the system to factory defaults
On the previous version (Simon3) it was press cancel + clock set + Minutes+ at the same time and the power up from battery
Posted on Jan 12, 2009
SOURCE: Programing 1st and 2nd numbers on the Simon XT home alarm
Try entering the programming mode with the dealer code, not the master. It's 4321 by default.
James
Posted on Feb 10, 2009
  • 80 Answers
SOURCE: Simon XT panel does not want to learn motion sensor
try learming the sensor in by removing the back and actavation the tamper switch of the unit. also make sure that the unit is not already learned into the unit and if all else falil default the panel and start over.
mj
Posted on Sep 07, 2009
I need to reset the alarm on my GE personal security window or door alarm
press the "status" button. If it is a Simon XT , press "disarm" then "status"
Mar 02, 2017 | GE Home Security
How do I permanently disable a GE Simon XT alarm system? Recently moved in and I want it off so I can leave my front door open for air.
do you own the property or rent . if renting there is nothing you can do but ask landlord to do something if yours you can cut the wires feeding it if you want .
Sep 10, 2014 | General Electric Ge Simon Xt Wireless...
Hi there, i have a Simon XT alarm system and i want to delete a sensor or reinstall it - i took it off the window when replacing them and now th system keeps bleeping to tell me it's been tampered
Try these 2 sites:
http://search.aol.com/aol/search?&s_qt=sb&q=Ge+simon+xt+service+manual&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
Jan 15, 2013 | GE Simon XT Wireless Home Security System
Simon xt key fob
doors and windows are armed with the single press. All devices programmed as "perimeter" will arm. "interior" devices still need a second press of the lock button
Jan 17, 2018 | GE Simon XT Wireless Home Security System
Had to manually disarm my alarm 2003 Tiburon, but why?
you need to ask a dealer of your make vehicle . FIXYA does not know.
Sep 18, 2017 | 2003 Hyundai Tiburon
How can i disarm the system without arming automatically after 30 seconds?
Hello my name is Israel and I will help you. First you will need to know where the override switch is located. Once you know where it is, you will need to close all vehicle doors and let it set. Once the alarm sets, enter vehicle, the alarm will sound. Insert key and put in the run position, but DO NOT START the vehicle. Once it is in the run position, push or turn on the overirde switch. This should turn off the alarm. Good Luck.
Feb 19, 2011 | Sound Around PWD201K 2-Button Vehicle...
Have ADT 3000 series alarm system - would like to set it to max
adt sw3000 panel does not support max button on key pad. best solution would be to have ADT tech reprogram Zones so windows are perimeter zones(instant when armed away or stay) and motions interior follower (instant when no perimeter zone was triggered first). doors stay exit/entry.
Feb 25, 2010 | GE Security Simon 3 Wireless Home Security...
How do i reset my alarm on a 97 jeep Grand
Here is excerpt from the 1998 Jeep Grand Cherokee Service Manual ... i know you posted under 1997 JGC but this information may be helpful ... by "reset alarm" i believe you meant disarming the alarm?
Arming
Passive arming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is exited with the key removed from the ignition switch, the headlamps are turned off, and the doors are locked using power lock switch. The power lock switch will not function if the key is in the ignition switch or the headlamps are on with the driver’s door open. The VTSS will not arm if either front door or the liftgate are locked using the key in the lock cylinder.
Active arming of the VTSS occurs when the Remote Keyless Entry (RKE) transmitter is used to lock the vehicle, even if the doors and/or the liftgate are open when the RKE transmitter Lock button is depressed. However, the VTSS arming will not be complete until all the doors and the liftgate are closed.
Following successful passive or active VTSS arming, the VTSS set lamp on the top of the instrument panel will flash rapidly for about 15 seconds after the illuminated entry system times out. This indicates that the VTSS arming is in progress. If the light stays on steadily during the arming, it indicates that the hood switch is closed (the hood is open). The VTSS will still arm if the hood is open, but the engine compartment will not be protected. Once the 15 second arming function is complete, the set lamp will flash at a slower rate to indicate that the VTSS is armed. Disarming Passive disarming of the Vehicle Theft Security Sytem (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the liftgate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter. Once the alarm has been activated (horn sounding, exterior lights flashing, and the the engine no-run feature), either disarming method will also deactivate the alarm. Depressing the Panic button on the RKE transmitter will also disarm the VTSS, but the horm will sound and teh exterior lamps will flash for about three minutes as a part of the Panic feature function. ..." And as an additional note, if you have the courtesy interior lights set at 30 seconds like i do, you have to wait until lights go out (with alarm still sounding) before you can disarm the alarm via passive disarm method... what a pain when you don't have the actual RKE handy... Good Luck!
Feb 14, 2010 | 1997 Jeep Grand Cherokee
Aug 12, 2008 | GE Security Simon 3 Wireless Home Security...
General Electric Ge Simon Xt Wireless Security System Logo
172 people viewed this question
Top General Electric Home Security Experts
Lawrence Oravetz
Are you a General Electric Home Security Expert? Answer questions, earn points and help others
