Question about Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Natural Gas
I have a telstar TGS 50 spa heater that keeps shutting off pre-maturely. Even if I turn it up all the way, it will usually burn for about a minute and then shut off for a bit and then turn back on. The tub isn't even close to the temp of having it shut off. What could be causing this issue? thanks!
    Top Expert:
  • Teledyne Laars Master
  • 8,889 Answers
Make sure gas pressure is correct if not it will overheat and shut off
Posted on Jan 14, 2016
3 Suggested Answers
  • 61 Answers
SOURCE: My teledyne Laars Telstar Model TGS-50 spa heater
Without doing more troubleshooting i would have to say that it is the main board (the board with the knobs on it) Take it out and see if there is any corrosion on it.
Posted on Apr 06, 2009
  • 81 Answers
SOURCE: My teledyne TGS 50 spa heaters main burner ignites
That is the main burner and its control. Replace it.
Posted on Jul 19, 2011
Kerosene Heater starts up and then shuts down
David, you need a copy of the Troubleshooting Manual here:
http://www.toyotomiusa.com/OwnersManuals/Portable%20Heaters/Name%20begins%20with%20LR%20or%20LS/LR-350%20LR-450%20Troubleshooting%20manual.pdf
It sure sounds like a failure during pre-ignition. Page 5 covers both of your burn times with two different Flow charts.
A yellowish flame can mean a warped flame ring or incorrect air flow.
Dec 29, 2014 | Heating & Cooling
HLS & Service Heater LEDs
Hello.... HLS usually means hi limits.... check the connectors at the high limit switches, to make sure they're not rusting off. If they're good, and the heater fires, but turns off after a minute or two, the problem lies usually with the temperature regulator.... it's the round cover with the 4 slits in it between the inlet and outlet. It comes out counter clockwise. It holds a spring with what would be a car thermostat attached to the end of the spring. That thermostat can be malfunctioning, and it will allow the water to get too hot coming out of the heater, which trips the hi limit. A quick fix is to remove the spring with the temperature regulator, and put the cap back in place. You definitely want to get another one to replace it, because the efficiency rating of the heater will go down considerably.... but it will do the job in the meantime with no danger. (Its like running a car with the thermostat removed, it can be done, but the engine runs too cool). They cost about 50 bucks on amazon.
May 05, 2013 | Pentair Mastertemp Pool & Spa Heater Dual...
I have a teladyne telstar tgs 50 natural gas pool heater that keeps shutting off early. I know the tempurature isn't that warm yet. If I turn the temp knob up a bit, than it will ignite and heat for...
No the issue is not with temperature limits its the main board (the board with the knobs on it) Take it out and see if there is any corrosion on it. If there is corrosion or any sort of rusting etc please replace the main board and the issue will get resolved.
Thanks
Mar 20, 2011 | Teledyne Laars Laars Lite 2 Pool Heater...
Have a brand new Master Temp 400K Propane with an Intellitouch and the heater shuts off at 84 degrees. Do I need to set a max temperature from the heater control panel?
If this heater has pool mode and spa mode as an option, and you need the water higher than 84 degrees, you must set it to spa mode even if it is a pool. As a regulation, these heaters come pre-set to max out at 84 degrees as a safety feature. However, in spa mode it can reach 104degrees.
Jan 11, 2011 | Pentair Mastertemp Heater
My teledyne Laars Telstar Model TGS-50 spa heater will not stop heating at 104 degrees. I have had it go to over 110 degrees before I shut it down. Whats causing this ?
Apr 03, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pentair Heater shuts off prematurely when warming spa
check gas pressure could be running out or overheating
Mar 06, 2009 | Pentair MINIMAX NT TSI IGNITER
Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Natural Gas  Logo
102 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
