Question about Pioneer DJM-600 Silver Professional DJ Mixer with Auto Beat Cou Home Equalizer
My DJM-400 has died on me... i was working second then i plugged a vacum in the same socket adapter now the DJM wont start up! i check the plug fuse and still no luck! ios there some internal fuse or something!
  • 682 Answers
Yes look inside in power line(after you disconnect power cord)from outlet.for fuse befor power transformer.
Posted on Aug 22, 2008
Unit will not power up
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jan 12, 2013 | Dell Inspiron 6000 Notebook
My diplomat dishwasher will not turn on. I changed the fuse in the plug and it still wont turn on. Theres no lights or anything, it has completely died
Try checking the power supply. It is possible that there is a fault in the socket. 1) Try plugging something else into the socket to check that it is working. or 2) plug your machine into a wander lead that it connected to another socket.
If still no joy, call in a repair man- good luck!
Jun 04, 2012 | Dishwashers
I have a djm 400 and it has started producing a buzzing sound through the speakers. I can take the same speaker cables from the djm 400 and hook them up to my backup mixer and the buzzing goes away. What...
Since it works with your other mixer, the DJM400 is probably fine. You have a ground loop.
Make sure ALL, and I do mean ALL... (re-read that if there is any confusion) interconnected equipment WILL BE powered from the same receptacle or source. If speakers or amps are powered from one place and the DJM is from the other end of the room you likely have a ground loop and you can ex[ect buzzing. Run extension cords alongside the audio leads if necessaryy to carry power from where the amps or speakers are plugged in back to the DJM400 and ANY pther connected equipment.
Jan 07, 2011 | Pioneer DJm 400 Professional DJ Mixer
1989 chevy 2500. started it up in driveway it died wouldnt start. changed ignition module drove it to town died wouldnt start again. got a diognostic tester which read throttle positioning sensor changed...
I WOULD CHECK IGNITION FUSE TO SEE IF POWER GOING TO COILS AND IGNITION MODULE. REPLACE DISTRIBUTOR CAP AND ROTOR.HAVE IGNITION TIMING CHECK.DISTRIBUTOR CAN SLOWLY WORK A LOOSE JUST A LITTLE TO THROW OFF IGNITION TIMING SO PLUGS WONT GET NO SPARK.
Jan 04, 2011 | Chevrolet 2500 Cars & Trucks
My DJM 400 jst wont turn on for some reason. I was jst using it normally and then it just turns off, i dunno y but it jst did and its not workin now. whats wrong with it?
The transformer is shown having a fuse in it or on it. I suspect that the fuse MAY have gone.
With the power switch on, verify there is relatively low resistance between the pins or the power cord, probably less than 200 ohms.
If you find a fuse is blown, suspect a bad electrolyric cap.
May 07, 2010 | Pioneer DJm 400 Professional DJ Mixer
When I plug the radar in the green dot turns on for a second then turns off, nothings on afterwards... I used a new wire and fuse and nothing....what could be wrong?
Does the unit work in another vehicle? If not, first thing to check is the fuse in the power cord. The adapter (part that plugs into the lighter socket) has a replaceable 2 amp 3 AG fuse inside it. The end of the adapter, which has the silver tip, unscrews to gain access to the fuse. CAREFUL: Unscrew slowly! The tip contains a spring which may fly out when disassembling. With use, screw cap on plug may loosen. Retighten occasionally.
Jun 23, 2009 | Car Audio & Video
Playing a ipod on a djm-500
Use a male Twin Phono to 3.5mm stereo jack plug lead. The two phono connectors need to be male, so that they can plug into the red & white line sockets at the back of the DJM 500.
Are available in any audio products store.
Regards
Rob
Jan 24, 2009 | Pioneer DJm500 Professional DJ Mixer...
Pioneer DJM-400 mixer turns on, but channels aren't working
could be a few things , what have you tried to trouble shoot the problem ?
My steps would be ;
check all leads (even if you KNOW u pluged them in)
check the gain is set corectly .
check the line phono slectors are set to what ever you have you leads pluged into on the back of the mixer ( there is 4 red and white RCA plugs , 2 for phono,2 for line CDJs shold be using line )
if you are using digital cables to conect your CDJs , on the back on the mixer there is a small switch marked "CD or digital" make sure that is sleceted "digital " . if ur not using digital cables make sure it is on "CD" .
the info iv put here is based on the DJM-800 so your mixer my not have some of these featers as iv never used a 400 . hope this helps dued . check out www.djtutor.com for more tricks and tips . Pratices'N'enjoy !
Dec 28, 2008 | Pioneer DJm 400 Professional DJ Mixer
Power shortage with new djm-600 US model used in UK
if it is a grounded power cord make sure the voltage is correct some are 115v and others are 220 also some have switch to select voltage plus there is two fuses on that particular model check both and replace with same volt and amperage if it does'nt work reply back to me!
Nov 01, 2007 | Pioneer DJM-600 Silver Professional DJ...
329 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
