Question about Novation Xio MIDI controller keyboard
Greetings from the Iceland! My xio is tuned 2 semitones to high.. how do I tune it back down? Please good sir, I am in need of assistance as soon as possible!
  • 604 Answers
Turn it off and unplug from the wall (power supply) this should return the keyboard back to its default tuning
Posted on Mar 20, 2011
  • Bryndis Run Mar 20, 2011
    This didn't work... I don't know what is wrong, do you have another solution for me, I'm trapped in this circle of hell!
  • Keith Brown
    Keith Brown Mar 20, 2011
    have you tried just pushing the down arrow on the pitch control, seems like a very logical thingk to do, but I had to ask. Its quite unusal for the keyboard to retain settings like this, but maybe it got put into memory somehow, is that possible? is the pitch controller maybe stuck in the up position? this is really challenging
My korg N364 is out of tune. how do i fix it?
hello sir,
THIS IS SOFT RESET; FACTORY MUTE PARAMETERS WILL BE LOADED INTO ... ART, MULTIVERB LTX, No factory reset, remove battery for more than 5 hours. .... KORG, N364, HOLD ENTER AND 7, THEN POWER ON. KORG .... ROLAND, D-550, TUNE/FUNCTION AND MIDI DATA INIT: HOLD PATCH BANK 2,
thanks from: SHAAD GONDEKAR
Feb 21, 2017 | Korg Music
My Yamaha PSR S500 keys are playing wrong notes
Is there a pattern to the wrong notes ( eg all up a semitone ? )
If so you could have altered the tuning.
Try a master reset:
Hold down top key whilst turning on. This will reset to factory setup.
See attached for individual reset procedures:
Dec 05, 2015 | Yamaha Music
How do i fix a Yamaha P95 that sounds Es with Fs and Bb with Bs across all the octaves?
Whether it happens to all of the key?
If yes, transpose setting may have changed. Change the setting to normal (0).
If the normal transpose, but tuning is still not standardized, check Pitch Setting.
To Restore Standard Pitch setting:
Hold down the A-1, B-1, C0 and C # 0 keys simultaneously and press any key between C3 and B3.
View image :
fix-yamaha-p95-sounds-es-fs-bb-bs-across-vzw3qjj2ajjzgyoqcmqtppa4-4-0.jpgfix-yamaha-p95-sounds-es-fs-bb-bs-across-vzw3qjj2ajjzgyoqcmqtppa4-4-1.jpg
If the above procedure is still no effect, try resetting the factory settings / Initialize overall: :
This is the steps:
Initializing the Settings
When you initialize the settings, all backup data stored to this instrument will be initialized and reset to the factory default settings.
Turn off the power to the instrument. Then, simultaneously hold down the C7 key (right-most key on the keyboard) and turn the power on again.
NOTICE
Do not turn off the power to this instrument while it is initializing the data in its internal memory (that is, while the button indicators are flashing).
View image:
Notes:
If this instrument somehow becomes disabled or malfunctions, turn off the power to the instrument, then perform the initialization procedure.
Sep 07, 2015 | Yamaha Music
How do I set the tuner to tune at different keys?
Good question, tuners can be simple and some are complicated
a basic automatic guitar tuner you would not have to do anything to the settings, just tune normal on the E string then slowly down tune to D most tuners are a little sensitive, so go slow
and one thing I always do is go lower than the note I'm tuning to then tune up tell it's correct, strings seem to stay in tune better
Hope this helps ?
and if you have time check back on my profile
I will be doing some video tips this weekend
showing tuning, and some basic guitar repairs
thanks for your time
Mar 06, 2015 | Music
Ive got a dean vedetta guitar with floyd rose pickup... every time i tune it, it goes off in a while... also my string levels are very high which makes it difficult to play... i dont have much knowledge...
Some tuners have a weird mode that one presses the button once and the tuner will pass the audio until it times out, then tuner and audio stop. Two presses kills audio while tuner works for a time period and then goes dead. A third press enables audio to pass for normal playing. These are confusing compared to other type built in tuners. If you have one of these read the CONFUSING instructions carefully...
May 07, 2011 | Dean Vendetta XM Electric Guitar
I am trying to replace several of my Suzuki hand chimes that are so out of tune I can't really use them anymore and can't find a supplier who will sell them individually. Can you help? I need 1 G-4, 2...
Suzuki does sell individual replacements, I bought a few last year. If there are a few unusable chimes now, you can try to tune them, nothing to lose, I was able to tune 8 of ours and 2 others were too far gone and had to be replaced. They tune like a tuning fork, which is what they are. If the chime is flat, you either file the tips, in effect making the legs shorter, this must be done evenly or sustain will be affected, or, the inside of the legs near the tips can be filed, again evenly, to reduce mass. If the chime is sharp, filing is done down in the "******" area.
Apr 25, 2011 | Suzuki 25Note Chromatic Tone Chime Set
Hi, i have a acoustic guitar and i am trying to tune it but i do not know how to use the Matrix Chromatic Tuner SR-1050
Hi
Simply turn the tuner on using the power button. Play an open string note close to the tuner (no more than about 1/2 metre away) - for instance the low E on string 6.
The built in microphone will pick up the sound and, if your guitar is reasonably close to being in tune the led light labelled 'E' will illuminate on the lower scale on the tuner along with one of the three other leds to indicate whether the note is flat (b), in tune (green) or sharp (#).
Due to harmonics any or all of these three leds may flash but it is the one that is on the most that matters.
Adjust the tuning peg until the green is on constantly when you play the string.
Move on to the next string
Note - if the string is more than a semitone sharp or flat a different light may flash (e.g if the low E string is 3/4 of a tone flat the D light will come on).
If you wish to tune your guitar to another instrument that is not at perfect pitch (and perhaps cannot be easily adjusted - like a pipe organ) you can use the calibrate button to adjust the setting of the tuner. This temporary recalibration will be lost when the tuner is turned off.
Mar 01, 2011 | Matrix Auto Chromatic Tuner Sr1050
The Yamaha P95 is have a semitone out. Using the transposing function moves it up or down a semitone, however it's still out from concert pitch where it should be?
how come mine is ok, maybe it's depends on where you bought it.
<a href="http://bestdigitalpianoreview.com/yamaha-p-85-review">Yamaha P85 Review</a>
Feb 12, 2011 | Yamaha P95 Digital Piano
With the novation xio 25. How do i alter the decay speed of the synth sound?
Try this link:http://www.novationmusic.com/answerbase/en/ or http://www.novationmusic.com/support/xio/
May 14, 2010 | Music
Novation Xio MIDI controller keyboard Logo
63 people viewed this question
Top Novation Music Experts
Michial Gueffroy
Marvin
Marvin
Are you a Novation Music Expert? Answer questions, earn points and help others
