Question about Campbell Hausfeld Welding Tools
SMALL PUDDLES NO PENATRATION WELDER IS FARM HAND 115 VOLT MIG//FLUX CORE WIRE FEED PUT ON ANY SETTING NO DIF CANT FIND MODLE IT HAS CHPOWER.COM WEB ADDRESS
  • 407 Answers
Hi:
If you are using flux core wire you need to switch the polarity of the machine. With flux core wire, your ground clamp becomes positive (lead) and your gun the ground. All you need to do is switch the cables above the feed rolls.
That will take care of the problem
If this was useful to you, please vote. Thanks.
Posted on Mar 21, 2011
Wire wont feed on my welder
I would call miller and get a number for the closest repair station. They have a three year parts and labor warranty. 1-920-735-4505
Jan 10, 2015 | Miller Multimatic 200 MIG TIG & Stick...
Very little power at wire
try to use bare .032 wire and co2 shielded gas, If the equipment does not have a gas solenoid you may have to wire a solenoid to the trigger mechanism to get the gas to flow while the wire is feeding. The bare wire usually copper coated burns much hotter than the flux core when there is a gas shield. Also a .032 bare wire with a gas shield burns a a lower amp range and will get better penetration.
You may have to experiment with the feed rate and gas flow to get the correct setting, but the bare wire has a lot less resistance to current flow than the flux core and will burn a lot hotter when you use a gas shield.
At 115 vac there is not a lot of amperage left to create an arc and run the feeder and the rest of the unit , and the flux core wire takes a lot of amperage to burn both the wire and the flux . .
Apr 03, 2014 | Campbell Hausfeld ® 115V MIG Flux Core...
I need the gun for my 80 fluxcore mig welder
Hi:
Her's the link to the site; all you need to do is to input the model number.
http://www.chpower.com/manualsearch/
Sep 28, 2011 | Campbell Hausfeld MIG / Flux Core Wire...
How do you switch the polarity switch on the 115 farmhand versa-arc mig welder. trying to switch from mig to flux core wire.
Hi:
Disconnect you ground clamp form the negative side pole and switch it to the positive pole, same for the gun disconnect the from the positive side and switch it to the negative pole.
Good luck.
Sep 07, 2011 | Campbell Hausfeld MIG / Flux Core Wire...
Wire won't feed, motor runs and it grips the wire. I can pull it through by hand but it is hard to do .Is something in the line restricting the wire?
I wll check the gun liner and see if it is kinked. Check also your contact tip, must be same diameter as the wire, if you are running flux core wire, oversize your tip, example if wire is 030, then use a 035 tip. Check also drive rolls, for flux core must require knurled drive rolls instead of grooved ones.
Dec 18, 2010 | Campbell Hausfeld 115 volt MIGFlux Core...
My welder does'nt feed a constant feed motor seems to slow down and wire pushes my hand away when hitting metal.
If wire pushes your hand away when welding you need to do one of the following:
Reduce your wire speed, or increase the voltage.
Nov 24, 2010 | Campbell Hausfeld ® 115V MIG Flux Core...
Hobart 140 voltage drop when welding in all setting using 30 wire and uni mix gas will start out welding good then will not ?????
Check your input line voltage. 115 volt Mig welders / plasma cutters need stable voltage / current. Test to see if the voltage drops to below 100 volts when welding. If so, find a more stable power supply.
Mar 05, 2010 | Hobart Welders 500505 Handler 140 MIG &...
Welder work OK with flux wire, cannot get penatration in MIG mode
Are you using combination argon/co2 gas? You need a flow regulator and should have it set for about 10cfm. Note that this is different than a pressure regulator. The problem you note is a result of inadequate or improper gas.
Mar 10, 2009 | Campbell Hausfeld WG2060 Mig/Flux Versa -...
Flux core welders are burning up tips, insulators, and leads
Try to turn up the wire feed and the volts and pull the cup 1/8 inch past the tip
Nov 30, 2008 | Campbell Hausfeld MIG / Flux Core Wire...
Welding Tools Logo
424 people viewed this question
Top Campbell Hausfeld Welding Tools Experts
Joseph Mueller
Joseph Mueller
ray gallant
Are you a Campbell Hausfeld Welding Tool Expert? Answer questions, earn points and help others
