Question about Garden
Need manual for wagner cs9000 hvlp sprayer - Garden
3 Suggested Answers
  • 2841 Answers
SOURCE: looking for a manual on
You can download a manual here. If you unit is discontinued then click Discontinued Product Manuals. If you have a newer unit just click Power Painter and download the manual in PDF format. http://www.wagnerspraytech.com/portal/wagner_product_manuals_spray,347943,747.html
Posted on Sep 20, 2010
  • 8404 Answers
SOURCE: i have a wagner hvlp
On my Wagoner sprayer, it is possible to turn the nozzle 180 degrees to clear it. Does yours have this feature? I thought my sprayer was faulty (being very cool myself, I didn't read the instructions) maybe due to non use or age as it has sat on the shelf for two years since last use. I bran out and bought another one. After about 10 minutes of use, the new one stopped. I cleaned and cleared and still had no luck. I bought pipe cleaner and little brushes ... you wouldn't believe all the trouble I went to to make sure the nozzle was clear. I was convinced the trouble was with the motor and not the nozzle. Then, I read the instructions ... they said to turn my nozzle 180 degrees and pull the trigger - IT WORKED!)
If yours will not spray, there is a motor trouble or there is a clog somewhere between where the paint is and the nozzle. Believe this and believe that the sprayer was made to work and it was not made to not work and you will discover your trouble.
Thanks for your question ... I hope I have provided some insight for you.
Posted on Jun 20, 2011
Can i thin Valpar Bond Primer no 46620 to apply with a Wagner sprayer?
If you have an airless sprayer yes , you can thin with a small amount of water or use flotrol for latex available at home depot or other box stores. If you have hvlp system no you can't. The hvlp uses a turbine wheel to compress air to around 3-5 psi. You did not say model Wagner sprayer you have. I use my Wagner to 1800-2000 psi. If the job is small you will have to consider the clean u time usually abound 30-45 minutes. Good luck
Jul 30, 2017 | Wagner Air Tools & Compressors
Need instruction manual for a "Wagner 200" sprayer
Owner's Manual - Wagner
www.wagnerspraytech.com/fileadmin/user_upload/wagner.../0525800_eng.pdf
wagner power painter 200 series manual - download - Google Docs
https://docs.google.com/document/d/.../edi
Oct 20, 2016 | Air Tools & Compressors
Why did I have a sudden loss of power?
HI, let me see if I can't help you with this problem-
You are say no power as in it won't turn on and It's new, right?
Lets troubleshoot a few things right now and see if there is a simple problem that may be causing "no power"-
1-turn the power control knob all the way while you pull the trigger
2-don't use an extension cord and try a different wall outlet
3- do you a GFI wall plug (ground fault interrupter) that needs to be reset
4- look at the power cord and check if you have any obvious damage to the cord that might be causing the problem ok
Thanks,
Perry Tradesman @ Tradesman Painting & Decorating Lic.778435
Feb 25, 2015 | Wagner SprayTech Paint Sprayer. Flexio 590...
Does a Wagner Paint Crew sprayer take lubricant?
The Wagner Paint Crew airless sprayer does not require oil for its operation like full professional sprayers. The piston is off-set from the pump chamber with the inlet and outlet valves opposite each other, however you need to protect the parts from corrosion between use and Wagner recommend running some light oil through it after cleaning. If you will be using it in a day or so for water based paint, you could run a 10% solution of their EasyGlide through it.
Sep 30, 2014 | Wagner Spray Tech Wagner Paint Crew 2750...
Spray gun problems
You basically have what is called a "cupgun" and there are a few reasons for this and it should be pretty simple to fix I want to stress that anytime you spray the paint no matter what latex-oil needs to be thinned with the compatible solvent water for latex paint thinner for oil/Alkyd by about 10% - 18% that could be the problem if you have latex in your gun but probably it has to do with the "needle seat" in the back of the gun there should be a knob to adjust the needle turn your gun on pull the trigger and turn knob till paint comes out if that wont work you may have debris in your paint that has clogged the stem pour all the paint out clean gun completely pour paint threw a strainer cone or strainer bag and be sure to thin it...
Sep 01, 2014 | Wagner Paint Sprayer. Flexio 570 HVLP...
Where is the serial number?
The serial number for this is not stamped on any part of the gun it is with the warranty paper work next to the model #
May 12, 2014 | Wagner SprayTech Paint Sprayer. Flexio 590...
My sprayer has power and blows air but no paint comes out
you have old paint that is pluging the pick-up line. you need to clean your sprayer very well each time you use it. I hope this helps you out some.
Aug 14, 2013 | Wagner SprayTech Paint Sprayer. Flexio 590...
Old Wangner Cap Sprayer & Compressor
The Wagner Capspray 9000 HVLP is about 20 years old, but you should be able to find parts, at least for the HVLP gun. The manual for the turbine is #0276989. If you are in the US try Scott at American Airless Wagner Titan Graco Paint Sprayers or in Europe try us at:
Home Lion Industries
Jul 28, 2013 | Wagner Spray Tech Cap Spray Paint Sprayer,...
Garden Logo
318 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
