Question about LG LRSC26911 Side by Side Refrigerator
How do I remove the icemaker from my LG model LRSC26911TT refrig/freezer
3 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: Need owners manual for LG Refrigerator
Your manual can be found and downloaded in PDF format. Hope this helps, Thanks, Sea Breeze
Click link below.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Posted on Feb 26, 2009
  • 489 Answers
SOURCE: LG refrig with freezer on
There is no reset button. Make sure the light bulb has not burned out. It's possible that ice has frozen the light switch. Use a hair dryer to the ice switch to see if it will melt the ice and release the switch. Good luck
Posted on Jun 19, 2011
Our icecube maker has stopped working on our Kitchenaid Model KBLA20EMSS Any suggestions on what the problem might be?
unplug the unit,remove the entire icemaker,then the motor module from the front that operates the harvest and all features,and manually rotate the motor,then re-install the motor on the icemaker and re-install it into the refrige and plug in the refrige,sometimes the ,motor glitches, and after you manually turn them it gets them going again
Aug 11, 2010 | KitchenAid KBLA20EMSS Bottom Freezer...
Ice maker does not make ice.
The water tube to the icemaker inside the refrig may be frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 06, 2010 | LG LMX25981ST Stainless Steel Bottom...
Whirlpool icemaker microswitch location
If the icemaker is still in the refrig ,(easily removed with 1 screw ) pour about 2/3 cup of water into it . Also check the black fill hose which is above the icemaker fill cup , to see if it is frozen closed . If the icemaker dumps the cubes , and doesn't refill with water , replace the water inlet valve behind the refrig . If it doesnt dump the ice , replace the icemaker . My parts site is down , or I would give you part numbers for the water inlet valve and the complete icemaker .
The laser light should flash 2 times , pause , flash 2 times etc , if working correctly . If the laser light is not on , then the icemaker is in the harvest mode . If it stays off , icemaker is bad . If you close the flap on the left side of the freezer , the light should go off , until you release the flap . If these factors are ok , then the optics are ok .
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
MY ICE MAKER FEELER ARM IS STUCK IN THE UP POSITION. CAN YOU PLEASE TELL ME HOW I CAN FIX THIS? MODEL LFX25950SB LG REFRIG
Water is getting into the area where the arm pivots and freezing. This prevents the arm from dropping down when it should. I use a hair dryer to melt the ice in the area of where the arms comes out of the base. As soon as the arm drops, the ice maker will make more ice. This LG in the door icemaker is junk.
Jul 14, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
GE French Door 22 cu ft (PFSW2MIXSS). Loud buzzing from behind the freezer. Ceased cooling.
The model number you post appears to be incorrect.
The buzzing was from the evaporator fan blade hitting on some ice build up. Getting to it on a bottom freezer refrig is a bit of a pain in the back side. If your model has a pull out freezer drawer, that has to be removed, the icemaker removed, one side of the drawer supports from the freezer wall, all to allow you to remove the back wall of the freezer to get to the fan. You may be able to just thaw out the fan and surrounding area then which will get your refrig cooling again, if the ice was just around the fan area. On the pain in the but repair scale of 1 - 10, this one rates at least a 7.
May 30, 2009 | GE PFS22SBSSS Stainless Steel French Door...
I CHANGED THE FILTER AND SET THE SETTINGS AND IT BEGAN TO WORK A FEW HOURS LATER THE DISPLAY WAS SHOWING ER NOW THE REFRIG. IS NOT COLD AND THE FREEZER IS NOT WORKING AND THE ICEMAKER IS NOT WORKING ALL IN...
If this is the Kenmore french door model with bottom freezer and ice and water in the door made by LG it could be that the mother board has failed.  Call for service and hope that warranty is still in effect.
May 19, 2009 | Refrigerators
Model 78182891 Coldspot with excessive water Collecting in Refrig
a plugged or frozen drain is a common problem that occurs from time to time in just about all refrigs so the answer is yes it may occur again in the future. But folllow theses directions and it will probably not occur again for 2-3 years.
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
  • reassemble in reverse order
Post back if you have any questions and I'll gladly help you out Thanks Peyton
Mar 17, 2009 | Kenmore Refrigerators
11 year old amana bottom freezer icemaker drips water when filling tray
as long as the temp in the frz is normal. the i/m could have a bad thermostat that, could be causing it cycling too soon or the tray is leaking water. either way i/m needs to be replaced, sorry
Sep 26, 2008 | Amana ABB1927DE Bottom Freezer...
Icemaker
You might have a frozen line. Also and this seems more important to you its prob to cold, Trust me to cold of a refrig will cause hollow ice cubes first leading to a frozen line. Clean your coils, if you have another refrig empty out into that, unplug it leave doors open a couple days. If you can get to water line use a hair dryer from a distance defrost line, turn down freezer half knotch 1 full one at maximum. should fix issues, especially if filter already changed. If this all check prob a clogged line, not just frozen.
Mar 15, 2008 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Open Questions:
See all LG LRSC26911 Side by Side Refrigerator Questions
LG LRSC26911 Side by Side Refrigerator Logo
103 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
