Question about Microwave Ovens
MMV5207BAW: The only way this microwave will work is to use the "add 30sec. buttom, puching it the number of times you want to keep the microwave cooking! Pushing any selected Pre-programmed item keys will start the microwave and then after just a second or two, it stops and the display indicates an erroe code of E-11. This happens no matter what keypad selection is made. Unfortunately, after purchase and installation, major health issues kept me from calling back the vendor to solve this problem when the product was still under waranty. Any help to resolve/re-program this unit would be appreciated!
  • Dennis Griffin Mar 20, 2011
    IT IS ERROR CODE E-11 not F11. It's been doing this for 5 years since it's been installed. It acts like it's never been programmed! I was fighting cancer for several years and was told I was terninal (wrong diagnosis) and have fully recovered now. I have been trying to play catch up with many honey-doos. This is a big one to get fixed for my wife! Dennis Griffin
    Problem with the Microwave Ovens
    Solution 1posted 4 hours ago
    dcramer531
    Rank: Guru
    Rating: 93.87%, 138 votes
    F 11 code. it is a touch pad error.
    If you just cleaned the control panel it may have water in the panel causing a key to stick.
    If after a day or 2 it hasn't dried out - then you will need to replace the touch pad. I will research this a little more but that is the most common issue and that is what the code is telling me.
    IT'S NIT ERROR CODE F11 BUT E-11.....IT SEEMS THAT NO FUNCTIONS HAVE BEEN ORIGINALLY PROGRAMMED INTO THE MICROWAVE. IT'S BEEN ACTING THE SAME WAY SINCE IT WAS INSTALLED NEARLY 5 YEARS AGO BUT I HAVE BEEN FIGHTING CANCER AND FORGOT ABOUT THE PROBLEM.
    ERROR CODE E-11 IS WHAT IS DISPLAYED AFTER HITTING ANY KEYPAD ENTRY...EXCEPT add 30 sec.
  • 1,998 Answers
Sounds like a defective touchpad or control have you checked the fuses located inside the unit if you check the fuses and all are well the next step would be to replace the touch pad in your unit usually these come attached to the control but on some instances i have seen there sold seperately here is also the manual for your machine as well http://www.managemylife.com/mmh/owner_manuals/6130/MAYTAG-Microwave-Hood-Combo-L0604498?brand_name_search=MMV5207BAW+MAYTAG after checking quickly these are both seperate parts 1 and part 4 in these diagrams you need to be able to distinguish between if the touch pad or the control is causeing the fault Thanks Rick
Posted on Mar 20, 2011
    President:
  • 1,654 Answers
  • 2 more comments
  • Dcramer531
    Dcramer531 Mar 20, 2011
    F 11 code. it is a touch pad error. After researching back forums this code always comes up touch pad, and that makes sense if your having this issue. Would you like me to help with parts or instalation? The touch pad and controller are intigrated as one. You can call the vendor if youlike and see if they will honor your warranty, if not new parst maybe a reduction in costs for repair. Explain your situation and believe it or not, most place will work with you on this.
    While researching this issue, it seems that Maytag has had more issues with this touchpad than I can count, so they are aware of this and should extend your warranty or at least work with you on the repair.
    This is the answer to your issue and if you have questions please feel free to get back with me and I will do what ever it is you need. .
    You can find parts here if you like. http://www.maytag.com/
    I hope I helped a little today.
  • Dcramer531
    I Apologize I keep typing F-11 I MEAN E-11 TOUCH PAD ERROR. F-11 is for washing machines and I get that so many times it is burnt in my head. The solution I posted is correct. Sorry for the mis understanding.
  • Dcramer531
    Thanks!!.
  • Dcramer531
    I spent some time on getting you the info you needed, and giving you helpful solutions and also offering to make sure you get thehelp you need and for what!
How to fix a maytag handle on a maytag microwave
Possibly three parts. Take it apart and look for the broken one.
Mar 05, 2015 | Maytag MMV5207BAW Microwave Oven
How to change the hood light
By hood light I assume that the light you want to replace shines from the bottom of the unit, not the light inside the microwave. If so check out he Disassembly video on this site: Maytag Microwave Light Bulb Not Working
Jan 02, 2015 | Maytag MMV5207BAW Microwave Oven
Everything went out
you blew a circuit breaker...find fuse panel and reset breaker. It will be the one that is tripped
Apr 05, 2014 | Maytag MMV5207BAW Microwave Oven
My Maytag over the range microwave is only 3 years old. No power. Changed the fuse - made sure the outlet worked on other appliances.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 14, 2011 | Maytag MMV5207BAW Microwave Oven
Microwave model MMV5207BAW won't power up when pluged in. Outlet has power but microwave wont power up.
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Mar 14, 2011 | Maytag MMV5207BAW Microwave Oven
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
I have a maytag microwave and the handle is broken, the model number is MMV5207BAW, I have searched for hours on the internet and cannot find a replacement handle, it is the white color microwave. Please...
You need too go too www.maytag.com and look for the microwaves, and look for a link for parts, if not you can call the maytag company and order one by giveing your model number.............
May 03, 2009 | Maytag MMC5000 Microwave Oven
Microwave not heating
heatman101
jkjf
Apr 02, 2009 | Maytag MMV5207BAW Microwave Oven
How do you alter the clock time on these?
There should be a clock set for the time.Some microwave you have to set the time and then push the number 5 buttom to set it. not sure with this one.
Mar 29, 2009 | Sharp R-1480 Microwave Oven
Microwave Ovens Logo
41 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
