Question about Dacor DMT2420SS Microwave Oven
I need a replacement for a touchscreen panel a circuit board for a dacor 2420ss
  • Dacor Master
  • 9,086 Answers
It can be repaired for $39.95 in most cases (details), or you can get a display unit here.
Posted on Nov 21, 2011
Dacor wall oven
Your tech is making it easy on himself, either he makes bank on the 1300 dollar repair or you back-out and let him off the hook.... Heat/ Temp sensors are nearly universal, so just about any RTD sensor will work in the oven, they are easily replaceable as well. Second, the logic control module is $269.40 at RepairClinic, I would start there- while installing the logic board, pull out the relay board and give it a close look in the daylight to see if any of the solder joints on the back of the board are cracking, burned, or otherwise failing- it is probably fine. Install the logic board and observe operation, the rest of those parts are likely not necessary- your tech sounds like a "Parts Changer Monkey," the old PCM.
Apr 12, 2016 | Dacor EO130SCH Epicure Discovery Wall Oven...
Dacor DM02420S Micrwave Display Screen - Can't see anything
can you see any thing like a circuit in that pannel.check for the soldering joints in that pannel.
Oct 12, 2008 | Dacor DCM24 Convection/Microwave Oven
Panosonic Microwave convection Model NN-8501V Touchpad appears dead
The unit has a fuse in the power board, but when the fuse is gone it does not even start up. If it starts it is not the fuse.
Look rather a problem with a faulty touchpad, or the magnetron that is not working and need to be changed.
Check also the door sensor.
Oct 03, 2008 | Microwave Ovens
Dacor microwave oven DMO24S panel buttons LEDs are non functioning. How do you replace panel.
I'm a little confused. What part you need depends on whether you have a display issue or an issue of some pads on the keypad are not responding.
Please post a new help request with your full model (thanks for that) and more detailed symptoms.
Jan 29, 2013 | Dacor DMO24SS Microwave Oven
We have a kenmore microwave 721.80803400. the display screen has gone completely blank. the microwave itself works (heats up, etc.) just fine. what part needs to be replaced?
While many microwave control circuit boards and displays are repairable, in this case, you may be better off replacing the board.
The part number is 6871W1S387A and you can get it from the Sears Parts Direct Web site.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays have a lock:
Sep 08, 2011 | Dacor DMT2420 1200 Watts Microwave Oven
Turntable will not rotate.
If it's also not heating, on the DMT2420, that's a bad bottom door switch, or possibly that switch's mount.
Otherwise, it may be a bad turntable motor, turntable coupler, or the control circuit board (which we repair).
The service manual is here and the parts list is here.
You can order Dacor parts by part number from the Pros here.
Feb 17, 2011 | Dacor DMT2420 1200 Watts Microwave Oven
Dacor DMT2420 turntable not rotating.
It may be a bad turntable motor or coupler, or the motor may not be getting power due to a bad connection or relay on the control circuit board (which we repair).
Dec 07, 2009 | Dacor DMT2420SS Microwave Oven
WE ARE AN INDEPENDENT SERVICE CENTER AND WE REPAIR DACOR APPLIANCES IN AND OUT OF WARANTY. i HAVE A DACOR RNGE HOOD/VENT MODEL RV46 SER RH8390987; WE HAVE THE KEYBOARD AND KEYPAD BUT NEED TO KNOW HOW TO...
Since you're a Dacor-authorized warranty service center, I'm shocked they haven't sent you the service manual in your manuals subscription!
You should contact your warranty servicer liaison at Dacor for that, and ask them bulletin # 04-07, which includes:
"RV30, 36 & 48 produced after 1/30/04: units equipped with the 12A control board part # 72881, the mounting screw for the main terminal board could be in contact with the heat sink on the control board. If the board is touching the heat sink
symptoms will include: inability to change speeds at the touch pad, and the blower operating as soon as the unit is prompted to rise.
In some cases, the board may be damaged, however, preventing the screw from contacting the heat sink will usually correct the malfunction.
Units affected are RV 30, 36, & 48 with serial # prefix of 0405 and above. If you have questions, please contact Technical Service 800-35-DACOR."
Or you can see that bulletin and exploded views here.
May 25, 2009 | Microwave Ovens
Often I have to hit the open panel several times to open the DMT24203 purchased in January of this year. It started a couple of weeks ago . Would appreciate any info Patricia Kuhl
This is usually due to grease buildup, or a worn or broken door open button or door open lever.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
If you are a Dacor owner with product covered by a Dacor Warranty, please contact your local Dacor Authorized Service Provider, or contact Dacor at (800) 793-0093. Or, click here to Contact them online.
If you are a Dacor EASE contract owner, please contact Dacor EASE Claims by phone, anytime, at 1-877-676-EASE (3273).
Dacor EASE Claims
650 N. Missouri Ave
Jeffersonville, IN 47130
(877) 676-3273
If you are a Dacor owner and your warranty has expired, please contact your local Dacor Authorized Service Provider for service. Click here to find the Dacor Service Provider nearest you.
If you need replacement parts please contact a Dacor Authorized Parts Distributor. Click here to find the Dacor Parts Distributor nearest you.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 23, 2008 | Dacor Microwave Ovens
Dacor DMT2420SS Microwave Oven Logo
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
