Compaq Presario Cq50-115 nr it is not working on AC Adaptor, what could be the problem
  • 600 Answers
Either the Adapter is bad (check with known good one) or the charging circuit in the laptop is bad
Posted on Mar 20, 2011
Compaq Presario V3000 SUDDENLY DEAD
Remove the battery and try on the AC adaptor only. if it still doesn't work try a new adaptor.
Apr 06, 2012 | HP Compaq for Presario V3000 Motherboard
Exclamation mark by network adaptor f700 presario compaq laptop
You can download the LAN and device drivers from theCompaq/HP WEB support/download page. Make sure you select your model laptop andthe Windows drivers you require and install them. Click on this link todownload the drivers: -
www.compaq.com/country/cpq_support.html
Feb 05, 2012 | Compaq Presario F700 Series Laptop...
Will not work with ac power adaptor but does with
Did you wiggle it a bit when plugged in? You can't tell from looking on the outside if the plug is fine because it goes bad inside where it is soldered. This is a very common problem, and have fixed many laptops with the same problem. All of them had a bad solder connection inside. Did you dtermine the plug was fine by plugging another ac adapter to your laptop or you just checked it visually? Hit me up I will solve this one for you.
Aug 12, 2009 | Compaq Presario 700 470024-192 Notebook
Need a sound sofware
i can't find sound and audio driver after formatting my laptop compaq presario C700 notebook pc
Nov 09, 2008 | Compaq Presario 700 470024-192 Notebook
COMPAQ V2000 WILL NOT POWER UP WITH DC/ADAPTER OR BATTERY
Hve u tried a differnt adaptor , the adaptor might be blown too ,try replacing the adaptor , also check for the power cord if it has any kinks in it which may be interrupting the power supply , since the adaptor 18.5 v 3.5 a is the most common of all hp adaptors u should find one to try .
Aug 27, 2008 | Compaq Presario R3000 Notebook
I have a compaq presario V5204NR
Try starting it with just the adaptor or just the battery.
If the adaptor is broken it might not properly power-up, same goes for the battery. You'll need to exclude these two first.
If it starts with just the adaptor: dead battery.
If it starts with just the battery: defective adaptor (broken connections, insufficient power etc.)
In both cases you should probably call upon your warranty. That is, it that is still applicable.
If both situations don't work, let me know and we'll think further.
Greetings,
DarkNeogen.
Jun 20, 2008 | Compaq Presario Notebook
Compaq Presario 1200 won't charge battery
dear N9YK
you can follow this
If you have a loose connection where you plug in the power on your laptop, or it works intermittently, you could have a bad dc jack. Symptoms
  • Move the power plug and the laptop loses connection
  • Broken or cracked dc jack
  • Laptop won't charge but worked on battery
  • Power LED and battery LED flicker when the adapter tip is moved
  • Battery won't charge
  • Sparks come out the back of the laptop
Why does this happen?
  • Flaw in manufacturer designs
  • Use of universal or non-original ac adapter
  • Lots of plugging and unplugging of the ac adapter
  • Tripping on or pulling the ac adapter cord
or you can check your dc amper in your adaptor
oke
thx
cropp
Mar 16, 2008 | Compaq Presario 1200 Notebook
Compaq presario v2000 notebook will not boot up blank sreen
If it is working fine with AC Adaptor, change your battery it need replacement.
Feb 09, 2008 | Toshiba Satellite A15-S129 Notebook
Compaq Presario 1680 Notebook shows no power in window when plugged in.
Take the battery out disconnect the AC adaptor Press and hold the power button about 7 seconds. Put the battery in and connect to AC adaptor press and release the power button. If it caused by static-component lockup, issue will be resolved. If still there is no activity including no power light check the AC Adaptor if its working
Good Luck
Dec 30, 2007 | Computers & Internet
Compaq Presario 700 won't power on
These are prone to broken power jacks that short out components on the mainboard. My shop saaw a lot of these come in dead like this and sometimes we could get them going again with a lot of mainboard work, but it seems they keep breaking.
I would save your money for another laptop considering the lousy reliability record these models have.
Dec 22, 2007 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
