Question about Bosch 11241EVS SDS-Max Rotary Hammer
Not working steady i have to tap it slighty with a hammer for it to work
    Sergeant:
  • 194 Answers
LOOSE CONTACT COULD CAUSE THE PROBLEM
Posted on Mar 20, 2011
My drilling machine 26mm active pro brand. i am using drilling one hrs ok after running problem hammering mode stoped only running not working for machine not proper working in hammaring mode.what...
Sheared hammer pin, stuck hammer or failure of a bushing or washer. A sharp tap with a rubber mallet in an area not likely to be damaged can sometimes free stuck hammers, if not it's a disassembly.
May 10, 2014 | Drills
Baxi banging noise
noise in water pipes is called water hammer and is when the water flow pulsates from an inconsistent flow. Water has mass and when stopped suddenly there is a pressure build up which moves any loose pipes. It can be fixed by putting more securing or mounting saddles on the pipe to hold it steady or you can get a pressure accumulator and it takes up the pressure build up and stops the noise. It is most prevalent when sudden stop taps are used such as ceramic taps or stop cocks and less so when you have to screw down the tap to shut off the water.
Jun 24, 2013 | Heating & Cooling
I have a new uberhaus shower faucet lever type with seperate diverter.prior to install i had no noise problems now i do i have checked all pipes to make sure that they are well atached to framing.i have...
indicates that you have ceramic 1/4 or 1/2 turn inserts in the taps
These taps are very quick action taps and the water flowing is stopped immediately resulting in water hammer
The air chambers you have installed ( accumulators ) may be working but the pipes will suffer the water hammer all the way back to the utility tap on the foot path
Find out the utility pressure to the house and then you may have to install a pressure regulator on the inlet pipe to reduce that pressure to stop the water hammer
Feb 12, 2018 | Home
Have1989 nissan hardbody and carbarator runs a steady stream of fuil when trying to crank doesnt stop. Whats wrong
Hi, the likely problem is a stuck float valve. If you tap with a small hammer on the carburetor float bowl near where the fuel line attaches, you may be able to reseat the valve, at least temporarily. As a long term solution, I would rebuild the carburetor. In the process, you would get a new float valve. Please let me know if you have more questions, and thanks for using FixYa.
Apr 02, 2011 | Nissan Hardbody Cars & Trucks
I have a 2006 crysler town and country i cant get the rear rotor off ive used wd 40 , hammer and evrything in my power to try and free this up . The rotor will begin to slide a little then its like...
If you can fit a good sized flat head screw driver behind to help you wedge the rear rotor off, this may work with the hammer to tap it along. A crow bar may even work if you have the clearance. Remember, when tapping the rotor out, rotate it each tap to make sure it comes off somewhat straight.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 12, 2010 | Chrysler Town & Country Cars & Trucks
The trailer ball is rusted into my trailer hitch. Any solutions?
Tap with a hammer - a little WD-40 or Liquid Wrench - tap some more.
Good luck with this "sticky" problem.
Thanks for your interest in FixYa.com
please vote
a
Nov 14, 2009 | Thule Folding 4 Bike Carrier for 1-1/4"...
Why would a blower work sometimes and sometimes it won't on a 97 lesabre? When it does work, it will start on high and then fade out until it stops. How hard is a diy fix?
If you have a Volt Meter you can check the voltage to the fan motor. If the motor voltage drops you may have a bad fan switch, if your voltage stay's steady you have a bad fan motor. If you do not have a Volt Meter, when the motor starts to slow down tap on the motor with a small hammer lightly. If the motor speed picks up you have a bad motor.
Oct 03, 2009 | 1997 Buick LeSabre
The horn has died on our 2000 passat estate it got quieter and quieter and harder to work, a friend recomended banging it with a hammer while pressing the horn. This did not work although the horns made a...
Check the horn relay is ok,
Check the horn ground is ok.
Place a trouble light across the horn supply- when horn is pressed it should light up steady.
If it lights up, the voltage to the horn is ok -then a replacement horn should fix it.
Sep 04, 2009 | 1999 Volkswagen Passat
Try to start the car and the starter wont work let it sit awhile and it will start it will happen 40% of the time
first thing i would do is the tap test when the starter doesnt work take a rod and hammer... no im not joking, put the rod on the starter/ soliniod DO NOT TOUCH THE WIRES and tap it with a hammer( DONT "HAMMER" ON IT THOUGH) just enought to send a good shock through the starter. if that alows you to start the car replace the starter...
Good luck
Aug 23, 2009 | 1994 Oldsmobile Cutlass Ciera
Can't remove the chuck retaining screw.
Place drill in vice with chuck in vice facing up . Clamp chuck lightly but with enough force to hold firmly.
put allen wrench in chuck and lightly tap down to make good fit to allen screw head.Clamp chuck jaws down onto allen wrench lightly to hold wrench steady. Take piece of pipe to end of wrench,10".
These chuck screws are tight. Hammer clockwise until screw brakes loose.Open chuck completely and remove screw.Chuck is threaded to spindle shaft . Place allen wrench with long end facing out of tool in chuck and tighten chuck securely. With hammer tap allen wrench sharply counter clockwise ( normal thread.)
Jul 08, 2009 | Makita Drills
Bosch 11241EVS SDS-Max Rotary Hammer Logo
190 people viewed this question
Top Bosch Drills Experts
John Trevino
Paul Carew
Are you a Bosch Drill Expert? Answer questions, earn points and help others
