Question about Tricity Bendix AW1400W Front Load Washer
Drainage Filter System. Filter gauze disintergrated and filter seals need renewing Down stream from ilter is blocked. What is the layout of the system please?
    Brigadier General:
  • 6,277 Answers
The drain pump itself is normally visible once the filter is removed so I suggest you use a suitable implement/tool and carefully remove whatever detritus remains in the tube. When you have done that the drain motor impeller blades should be visible and you can then check the pump's operation (without the filter) by running a spin and observing ;-0)
Good luck,
John C
Posted on Mar 20, 2011
Can I take the fuel pump and filter out of my 2004 Kia Optima clean it and put it back in without damaging it I know you should buy a new one but trying to be cheap
You can, but it is not an easy chore to drop the tank, clean the top of the tank, and remove the retainer ring to access the fuel pump. Only to put it all back together and have to do it again. I would highly suggest installing a new unit if you go thru the effort to get to it.
Apr 15, 2016 | Kia Cars & Trucks
Stalls slowing down
Air filter plugged - Clean air filter
Tank vent faulty - Clean or replace tank vent if necessary
Leak in fuel line between tank and fuel pump - Seal or renew connections and fuel line
Pump diaphragm damaged or fatigued - Fit new pump diaphragm
Main jet bores or ports blocked - Clean bores and ports
Fuel pickup body dirty - Fit new pickup body
Fuel strainers dirty - Clean fuel strainers
May 01, 2013 | Husqvarna Garden
Ink idling problem in gestetner dx 2330 copy printer
Hi Hope this helps.The metal gauze filter (see image) behind the input nipple on the drum unit may become blocked with congealed ink deposits causing the ink not to feed at full flow.
Strip and clean the blocked gauze filter in the Ink Supply System.
Jun 24, 2012 | Gestetner Office Equipment & Supplies
My bike will not start, no fuel is getting to the caburater, there use to be a sound right after i turn the key on, but that has stoped,all the fueses are ok, my name is john, hope this is simpel.
Your bike uses a fuel pump which was the origin of the noise you used to hear. Now your pump has died and must be replaced.
This is how the pump is mounted, how you remove the tank coder to access it and where to order a new one
http://www.bikebandit.com/1993-bmw-motorcycle-k1100rs-5-speed-transmission-drive-shaft/o/m60sch350445
Jul 13, 2010 | 1993 BMW K 1100 RS
Looks like the oil is leaking out right above the
oil filter screws onto an adapter housing which also has the pressure sending unit on it (above oil filter). This adapter housing bolts to the block with 3 bolts. if oil appears to be leaking from where the adapter housing meets the block (especially at the rear side of engine near bottom), then you need to replace the siamese o-rings between the adapter housing and the block ($12 part at dealer). remove lowest 12mm bolt and loosen top 2 12 mm bolts(top 2 bolts won't come out unless you drop the engine down, but loosening 1 inch is all you need), replace o-rings and retighten bolts. be careful not to get dirt/grit between block and adapter. just finished doing this to son's 95 2.7 v6 which was leaving an 8" puddle of oil after idling for only 1 minute-worked perfect
Feb 24, 2010 | 1995 Honda Accord
My canister machine kicks off immediately after starting and bag full light goes on but it has a new bag
hi from uk your problem with vac may be the gauze filter on the inside of the compartment that has bag this filter there to allow air from the micro pores of the bag to expel to the exterior of vac (room) whilst preventing dust from expelling too ? normally another symptom of this is the vac cover sometimes flips up ? however if air cannot expel from compartment it will cause overheat of motor resulting in auto cut off but will reset when cooled SO check the filter gauze and renew or wash clean? hope you understand above and hope this helps ?
Oct 09, 2009 | Electrolux Guardian Bagged Canister Vacuum
The water line on our refrigerator runs very slowly with a thin stream. The refrigerator is only 3 years old and the filter was recently changed, but did not help the problem.
There is very often another gauze filter in the plastic fitting which connects to your main water supply tap. This is to prevent larger particles from getting into the system but very often clogs up. Check it out.
Mar 03, 2009 | Refrigerators
Electrolux #1521 Canister Vacuum won't stay closed
hi from uk your problem with the canister cover/door coming off whilst vaccing ? you have renewed bag ? ok but there is a filter/gauze also inside the canister where bag is fitted if you check inside you should see the filter at opposite end from where bag is secured it is usually fitted behind a slotted pull out plastic gate ? this filter/gauze is to allow air out of canister when vaccing and the filter traps any dust that may accumulate inside the canister case so the dust does not get blown out to atmosphere/rooms SO if this filter is clogged it will not allow vacced air to escape out of canister so result is build up of pressure within cylinder and eventually cover flips open ! so for now you can remove filter/gauze and wash then dry refit this will allow air to escape from canister but still retain dust particles from escaping as it is designed for however may i suggest you replace filter when convenient ? all above is on assuming that the latch on cover is working ok and not now damaged ? hope this helps best wishes
Mar 01, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux vacuum turning off
hi take off canister cover remove bag now if you look inside canister you will/should see a gauze type filter at the opposite end of canister from where bag locks in ?? remove this gauze filter and for now just shake tap on floor to remve dust/debri etc /from it this gauze is the filter that when vac is working andfilling the dust bag ? the pressure of air only that blows bag up but allows only air to pass thro the microscopic holes in bag ? then has to expel via the gauze filter to exterior ? and any dust etc that is clever enough to seep through the bag ??? will not pass further due to gauze ? and so prevents this blowing back into room ok so far ?? if this gauze is blocked due to whatever ?? then pressure build up in canister will result in cover lifting? this is provided that the fault is not the actual cover securing latch is ok and not damaged ? hope this explains and helps ? best wishes from uk !
Nov 08, 2008 | Electrolux UltraLux 2000 Bagged Canister...
LG LST243C-2
- Check your air filter at the indoor if clean.
- Check your evaporator fins if clean.
- Check if no icing in your evaporator and outdoor pipes.
- If your air filter and evaporator fins is clean and icing is present then your unit is under charge.
- When your indoor drips check your drain pipe if there are water comes out. If no water drain from your drain pipes then your drainage is restricted.
- Flush your drainage with water using your garden hose to flush out dirts from your drainage.
Jan 14, 2008 | LG LSC121PMA Split System Air Conditioner
Tricity Bendix AW1400W Front Load Washer Logo
47 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
