Question about Maytag Ovens
Maytag range mer575baw electric glasstop range where the clock and window for the oven use says 5ab what does that mean?
IB4G2008
  • 3587 Answers
SOURCE: Clock shows strange code, oven won't operate
that's an error code for something else that's not working..do you have the owners manual?
Posted on Mar 09, 2008
SOURCE: Oven doesn't work after power failure but range does
Sears customer care suggests to hold the clock button for 5 sec. But that does not work. After 2 hours on the phone getting the run around and getting disconnected, the only help they can provide is to call a repair guy in for $70 per hour just to diagnose the problem. They will not provide a spec sheet or a manual to determine if I needed a new circuit board at $305.45. I fixed the problem myself by holding down the Timer OFF button for 5 sec. Maybe they should pay me $70. I will be buying a surge protector for the oven outlet. I hope this helps.
Posted on Aug 25, 2008
  • 63 Answers
SOURCE: I have a Maytag Electric Range/Oven The Range MODEL#MER5755QAW
best guess is thermostat I believe the broiler does not need the thermo in oven.. it stays on steady hot .. thats why it still works
Posted on Mar 13, 2009
EllaWatson25
  • 725 Answers
SOURCE: What does an F3 code mean on a Tappan
This is your oven temperature sensor on your Tappan Oven.
T
hese codes are designed to troubleshoot your appliances and prevent further electronic issues from happening to your unit.
It is a simple repair that you can repair yourself and you can save a ton of money, also!
Once this part has been replaced, you oven should close properly and work just fine.
Posted on Oct 20, 2009
  • 464 Answers
SOURCE: Can I use cast iron on a glasstop electric range?
yes it is true, the heat transfer will be to great and will crack or explode the glass. definately not recommended.
Posted on Nov 08, 2009
Control panel
The error code shown on the display is"Sab", not "5ab".
To disable the Sabbath mode push and hold the Clock pad for 3 seconds.
Jun 18, 2013 | Maytag 30" Built-In Single Electric Wall...
Tip
My oven displays error code 5AB
Hi.
I am publishing this tip because of the many users asking me about the code 5AB on Amana, Maytag and other ovens.
Error 5AB in fact does not exist , and what you see written on display isnot 5AB.
The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
If power is disconnected a new 72 hours cycle will start.
Depending on the model, there may also be a beeping sound when you try to operate the oven.
Push and hold the Clock button for about 10 seconds, until the display clears, that will reset SAB mode.
If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
Regards.
on Mar 05, 2010 | Ovens
The power was out at my home yesterday and my range won't reset. It shows a code 5ab. How do I reset it?
that means it's in sabbath mode,hold the clock button in for 5 seconds to take it out.
May 12, 2011 | Maytag Ovens
Maytag gas oven has an F1 code. Model # CGR3740ADW.
The F1 code on a Maytag electric stove means the electronic range control, clock or touch pad is defective. You or a technician can do a test to determine which item is broken, but you must replace the electronic clock range in models where the touch pad and range control are one part.
Feb 01, 2011 | Maytag 24" Built-In Single Gas Wall Oven -...
Nov 08, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Readout is stuck on 5Ab. Can't do anything with it
Hi.
Regards.
Jul 09, 2009 | Maytag MEW6530D Electric Single Oven
Erroe code 5ab
According to the manual, this mode is SAB and not 5AB. SAB stands for sabath mode and lasts for 72 hours. The mode may be canceled by holding in the clock button for 3 seconds. This mode was activated by holding in the clock button for 3 seconds. My wife did the same thing when resetting the clock for daylight savings time this year. Resetting the power does not reset SAB mode.
Nov 21, 2007 | Amana AOCS3040 Electric Single Oven
Ovens Logo
Top Maytag Ovens Experts
Carmen Mikulic
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
