Question about Cycling
Need instuctions on how you shift - Cycling
    Brigadier General:
  • 8,546 Answers
Google bicycle shifting technique, for example:
http://coachlevi.com/cycling/complete-beginner-guide-to-bicycle-gears-shifting/
You should NEVER run cross-chained (big-big or small-small). The drive train performs best when the chainline is as close to straight as possible.
Excess sideways stress on the chain will wear it out prematurely and decrease its normal efficiency.
To demonstrate this for yourself, put the bike in the same combination of gears you
Posted on Mar 20, 2011
2012 rt will not shift into gear
low clutch fluid, follow bleeding instuctions on spyderlovers.com
Aug 07, 2013 | 2010 CanAm Spyder RT Audio
WHERE CAN I DOWNLOAD A COPY OF THE NASCAR 07 INSTUCTION MANUAL?
I couldn't find a downloadable copy but got a hand written one:
NASCAR 07
RACING CONTROLS
Directional Buttons Steering
X Button Share Draft
Triangle Button Reverse
Square Button Intimidator
Circle Button Change View
L2 Button Brake
L1 Button Shift Down
R2 Button Accelerate
R1 Button Shift Up
Start Button Pause
Select Button Toggle Mirror
Left analog stick (L3 Button when pressed down) Steering
Right analog stick (R3 Button when pressed down) Team Communicator
Jul 08, 2011 | Electronic Arts Nascar® 07 for PlayStation...
Assembly instuctions to build racing rig pro builder mega bloks
You can get the instructions from the Mega Bloks wiki, Blok City.
Follow the link below and then go to the bottom of the page and the instructions are there.
http://www.blokcity.com/wiki/index.php?title=9744_Racing_Rig
Apr 19, 2010 | Mega Bloks Probuilder Authentic Definition...
My 2000 Ford Lightning V8 5.4L won't shift out of park!!
The best thing to do is go to any Advance or Auto Zone and buy the Chilton Repair book for this vehicle and it will have step by step instuctions for any repair that you may need. It also has pictures too. They cost around 19.99 but this book is the best for any repairs that you may ever have. Hope this helps.
Dec 06, 2009 | 2000 Ford F150 Flareside SuperCab
1997 Ford Taurus, Won't Shift Past 3rd Gear
Ford is very common for tranny problems. Most likely your tranny will have to be rebuilt. As a mechanic myself, I would suggest taking to tranny specialist to see if i needs to be rebuilt, or if the electrical unit is faulty. It will have to be tested with voltmeter/ohmmeter/multi-tester
Sep 16, 2009 | 1997 Ford Taurus
Liftmaster 1/2hp problem with shredding gear shift really fast
DOES THE DOOR WORK SMOOTHLY AND EASILY MANUALLY??
IF NOT THAT WILL CHEW UP YOUR GEARS.
IF THE DOOR WORKS WELL MANUALLY I AM GUESSING YOU ONLY REPLACED THE EASY GEAR.
YOU NEED TO REPLACE *BOTH* GEARS - FOLLOW THE INSTUCTIONS COMPLETELY. THE SECOND ONE IS HARD TO CHANGE BUT IF YOU DON'T THE ROUGH SURFACE OF THE HARDER WORN GEAR WILL CHEW AT THE NEW GEAR AND ..... WELL YOU HAVE SEEN THE RESULTS.
HOPE THIS HELPS
Mar 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Cycling Logo
100 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
