Question about Haier Dryers
I have a haier RDE350AW dryer i need a thermal fuse. were can i find one?
SOURCE: Thermal fuse replacement
Thank you for that info.......... after taking everything apart, it became aparent the fuse was on the back of the cabinet exhaust............... oh well, at least I got to clean out the entire machine! Thanks
Posted on Mar 21, 2008
SOURCE: thermal fuse location
where located fuse
Posted on Sep 17, 2008
  • 1122 Answers
SOURCE: location of thermal fuse on leq9858 l dryer whirlpool
if this is a top load?if so remove the back panel and you will see the dryer heater box to your right,the fuse is on the left side of box top,the high temp thermostat is on the bootm left and should be replaced also,before you do thatmif you have a meter remove the 2 wires from the heating element and check it on omns,no meter?remove the 2 screws pull the element off and look to see if the coil is broke anywhere,let me know how you do-mkie
Posted on Apr 20, 2009
  • 2699 Answers
SOURCE: Dryer won't heat. I need to check the thermal
need model number,if filter is on top,pull it out and take out two screws.get staight blade screw driver and put it in seam between the top of dryer and the cabinet and pop up on left and right side,{there are two clips holding the top on,one on the right the other on left side}, unplug door switch wires on right side and you'll see two 5/16 screws one on left and other on right around 4 inches down from the door switch,now grab top of front panel and pull up,there are two clips on bottom of cabinet that panel clips into,you'll see the fuse on the top of blower wheel housing,the fuse could also be located in the back of dryer too that's why you should send model number,hope this helps,while your in the dryer see if it needs to be cleaned out,that's what usually pops the fuse,check the lint filter duct,vac the inside of dryer and blow out the vent line,make sure the flapper is blowing open outside
Posted on Nov 08, 2009
heatman101
  • 43501 Answers
SOURCE: MODEL # RDE350AW HAIER HAS POWER BUT WONT START
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Aug 18, 2011
My Haier Dryer Model RDE350AW only clicks when I press start button, any suggestions?
Since the start relay is clicking it is likely closing the circuit and sending voltage to the dryer motor. You may have a defective thermal limiter fuse blown, it is near the dryer motor so you must remove the back or front of the dryer to access it for testing. Always unplug the dryer before any work is done. You will need a DVOM meter (about $10.00) to check the fuse for continuity.
Dec 28, 2016 | Haier Dryers
I have a Haier Electric dryer RDE350AW and it needs to be reset. Where is the reset button on the unit?
no such thing.....check E/E house panel.....breaker to dryer is tripped.....
Mar 02, 2015 | Haier Dryers
Where is the thermal fuse on haier dryer rde350aw located
Inside the back attached to the exhaust plenum.
Feb 15, 2015 | Haier Dryers
Where is the thermal fuse on haier rde350aw ?
Either on the heating element or right next to the blower fan
Nov 05, 2014 | Dryers
Dryer has no power
plug it in, close the door all the way, check fuse panel, or switch inside the door.
Jun 21, 2012 | Haier RDE350AW Dryer
Dryer won't work
Check the terminal block where the dryer plug connects to the machine to make sure that there aren't any burnt wires, and if not check the rest of the dryer you can gain access to for the same thing, More than likely this is what caused the breaker to trip in the first place.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
MODEL # RDE350AW HAIER HAS POWER BUT WONT START MAKES CLICKING SOUND
heatman101
Aug 17, 2011 | Haier RDE350AW Dryer
Dryers Logo
279 people viewed this question
Top Haier Dryers Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Haier Dryer Expert? Answer questions, earn points and help others
