Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
DC 17 Animal Issue: I cannot find the brush bar belt tensioner part anywhere!!! I disassembled my dyson, and the plastic tensioner arm that seats in the black motor cover was broken. It is a simple enough fix, but I cannot locate the tensioner arm assembly (tiny plastic part). I called Dyson, and they didn't know what part I was inquiring about. I then worked with a rep as Sears parts direct, and looking at the online diagram for the DC17, the part was not visable. Is the tensioner arm available if you order a new brush bar motor cover? Is there a part number, etc? Please help....
  • 1 more comment
  • bullitt941 Mar 21, 2011
    I have sent a request to the site you recommended, (Espares) regarding the brush bar belt tensioner, and am awaiting a reply. Hopefully they can help. I will update you with status once I hear something.
    Also, i attached two pictures of the arm, and the brush bar motor housing it seats in. The original arm was partially warn away when it came off and became caught in the brush bar itself. You can see the spring and roller appear fine, just the arm is damaged,
    Thank You,
    Dave..
    The arm pops in to the housing here. The spring seats between the arm and the housing on the + to supply tension.
    I went to Dyson, they stated they cannot provide parts directly due to liability issues. They then turned me over to Sears parts direct who handle their parts, and via the diagrams of my vacuum, they did not have a listing for the brush bar belt tension arm. That is why I am trying other alternatives.
    Regforge, I received the following message from Espares:
    Unfortunately we have been unable to source the part(s) you require.
    I wasn't surprised, as on their dyson page, it appeared that the only vacuum not listed was the DC17 model.
    Are there any other possibilities you can think of. I am going to start trying to find Dyson authorized repair shops, etc. I can't believe this is so difficult.
  • 4,963 Answers
Try here
Very informative and helpful company
CLICK HERE
Posted on Mar 20, 2011
    Genius:
  • 1,622 Answers
Hi, you can get any part you want for your vacuum cleaner. just go to the site of the product maker of the vacuum your using and get in contact with customer care.. They will help you out with anything you want..
Take care..
Posted on Mar 21, 2011
  • 1 more comment
  • SANYADE  OMOTOLA
    SANYADE OMOTOLA Mar 21, 2011
    Good luck.
  • MrSimianca Oct 14, 2013
    Utterly useless and stupid comment! The first thought that comes to youre mind is usually not something EVERYONE else didnt think of. In this case it requires FAR more effort to find this part, which you need skill to install!
    Dyson only supplies belts, filters and replacement EXTERNAL parts. This guy needs a belt motor shroud belt tensioner.I've installed them and it is a pain but satisfying.
3 Suggested Answers
SOURCE: Power shuts off on my dyson dc17 animal
My DC 17 Animal would only work when the brush was in the down position & the hose attachment wouldn't work at all. There was no suction. We had to take it in to be serviced & discovered that there is another filter in the system that Dyson doesn't tell you about. The person at the service center said he sees this problem a lot with this model because there is nothing about it in Dyson's consumer documentation.
Posted on Oct 06, 2008
  • 20 Answers
SOURCE: DC17 Animal Bagless Upright Cyclonic Vacuum: dyson animal wont turn off...
dyson has switch problems, needs new switch.
Posted on May 06, 2010
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    DC 17 animal, axle roller that acts as a belt tensioner is shot, including the plastic mount that it sets in, (poor design) that wore down when the roller froze up. Where can I get just this part without...
    I've had this stupid problem and my $500 dollar vacume has been broke for months so today after I spent hours on hold at dyson and talking to sears and everybody else under the sun and they say part doesn't exist pretty much, so finally I talk to a dyson repair man today 6/13 and he tells me that you dont even need that part and when someone gets one in they remove this part even if that's not what there fixing the so called belt tensioner is worthless he said all I need is a NEW BELT! So I bought a new belt locally and twenty minutes later vacuum is working like new, also you can get five belts on eBay for five bucks!
    Sep 25, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
    Dyson blueprint beater bar won't turn
    The Dyson DC 17 has a rug / floor switch on the head of the vacuum. Please check to make sure the switch is in the Rug position. If the brush roller still does not turn then you have broken the belt and need the following part.
    Dyson DC17 Geared Drive Belt, Genuine Dyson Part # 911710-01 - Free Shipping
    Apr 08, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
    How do I replace the belt on the DC 17
    Take out the (3) screws on the bottom of the brush roll cover and then you can remove the roller brush and change the belt. Here is the belt you need:
    Dyson DC17 Belt
    Jan 03, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
    Replace dyson 07 animal brush roll assembley
    The end caps of the brush assembly which contain the bearings are only a push fit onto the spindle (quite tight). Remove these and the brush bar will pass through the drive belt loop. To achieve this the belt has to be stretched slightly so care has to be taken not to over-stretch what might be a belt getting to the end of its life. When refitting the end caps do not forget to aline them properly so they fit into the sole plate recesses correctly.
    I cannot see at the moment how to replace the drive belt on the DC 07 without significant dismantling (that will probably be my next job) I do not see the use of the Dyson tool you offered.
    Oct 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
    Howdo I replace dyson belt??
    Replacing the belt on the DC-17 is not complicated at all. Once I understood how, the process took about 5 minutes. My best suggestion is to call Dyson and they will quickly and cheerfully walk you through it without making you feel stupid. Here is what they told me: 1. Remove the bottom plate that covers the beater bar, using a flat head screwdriver; pull the beater bar out so that it is only attached by the belt. 2. Use the flat head screwdriver to wedge the belt off the beater bar. It takes a little bit of wiggling, but it is not difficult. 3. Once the belt is free of the beater bar, use the screwdriver to unhook it from the gear that is attached to the motor inside. 4. With the new belt, repeat the steps in reverse, hooking the new belt onto the motor gear, over the beater bar, etc.
    Apr 22, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
    The brush bar on my Dyson DC17 stopped turning.
    If this model has a brush control - i.e a roller at the side of the model which controls brush to spin or not, then its a protected brush model - therefore even if the drive belt is intact the Dyson would have to be repaired by a service personnel or professional. The brush protection isn't able to be taken apart and sounds like it may well have slipped off due to tension.
    Mar 31, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
    Dyson Animal dc07 -- change belt
    Read the manual -- available on the Dyson web site. Brushbar not spinning • Ensure brush control is set on carpets mode. Note: brushbar will only spin when the handle is reclined.
    Dec 27, 2008 | Vacuums
    Dyson 17 Brush Belt Broken
    When I had a problem with my DC17, I received a quick response from their service department at 866-693-9766. They recommended a local authorized repair shop.
    Jun 22, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
    Replacements belt for DC 17 absolute animal by dyson
    Call Dyson....they sent us ours for free along with a new beater bar
    May 10, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
    Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
    1,135 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
