Question about Microwave Ovens
Looking for part number 92100790 for pro 1600pwa model number 220140300123
Screw size
316545301 is the part number of a door handle.
That handle fits more than one model, and the in manual I looked at that had that handle, the dimensions of the screws were not described.
So you would have to look up the screws by part number in the appropriate exploded view for your specific model.
Replace the XXX in the URL below with your full model number from the tag in
or on your unit, or simply click the link and enter your full model number on
the resulting page.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KHMS155LSS3&siteCd=WHRCOM&userType=Consumer
You can order parts from the Pros here.
Apr 25, 2013 | Frigidaire Microwave Ovens
Model: NN-SD277W.     serial number: 6A88040672 A.
There is a dead short in the microwave oven that can be any number of things, yes you will need a pro to fix this and I suggest an estimate first.
Mar 12, 2012 | Panasonic Microwave Ovens
I need an instruction booklet for a ero-pro toaster oven model #K4245
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 25, 2011 | Microwave Ovens
Can I purchase insructions for Breadman Pro?
Hi and welcome to FixYa, I am Kelly.
Which model to you have? There are a several of versions of the Breadman Pro.
There are several manuals here:
http://www.megaheart.com/breadmachine_manuals.html (pop-ups must be enabled)
I am going to guess and present the TR777 as the manual you are probably looking for:
http://www.megaheart.com/pdf/breadman_TR777.pdf
If you have a good model number then choose the manual for your machine using the first link above. Rt click and save to your comuter.
Thanks for choosing FixYa.
Kely
Nov 15, 2010 | Microwave Ovens
I have a frigidaire pro series micro wave built in undercounter serial number 7g61910011, I am moving and want to know how I can uninstall..the store personel who installed took the install manual..and I...
Your model number will be on a tag inside the cooking cavity or around the control panel frame or door frame.
You will need that number.
You can download owner's manuals and installation instructions for Electrolux and Frigidaire here.
Nov 25, 2009 | Frigidaire Microwave Ovens
Bosch range front glass smashed
open the oven door and look on the sides where the door meets the oven. also slide open bottom drawer and look where drawer meets oven. hope this helps!
Aug 29, 2009 | Bosch HMB402 Microwave Oven
Looking for the grill above my microwave model number 721.80823500
Go to searspartsdirect.com. Type in the model number you provided and look under the "Oven Cavity Parts" heading for item number 3024. The part number is 3530W0A034D. I hope this helps you. If this is not the part you are talking about, please let me know.
Jan 17, 2009 | Kenmore 63792 Microwave Oven
Microwave oven provides no heat
I would suspect that your (or any) microwave that is run empty and runs but does not heat probably has a failed magnetron.
With your model number (usually found on as together on the back, inside the cavity or around the door frame) we may be abel to point you to parts and repair sources.
Aug 30, 2008 | Magic Chef CMV1000B Microwave Oven
The glass plate in my microwave broke.The model#mv1515B THE SERIAL#202kmo1221
Searspartsdirect.com has the tray for $36.99. Just type in your model number in the "Search By Model Number" block and look for item number 501 under the "Interior Parts 1" heading. (Part number 1B71961F). I hope this helps you.
May 05, 2008 | Microwave Ovens
Microwave Ovens Logo
69 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
