Running updates it rebooted no video when it came back up
  • David Petry Mar 20, 2011
    What updates dd you run and are you using onboard graphics and/or graphics card?
    Problem Solver:
  • 12 Answers
It sounds like a driver update has affected your video. If you're able to get past the splash screen on boot, press F8 repeatedly until you see "Advanced Boot Options". Select Safe Mode, and when it boots up, right click "Computer" then select "Manage". In the left hand column, click "Device Manager". Find any devices with a yellow exclamation mark and double click them. Click "Driver" and select "Rollback Driver". This should solve your problem.
Posted on Mar 20, 2011
Auto restart
Your machine is rebooting itself while you watch a movie on it? Could be a couple of things. First, is this a laptop or desktop? When is the last time you updated your video drivers? If this is a laptop, does it get very hot just before rebooting?
Theories work like so:
1. older video drivers can be causing a cpu panic condition due to a bug. This is more common with PC games vs. watching movies, but still possible. Updating your video drivers may help fix the problem if that's the cause.
2. heat: if the computer overheats, it will reboot to protect itself. As for why it's getting hot--could be that your video hardware or cpu is getting too hot playing the movie. Could be that your cooling fans are bad. This is why I asked about the machine getting hot.
Another possibility is the need to update either your BIOS or hardware drivers.
Please post more info if you require additional help.
Oct 18, 2013 | Intel Computers & Internet
Tip
Unable to Run Videos
If you are facing trouble in running videos.. which are most of the times coded in Flash Scripts.
This may be the problem with your Web Browser and not having the Flash Plugin.
So please download the Active X and Adobe Flash Plugin
If already having the Active X and Java install, then Uninstall active X and JAVA
Reboot
Try the below update
http://support.microsoft.com/kb/912945
Select XP and download update (For XP Users)
Use this link to download Active X and Flash Plugin
Download Active X
Download Latest Flash plugin
Reboot after update
NOTE: If you need any assistance, in solving Vista or XP problems you can contact me anytime round the clock. Just use the link in this website and Click the ASK ME button, I will assist you through Emails and Online Remote Session.
Best of Luck & Regards
Ellin Scott
on Oct 12, 2008 | YouTube Videos
Westinghouse l2210 montor comes up with color lines on it when i turn on the computer
you should check your video card,and try to upgrade any drivers you have,or go to video card website and check for updates,unplug card from computer,and reinstall reboot and hit F8 button and go into safe mode,go to control panel,hardware manager and look for your video card,clik on plus sign and open it look for update your card or roll back drivers,clik to update and go to file with update and install, then after install, reboot, chek computer video, see if improves if not sounds like video card is done....
Oct 10, 2012 | Westinghouse 22"" L2210NW DVI Widescreen...
What graphics adapter upgrade do I need to make
Hi.
The graphic adapter is the video card installed inside the laptop, and normally does not get replaced, as this is integrated with the motherboard.
After installing Windows 7 you will need to install all drivers.
I would recommend using Vista on this laptop, since factory drivers for Windows 7 had not been released. You will have to install general drivers not designed for this laptop.
If you want to install Windows 7 here you get the instructions.
I quote the part concerning video adapter drivers:
"Update the Video Driver
  1. Preparation
    1. Be sure there are no other video drivers installed (you will want to start out with just the standard VGA driver)
    2. Download the latest 82852/82855 drivers from Intel's website
    3. Extract the drivers somewhere, but do not install anything
  2. Turn Off the Digital Driver Signing Check
    1. Create a shortcut on the desktop to cmd.exe
    2. Right-click on the shortcut and select "Run as administrator"
    3. When the command window opens, execute the following commands:
      1. bcdedit /set nointegritychecks ON
      2. bcdedit /set loadoptions DDISABLE_INTEGRITY_CHECKS
    4. Reboot
  3. Install the Video Driver
    1. Open the Device Manager
    2. On the menu, go to Action > Add Legacy Hardware
    3. Acknowledge the initial dialog screen
    4. Select "Install the hardware that I manually select from a list (Advanced)"
    5. Click Next
    6. Select "Display Adapters" and click Next
    7. Click the "Have Disk..." button
    8. Navigate to the path where you extracted the Intel drivers. The *.inf file will be in the Win2000 folder
    9. IMPORTANT: Do not select the 82852/82855 GM/GME drivers, select the 945GM driver (yes, this is counter-intuitive)
    10. If prompted to reboot, DO NOT REBOOT
    11. If told the 945 device might not work right, acknowlege the error, then run Action > Scan for Hardware Changes
    12. "Intel(R) 82852/82855 GM/GME Graphics Controllers" and a "Mobile Intel(R) 945GM Express Chipset Family" devices should now be listed under "Display Adapers
    13. Disable the 945GM device
    14. Reboot
  4. Verify the Video Driver Installation
    1. Upon rebooting, Windows 7 may roll back one or more of your display devices to Standard VGA
    2. Open Device Manager
    3. Check the Display Adapters
    4. If there is only one 82852/82855 GM/GME device, or if there is a new "unknown" device, precisely repeat the above driver installation section (include the instructions for disabling the 945GM device); in the case of an unknown device, run the "Update Driver" action for that device instead of running the generic "Add Legacy Hardware"
    5. When everything is working, you should have "Graphics Properties" and "Graphics Options" menu items in the pop-up menu when you right-click on the desktop
    6. The "Graphics Option" item should have sub-items for display rotation
    7. Reboot and verify that Windows 7 no longer rolls back your display drivers after rebooting
  5. Protect the Video Driver Installation
    1. Go to Control Panel > System and Security > Windows Update
    2. Windows will likely tell you that an important update is available
    3. Click the "important update is available" link (do NOT click "Install updates")
    4. Right-click on the "Intel Corporation - Display - Mobile Intel(R) 945 Express Chipset Family" update
    5. Click "Hide update" from the context menu
    6. If the display driver gets updated to what is currently on Windows Update, the system will revert back to the Standard VGA driver.
  6. NOTE: When using a driver install hack different from the method described here, I have read reports that a system might Blue Screen when using Windows Media Player to play DVD's; however, alternate media players, such as VLC, reportedly do not exhibit this issue. I do not know if this method will have this same problem, but I thought I would mention this workaround in case someone does experience this issue."
You find driver software at Intel Download Center
Regards.
Oct 26, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
I changed resolution from 640x480 to 1024x768 and all i get now is a blank screen. cannot get back in to change resolution back to 640x480
reboot the computer in "safe mode with networking" by rebooting the machine and during the manufactures name screen, tap the F8 key and you will see the muli-boot menu come up. Safe mode usually loads a resolution the video card and monitor agree on. You may have corrupt video drivers that give the black screen. While in safe mode, go online to windows update and let it scan your system, choose custom installation and look for the optional updates, these will be the hardware drivers you need to update your system. Check them all if you like and let windows install them automatically. Once done reboot normally and see if that clears the problem.
Sep 20, 2009 | Computers & Internet
I updated my Maxtor video driver and now when I
Instead of safe mode, try VGA mode. Then roll back the driver.
FYI - It helps if you post your OS.
Aug 17, 2009 | Matrox G450 Millenium 32MB DDR PCI Dual...
Installed Windows Vista then reboot, can't run repair install.
Maybe you must check your hd for errors. Try program -hardware regenerator-
Mar 29, 2009 | HP Pavilion dv9000z Notebook
T60 after Bios Update to Ver. 2.22 no Video
I do not know if this will work
1)open case
2) check motherboard for word which will say reset bios or words to that effect nearby will be a small 2 or 3 pin connector with the 2 pin remove the jumper from 1 pin and fit over both reboot and turn off straight away refit jumper back over 1 pin and reboot see what happen it may work
with 3 pin setup jumper will already be over 2 pin remove and fit over middle and the other pin remove reboot etc
Usually a failed bios update is more often than not fatal
hope this works for you if it does post favorable rating thanks
Jul 29, 2008 | IBM (10l1433) (  10L1433)...
My comptuer reboots when I isntall the software
If after installing your camcorder in XP, the computer is Rebooting on its own, the you must get a Windows update. This is NOT a Samsung Issue. It is a known Microsoft issue with XP. Run a Windows Update and download the update marked: KB822603, USB 1.1 & 2.0 update. This will fix the issue of rebooting. Reinstallation of device drivers may be necessary.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
