Windows Vista is not booting it says a problem has been detected and windows has to shy down
    Sergeant:
    Champion:
  • 239 Answers
Restart the computer but tap F8 continuously until you get another menu.
Select the option ' last known good configuration' and hopefully this will recover the machine to a useable state.
If you still have problems then do the same thing and go to 'safe mode with networking' then you can try to identify the problem and take whatever action necessary - suspect recent new hardware and software first. It may also be worth running an antivirus scan - try malwarebytes
http://www.malwarebytes.org/ (the free one is fine!)
Posted on Mar 20, 2011
Windows vista on my laptop did not boot that happend when i was made some windows updates so i try to set up another windows xp from a new bootable cd ,the windows begain to set up but its shut down and a...
I had a similar problem but I can't recall if it was the same error number as in your message---what I did was used the recovery console and re-wrote my master boot record (MBR) my error was in the MBR causing my computer not to boot up in the first place. Your bootable cd should give you an option to use the recovery console before you reinstall, take it and use "fixmbr" at your dos prompt. XP works like that, but I've never had that problem with vista yet....it's worth a try if vista does the same.
Feb 14, 2011 | Computers & Internet
Can't get vista computer to boot up safe mode doesn't work. when computer reboots goes to launch start up repair which leads to "a problem has been detected and windows has been shut down to prevent...
Any Microsoft Vista CD/DVD disk can be used to run the "repair" application,
or to totally re-install Windows, using the license-key on the decal on the side of your desktop computer (or on the bottom of your notebook computer).
Oct 26, 2010 | Computers & Internet
How to install window xp over window vista as defult
not possible, unless you wish to dual boot the WIndows versions ... 'you will need to place the windows XP CD, boot from this CD and format your Hard Disk and then install windows xp.
make sure you have the windows xp licence key as the WIndows vista licence is not valid for windows xp.
last but foremost .. I strongly suggest you download the three key drivers from your manufacturer for 1) Sound Card. 2) Video Card 3) Network Card and have them available after windows is installed. As Windows does not detect all drivers for your computer. Then install either your current preference of Antivirus software or use AVAST (www.avast.com) which is freely available.
check your vendors website to confirm that there is drivers for your make and model laptop or pc.
good luck ... hope this helps...
Oct 08, 2010 | Computers & Internet
After windows sp2 update
0141 error is no hard drive detected. So boot to the BIOS F2 at boot and ensure that the BIOS is seeing the hard disk drive. If it is not, then reseat the drive/drive cable connections and try again. If the drive is detected in bios, then try booting to WIndows, if HDD never is detected, reset bios defaults and reboot, and see if it detects, if still not detected, replace the hard disk drive
Nov 01, 2009 | Dell XPS 420 (dxcwqj1_2) Intel Core2 Duo...
Multiple problems with vista
Since the step are fairly long I have supplied a link to a tutorial,Just Go here for the step by step details http://www.syschat.com/dual-boot-vista-xp-vista-already-1946.html
Please rate this fixya
May 16, 2009 | Microsoft Windows Vista Ultimate Edition
Installing XP on a vista pre-installed laptop
your harddisk is not detected in bios.reconnect your harddisk power cable and sata or ide cable again.then check in bios harddisk is detect or not.
u cna enter in bios with "del" key when u power up ther computer prerss "del" or F2 keyh to enter in bios.
Mar 25, 2009 | Acer Aspire 3680 Laptop
Windows doesnt start
you need to restore your boot system by booting from windows installation disk.
whenyou boot fron CD and ask for repair , select install windows
after you accept the disclaimer by pressing F8, installation will search for current windows installation
after the search select RESTORE
Mar 20, 2009 | HP Pavilion Media Center M9402f PC PC...
I can't install windows xp
If you are going to triple boot your computer you need to install XP first, then Vista this will edit the Master Boot Arecord as needed.
Mar 10, 2009 | Acer Aspire 4315 Notebook
Dual Boot problem in Windows XP & VISTA
Don't try to edit the xp boot.ini or the vista bootloader. It only leads to other problems and headaches.
Try this first: Take note as to which drive has vista on it, put your vista installation cd in the drive and let it boot to the "installation window", then choose "repair", then "startup repair." Make sure you choose the drive that already has vista on it. Let that run and when it re-boots you should then be given a choice to boot to vista or "other windows".
There is also a (free) program called EasyBCD. Download that, read the directions and have at it.
If none of that works, you'll have to do a clean install. Install XP on one drive first, then Vista on the second drive in that order. The Vista bootloader will pick up the XP. However, XP is NOT forward compatible and will not recognize the Vista bootloader. Make sure that you don't have any flashdrives or media cards plugged in before doing the install.
Another approach would be to shrink the Vista volume, creat a new partition, then install Linux Ubuntu that partition. Linux will detect all of the OS's and create a boot menu. Unfortunately, you'll lose about 5 gigs to the Linux OS and it's swap partition, but then, you get to goof around with Linux :-)
Feb 25, 2009 | Microsoft Windows Vista Home Premium with...
2 operating systems
The Boot Configuration Data (BCD) store contains boot configuration parameters and controls how the operating system is started in Microsoft®Windows Vista.
Remove Windows Vista From Dual Boot System Windows Vista works slightly different from earlier versions of Windows when installed on a dual boot system, in that it has a completely different boot loader.
When Windows Vista is first installed as a dual boot operating system a new boot folder is added to the root directory of your PC. This is a hidden file and therefore is not noticed. When you boot your PC a menu appears with the following options:
  • Earlier versions of Windows
  • Windows Vista
Clicking the Windows Vista option will boot the PC into Windows Vista. If, however, you select the earlier versions of Windows option, another menu will appear from which you can choose Windows XP or whatever earlier version - Windows 2000 or Windows 2003 server - you installed first.
Because of this new boot loader it is not as easy to remove Vista from a dual boot system scenario. Simply deleting the Vista partition will, of course, remove Windows Vista, but, unfortunately, it will not remove the Windows Vista boot loader. For this reason, if you simply delete the Windows Vista partition, on rebooting your machine you will not automatically boot into Windows XP (or an earlier version). Instead you will once again be presented with a menu from which you have to choose which operating system you wish to boot to.
Obviously, once you have removed the boot loader and rebooted the Vista operating system will still be on the partition you originally installed it on. To remove Vista completely you will need to Delete the partition that Windows Vista was installed upon.
To remove this menu, or more to the point, the boot loader, proceed as follows:
1/ Boot the PC to Windows Vista
2/ Ensure you are logged onto the Internet and then download the freeware boot loader utility VistaBootPro (www.vistabootpro.org)
3/ Once you have downloaded VistaBootPro, install it on your machine
4/ During Install VistaBootPro will install an icon on your desktop
5/ Locate the VistaBootPro icon and Right Click on it. Then, from the drop down menu, Click on the Run As Administrator option
6/ User Account Control (UAC) will pop up and ask for permission to run the program
7/ After you have given UAC permission - you must be the administrator or have administrator privileges - VistaBootPro will run.
8/ Once VistaBootPro opens, Click on the Bootloader tab
9/ In the Bootloader Maintenance section, Click on the Radio button next to the option marked 'Uninstall the Vista Bootloader (Used to restore Legacy OS) option' and then Click the Apply button
10/ Finally Reboot your PC
11/ On rebooting your machine you will boot directly into Windows XP (or an earlier operating system). No menu will appear.
12/ All that is left to do now is to delete the partition which originally contained Windows Vista. (Assuming you wish to remove the Vista partition from your hard drive).
Sep 12, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
21 people viewed this question
Alun Cox
David Payne
David Payne
