Question about Kenmore 98702 Stacked Washer/Dryer
Lint Is there another place, besides the lint screen in the dryer, where the dryer collects lint, like in the back? If so, how can I clean it out? Thank you.
    Guru:
  • 1,894 Answers
This diagram will help you with the dryer parts
Posted on Aug 03, 2008
How do i clean the lint trap in side the dryer. I can't figure out how to take it apart.
There must be two vents going into the interior of the dryer, one is the intake (where the hot air comes from), the other is the outtake (where the lint trap must be). Locate the two vents and see if one of them has anything removable near it, or if the vent itself has finger holes or something that you can grab and pull or slide it open.
In some front loading models the two vents are at the back and both look like nonremovable vents. If that's the case, one actually pulls right out easily. It might then have two parts (the grate on the dryer side and the screen on the exhaust side) that snap or slide apart, with a space between for collecting lint. If that's the case, and you haven't cleared it in a long time, it will be packed full of lint. The two parts snap or slide apart, then you can get at the lint and remove it. Then snap or slide it back together and just push it back securely in place in the dryer.
Jun 13, 2010 | Maytag Atlantis MDE7657BY Electric Dryer
How do I clean the filter?
Normally you just roll the lint off the screen and use the lint ball to collect any small bits left over. Rarely, you may need to wash the filter with hot water and detergent to clear any residual fabric softener build-up. Be sure to dry thoroughly before putting it back.
Feb 22, 2010 | Dryers
My dryer keeps burning my clothes
I recently solved this problem on my dryer by taking apart the lint collection area. Some dryers allow you to do this by removing a couple screws surrounding the lint screen holder. Others require some dis-assembly of the top and front panel.
Once you have access behind or below the lint screen, use your hands or a strong vacuum (shop-vac) to clean out any collected lint that has fallen below the collection screen and settled in the exhaust duct. I pulled out about 100 cubic inches (~1.6 liters) of collected lint, cat hair, and debris that was obstructing air flow.
Obstructed airflow can cause metal parts near the heating element to overheat and scorch clothing and is a serious fire hazard.
Jan 13, 2010 | Dryers
Our GE gas dryer is burning clothes that are fleece fabric or blankets. Any suggestions?
I recently solved this problem on my ELECTRIC dryer by taking apart the lint collection area. Some dryers allow you to do this by removing a couple screws surrounding the lint screen holder. Others require some dis-assembly of the top and front panel.
Obstructed airflow can cause metal parts near the electric heating element to overheat and scorch clothing and is a serious fire hazard. I expect similar problems can occur with gas dryers.
Dec 28, 2009 | GE DBL333GB Gas Dryer
I have constant lint buildup in the exhaust pipe. Why isn't the lint trap catching it?
No lint trap catches ALL the dryer lint. Some small particles of lint are always exhausted through the dryer exhaust along with warm moist air as your clothes dry. In a perfect world, this lint makes it all the way to the end of the dryer exhaust and exits your home. However, if you have any kinks, excessive bends, sags, or excessively long ducting runs, the can create choke points for lint to accumulate. This creates resistance and makes and condensation forms inside the dryer vent. With condensation, comes areas where lint can accumulate. Once the lint accumulates, it begins to collect moisture. As it collects enough moisture, it will act as a sponge and collect more lint until the dryer becomes completely clogged. Left in a clogged state, the dryer begins to overheat and dries less efficiently. You may notice longer dry times or an excessively hot dryer. Eventually the dryer heating circuits will fail. This can also become a fire hazard if the lint becomes so backed up that it begins to collect on, or near, the heating element.
If you have not checked the dryer ventilation any time recently, now may be a good time to do so. I recommend checking it about once per season to ensure it is not obstructed. Make sure you are also using the semi-rigid metal type ducting. It resists crushing, kinking, resists heat better, and resists rodent infestation.
NOTE: Mice are notorious for building nests inside dryers. Give them a warm place with bedding material and they will make it a home.
Make sure the exhaust vent is at least 12 inches off the ground. This will deter mice and others pests (like snakes or birds) from entering the dryer exhaust from the outside. If you place a cover on the vent, make sure it is of the louvered variety. Do not use screens. They will collect lint and clog easily.
An easy test to determine if you have an exhaust problem is to remove the dryer vent hose from the back of the dryer. Turn the dryer on and allow it to run. The air leaving the back of the dryer should be forceful and warm. If the air flow is weak, you need to check the dryer interior. If the air flow is normal, reattach hose and run the dryer again. This time, check the exhaust vent where it exits your home. Again, the air flow should be forceful and warm. If not, you have a clog somewhere in the ventilation ducting which will require cleaning.
NOTE: If you are using plactic ducting, get rid of it. It collapses easy, rips and mice will chew right through it.
In addtion, many home owners unknowingly will push the dryer against the wall and crush the hose behind it. This will also clog the vent and make the dryer inefficient. Leave about a 1 foot space behind the dryer for proper ventilation and ensure the vent hose does not get crushed. Semi-rigid hose will prevent this from happening.
If you have any questions, please let me know. I have seen this problem many times. Let me know what you find and if I can be of further assistance. I hope this helps you.
Nov 30, 2009 | Dishwashers
Dryer seem to take to long drying
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem.
Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Apr 01, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lint screen is warped and does not collect very much lint
If the dryer is less than a year old the lint screen should be covered by warranty I would replace the lint screen to see if that helps.
Jan 06, 2009 | Kenmore 67082 Electric Dryer
Lint Trap in dryer
Friend,
ngfam1 At your service!
You said, lint is collecting by vent located outdoors. And you feel, the lint trip isn't working.
and you feel very concerned that this is a fire hazard.
We do clean the lint trip off before every dryer run.
The fact that lint is clogging your outside vent does not mean the dryer is not working properly!
The dryers with the top mount lint screens have blow by lint to the outside.
My next dryer will be a Speed Queen dryer which has the lint screen inside the dryer by the door and works better , without the mess on top of the dryer every time I remove it to clean before each load!
That top filter is an old style design!
The outside screen is to keep small animals out!
I find the new plastic outer vents have a plastic mesh screen which caused the same issue as you spoke of and caused my dryer to stop getting hot even though it was only half blocked outside !
I REMOVED the screen and left it off!
And recommend this to all other folks too!
The dryer is too hot for animals to want to enter! They sense it! AND THEY WON'T go in it!!
There are a few types.
1.The old ones are a aluminum vent with a aluminum flap like door that has a spring to keep it closed when the dryer is not on and forcing it open to allow for the exhaust to escape.
2. The newer ones can have a plastic flap that works the same way ,but usually designed without the spring mechanism.
3. the newest one are the ones with the plastic mesh screen that I spoke of above!
Remove the pop off plastic screen and leave it off!
Or if you have the flap door kind.
Change the vent to the open one that comes with the plastic pop on mesh and do not put the screen on!!
It's been years that mine is off and it's all is fine.
You will be fine
Bless You ,
huuum
Please give me the best rating for this solved solution!
Thank You!
Sep 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I want to know how to remove the lint trap (not just the screen but the entire assembly) from a Maytag Performa PYET344AZW front loading electric dryer. The lint screen will not even properly slide back...
Besides drying clothes, dryers also remove lint. This fine, fuzzy material can cause trouble because it blocks dryer lint traps, clogs vents, and fills blowers. Lint can also gather around and in the tracks of the drum rollers, or in and under the pulleys and the drive belt. The result is poor clothes drying or -- sometimes -- no drying. To avoid lint problems, clean out the dryer's lint trap system every time you use the dryer.
To clean the lint screen, remove it from the unit. The screen may be located near or under the door sill, or in the top of the dryer near the control panel. It can usually be removed by pulling it up and out of its housing. Remove the accumulated lint to clear the screen; then replace the screen.
The exhaust vent also collects lint. Vent maintenance involves cleaning the lint from a screen in the dryer's vent exhaust collar and/or at the end of the exhaust vent where it sticks out through a basement window or through an exterior wall. To clean the screen, remove the clamp that holds the vent to the collar, or back out the screws that hold the vent to the collar, or pull the vent straight off an extended collar. Clean the screen thoroughly and replace it in the vent assembly.
To clean the vent itself, use a vent-cleaning brush (available at hardware stores) to pull out any lint deposits. Also check the vent run to make sure that the vent piping or tubing isn't loose at the joints, or -- in the case of flexible plastic venting -- isn't sagging between hanging brackets. Breaks or sags cause undue strain on the dryer's blower system, and can cause drying problems. If the vent pipe or tubing has become clogged with lint, remove the lint by pushing a garden hose or a drain-and-trap auger through the vent to a convenient joint. Disassemble the joint to remove the debris. With this procedure, it isn't necessary to disassemble the entire vent to find the blockage.You can head off problems before they become too serious by providing routine maintenance for your dryer's door gasket, thermostat, timer, and other frequently used parts. Let's discuss how to service these important components in the next section.
how-to-repair-a-dryer-1.jpgTHANK U.. RATE IT...
Sep 11, 2008 | Dryers
Back panel removal
it is..remove bottom panel ..after unplugging from wall..remove lint screen next remove 3 screws holding the lint screen/blower housing in place ..clean out housing clean blower wheel with long brush or a long arm clean lint from base and on element housing on right side especially on top of the housing..that is the most important location if lint gets too thick on element housing ..fire hazard....ckd vent behind dryer and to outside if you find a large amount of lint .that is good indication of a restricted vent
Aug 22, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
124 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
