Question about Sony PlayStation Portable (PSP) Console
Why does The Umd Doesn't Work I put my Umd In my Psp I'm gonna play GTA.. But then it doesn't read at all How should I fix it When I Hear the sound It just stops..All my Umd Doesn't work Can you please tell and If I have to fix something can you tell the Instructions Thank you!!!..
  • 143 Answers
Dont worry you can fix this easily with the help of PSP repair guide ....... you can download it and solve your problem its a big process but if you do correctly according to the guide then you can fix this....... All the best
Click Here to downlaod PSP repair guide.
Posted on Mar 22, 2011
    Sergeant:
  • 194 Answers
MAY I KNOW THE FRIMWARE VERSION OF YOUR PSP
Posted on Mar 20, 2011
How can i fix the problems with my PSP
Sounds like you need to update your firmware and is causing all the games you downloaded (on the old firmware) to not work properly. The alternative is to re-download all the games that seem to be affected. If this doesn't work, make sure you are getting your games from a legitimate source otherwise they wont play correctly regardless.
Nov 19, 2011 | Sony PlayStation Portable (PSP) Console
Error 80010087
Check the firmware of your PSP. Some games may not work if the latest firmware is not installed.
You usually get this message if the UMD has errors reading or the UMD is not present or was ejected in the middle of playing a game. You should try testing your PSP with other disks, if it doesn't have the same problem with other disks then your UMD is most likely scratched or damaged.
If you are using a modded PSP then you will get this error if you load a game from the memory stick without having a disk inserted in the drive. Or if the game that you are trying to load requires a higher firmware version. You will need to install a higher modded firmware to fix the error if that is your case.
Hope this helps.
Jun 29, 2011 | Sony PlayStation Portable (PSP) Console
Psp will hung up when playing Gta vice city stories
Are you playing the GTA Vice City Story from the Memory Stick or from the UMD.
If you are playing the GTA from the memory stick, I assume you have a customized firmware (CFW). Try to upgrade your firmware to higher version.
If you are playing the GTA from the UMD, update your PSP firmware.
Jan 19, 2010 | Sony PlayStation Portable (PSP) Console
My psp2006 ver5.03 cant read games
PSP UMD Repair: Not reading UMD discs
I have seen many PSP's stop reading UMD discs and for the most part they are repairable with the least amount of opening your PSP.
First we will do some trouble shooting with what might be wrong with your PSP unit.
About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
Another 25% is the Disc Spinning motor. This will not let The disc in the UMD spin.
About 20% is the Laser motor, this might be hard to spot since it could be something in the gears.
About 10% is the actual laser itself. It will not focus the laser to read the UMD disc.
The Last 10% is the Motherboard. This is the worst outcome, since there is very little what we can do but replace the motherboard.
So first what we need to do is find out what is actually wrong with your PSP.
With your PSP in hand.
Turn on your PSP and remove any UMD that might be in there now.
If you open up the UMD door and look down inside you will see the Laser assembly.
If you look to the left there is a black tab that sticks up, this tells the PSP that there is a UMD in the drive.
If you press this down with a small probe, you should see the disc motor spin and the laser light up red
*** CAUTION DO NOT STARE DIRECTLY AT THE LASER ***
If the Motor is not spinning. is it moving slightly? Maybe a little twitch?
I would lean more towards the bad motor problem BUT would not say for sure, I would recommend that you take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser, I would try and check the cables to the PSP and see if there is a bad connection.
If both are running well then lets put a disc in and get your ear up close so you can hear what is going on in there.
On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be to much pressure for the disc to spin freely.
Can you hear the Laser focus? This might be hard to hear it will sound like a little tick. If you cant hear it tick I would move on and inspect this internally later.
Can you hear the Laser move down the rail? This will be a smooth sound of the gears, it should not be a really clicky sound.
If you can't hear it move down the track OR it is very clicky follow this.
It would look like this if your UMD door was off.
You should open the UMD door and carefully manually move the laser to the right side of the assembly.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing. It is quite hard to see it in the photos so I put a red star around it.
I usually try and scrape the gears themselves to make sure there is no gunk or debris in the gear.
After this try and see if it is reading UMD again.
This fixes it about 35% of the time.
If none of this is working, it is time to open your PSP unit Or send it in for repair.
If you know what's wrong you can replace the problem here
Replace UMD Assembly
Replace UMD Disc Motor
Replace UMD Laser Motor
Replace PSP Motherboard
All photos and content copyright © Llamma Corp. 2002-2006
http://www.llamma.com/PSP/repair/PSP_UMD_Not_Reading_Discs.htm
Jul 16, 2009 | Sony Video Game Consoles & Games
Why UMD video not work in my psp?
I don't think it is posible to fix this problem. The region code is like the one they put on DVD's to stop piracy. So if i bought the UMD in America I couln't play it on a PSP bought in Asia.Hope this helps.
Jun 21, 2009 | Sony PlayStation Portable (PSP) Console
Umd laser
You will have to contact the SONY COMPANY and tell them that your UMD system doesn`t work. The net dday you will have to mail them your psp and if your guarantee is not expired they fix it for free and they should refund your shipping cost.
Mar 08, 2008 | Sony PlayStation Portable (PSP) Console
PSP won't play any games
the reason the umd wont load is because someone shut the psp off when the game was loading. so whoever did that just messed up your psp. i know cause someone did it to mine now i have to get it fixed or buy a new one. and to get the psp fixed its not guna be cheap.
Dec 25, 2007 | Sony PlayStation Portable (PSP) Console
Playing neopets on psp
Hi Shay877,
Well I would not use that UMD no more.
The UMD could have jarred the Laser and keeping it from moving. Sometimes you can clear this by forcing the laser to move some. You will hear it click a few times. Once you click it a few times one way or another. Try a UMD, Not the UMD that broke it, to see if that fixed
Nov 11, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
81 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
