Question about Quinny Buzz Jogger
How to repair back wheel brakes? the foot break not the handle break? many many thanks...
See http://www.youtube.com/watch?v=J9YK3ewvteI on adjusting the cable.
You can take apart both units and clean the insides as per the other person's comment on you tube - just take note of how it was put together.
I have taken the red brake pedal side of mine apart and the brake is working better now the inside is better but now having trouble attaching it to the frame again (can't get it lined up and screwed on without it slipping).
I'm now looking for instructions on how to get it back on. I have a 2006/2007 model like the one pictured above. Any help would be appreciated
Posted on Apr 06, 2011
Rear drum brake
the emergency brake is controlled by a ratchet action near the handle or foot pedal(hand release under dash) There will be a star wheel for adjustment in the backing plate (slot) or in the hole in the front of the drum
Jun 25, 2013 | 1992 Chevrolet C1500
Where is the brake on a Maclaren daytripper.
In the middle of the wheels see the wheels are 8 right and each side has 2 wheel the break is in the middle of each wheel just press it down so that the breakcan be used..
Jul 02, 2011 | Maclaren Daytripper Stroller
The lever for my back break will not return to its upright position after pressing the break. I think this may be due to the break cable. The pedal has lost its 'springyness' but when pressed the break...
There are four possibilities. From worst to easiest to fix: (don't worry, a link provided below has diagrams of all the parts in exploded view with part names)
1. There are two springs holding the brake shoes firmly against pivot post and brake lever cam, the ends of these can wear through and break. These provide most of the spring tension felt in a cable operated expanding shoe brake. Requires wheel removal and simple removal of brake hub to access.
2. The cam that expands the shoes (when rear lever is actuated) runs through a waterproofing rubber grommet. This grommet can often tear and bind up, reducing the return spring's effectiveness.
3. There is a spring behind the brake's foot pedal frame mount and the plate that pulls the front of the cable end. This maybe either dislodged or the angled ends broken off.
There is a compression spring at rear wheel end of cable, between cable stop and lever arm. This can be removed, stretched and replaced or packed with spacers to provide additional spring.
Check site below: Wheels/tyres/drive - Rear wheel parts #6 (shoe springs) part #7 (brake cam)
Frame/Footrests - part #4 (pedal return spring) part #9 (compression spring)
If this helps let me know below, ...Cheers.
http://www.bikebandit.com/houseofmotorcycles/2004-yamaha-motorcycle-xv250s-virago-250/o/m8460
May 13, 2010 | 2004 Yamaha Xv 250 Virago S
Back break not working wen u push it down
Keep on bleeding until all air bubbles goes out but never-never let your brake fluid reservoir empty, as you bleed the brake, fill the reservoir immediatel to full level. Do you know how to bleed properly? Make sure the engine and key is is off position. Pump the foot brake 6 or 7 times until it becomes hard, keep pedal down, open brake nipple relase fluid as soon it stop spurting, close tight and repeat process until all air bubbles are out from system, fill brake fluid reservoir. As the bike is on centre stand,hand turn the back wheel and press foot brake it should stop it from turning which means it is now working properly. Good enough advise?
May 02, 2010 | 2003 Gas Gas Pampera 280
2000 Grand Prix GT - Parking Brake Stuck - Immediate help needed!
If it is not automatically releasing the park brake wnen car is started and put into gear there may be a more serious problem , There are also break release handles in the area .
Oct 02, 2009 | 2000 Pontiac Grand Prix
My Bugaboo Cameleon break is not working properly. . .
Hi maristel5679. I had the same problem. It's quite easy to fix yourself. There should be a small philips type screw holding the whole assembly onto the frame. Undo this and you will see the inner workings. You just have to realign the ratchet inside. Do this by taking off the whole thing. Be careful when you place it back on the frame as it could slip out of line again because of the tension in the brake line. Undo the tension by slackening the brake screw. replace the hand-brake, tighten the philips screw, then remember to tighten the brake back up. Hope I explained this clearly!! Good luck.
Sep 20, 2009 | Bugaboo Cameleon Jogger
Brake lights don't work when handbrake is not engaged.
I've had a similar problem is so matter what i do the lights would stay on dim. My solution to my problem was that I had a bad/loose ground.
To your problem with the high mount break mount staying on is that you have a loose ground or a tear in the wire.
but since your truck isn't really that old I would first try contacting the Ford dealership asking them if there was a certain recall on this problem of somesort
Aug 12, 2009 | 2004 Ford F150
Wheels in the front of a 1994 ford aerostar shake when coming to a stop from speeds of 40/70 miles a hour, also the steering wheel shakes.
The front break rotors are causing this..
You need to have the break rotors turned - or replaced if they cannot be turned..
Note;
Thank you for posting your question on FixYa.com
We are helping people on a points system.
If the information provided here was at all helpful,
please be kind - rate well and close the post.
Thank you – and enjoy your day ;o)
Aug 07, 2009 | Ford Aerostar Cars & Trucks
Brake assembly
If you loosen the wire that is connected to the gripping machanism first , you will have long enough wire to put it throu the brake grip first then tighten it back at the wheel gripping area.
Dec 01, 2008 | Huffy Disney Princess 16 in. Girls Bicycle
Quinny Buzz Jogger Logo
148 people viewed this question
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Oloyede Monsuru
ray gallant
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
