Sears Calypso Elite Washer, no diagnostics code, although recently an "ob" code appeared while attempting to resolve (thru procedure posted in product manual) the pump will not drain. I have tried the diagnostics test to drain the pump but nothing happens. So should I replace the pump or should I try replacing the lid switch. My tub is pretty full and I will pump out the water manually. Remember I dont have any FL code present. Thanks for any assistance that you can provide
  • Washing Mach... Master
  • 1,902 Answers
Hello & Welcome to FixYa
If the motor controller detects an unrecoverable off-balance condition, the machine controller
will shut down and display an "ob" which means off balance. The lid switch must be opened at least once before restarting the cycle, if this condition occurs. You can try to jump start the lid switch by removing it and then connect its two wires together, if it works then replace the lid switch else replace the pump assembly.
Please get back to me if you have any other questions.
Kevin
Posted on Mar 20, 2011
What is 06 code on a calypso washer
could this be an OB code? if so it is an off balance code meaning the wash load is to unbalanced.open the lid redistribute the load and start it back up. all of the manuals for the calypso do not show any numbers or an 06
Nov 15, 2011 | Kenmore Elite 45986 Front Load Washer
Washer keeps shuting off in the spin cycle and the code ob shows up.
Hi
Thanks for using FixYa. Error ob indicates off balance, if the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an “ob” for off balance. The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow the customer to view and redistribute the load. Press STOP/CANCEL to clear the display. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 23, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
What does error code ob mean on a Whirlpool Calypso washer? The washer stops in mid cycle with the error code ob. I restart it and after a few minutes it shows the same error code again.
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*@^%
May 29, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Code Ld and sometimes Ob water doesn't seem to drain properly
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*@&^$
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Found broken part in my kenmore calypso washer
sorry any problem is a common problem on calypsos, its a techs nightmare. sounds like your better with new machine.
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
OB code plus water leakage
yes its most likely a defective pump...but do some homework,,,calypso was recall a couple of years ago...start a this site servicematter.com
Jan 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso kemore elite washer wont start cycle ( 8 yrs old)
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
May 01, 2008 | Kenmore 23012 Top Load Washer
May 01, 2008 | Kenmore 15864/15862 Top Load Washer
Out of Balance - every cycle!
You probably have something trapped under the large washplate inside the drum. I'm going through the same issue right now with the wife's dis-integrated bathroom rug.
Jun 30, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
