Question about West Bend 41053 Bread & Dough Maker
Bread maker motor still hands
My husband took the bottom off the bread maker again. He could not find either a fuse or resistor or capacitor. Are these things in the motor? If yes, how do you get to the motor? Thanks
    Brigadier General:
  • 3,614 Answers
It has something to do in the motor.. i don't know which is the specific location but always check on the right side.
Posted on Aug 02, 2008
The spindle that holds the paddle won't turn. It's stuck tight.
It may be hard to turn by hand but does it turn when the machine is
turned on? If so it is OK even if you can't turn it by hand
Nov 28, 2012 | Breadman TR555LC Bread Maker
The pan on by breadman gets stuck everytime I make a loaf of bread and my husband has to get it out for me. How do I easily remove the pan?
Keep your husband nearby, lol.
No, but really, the two guides located at each end of your removable bread pan insert need to be raised up a bit. Place both thumbs directly under each guide and push up a bit.
The two baking chamber clips may also need a bit of re-positioning. Reach under each clip, grab the opening at bottom, then genty tug in the direction of the opposing clip.
Did this answer help? Please rate this answer as soon as you can. Thank you.
Jun 08, 2011 | Breadman TR875 Bread Maker
I have this model bread maker. I tried making
Try Ebay. Good Luck...Hank
http://stores.ebay.com/Bread-Machine-Parts-Finder_Regal-Breadmachine-Parts_W0QQ_fsubZ17951273QQ_sidZ649231974QQ_trksidZp4634Q2ec0Q2em322
Jan 29, 2010 | Regal Ware K6725 Kitchen Pro Bread Maker
Mix cycle does not mix add ins evenly or thoroughly. Nuts and seeds are mostly left in bottom of pan or lumped in a few spots in the bread
Check the belt on the motor. It could be lose or has fallen off. Also check the motor to see that it turns in a kneading cycle and check to see if you can spin the paddle freely by hand. Hank
Jan 11, 2010 | Cuisinart CBK-200 Bread Maker
Ineed the Bread Pan for my Regal Kitchen Pro bread
Call the company listed in your manual. They will have the part you need.
Jan 11, 2010 | Regal Ware K6746S Kitchen Pro Bread Maker
Platinum Bread Maker
HI I HAD THE SAME PROBLEM BUT MANAGE THEM TO SENT ME A RECIPE BOOKLETT. IF YOU FOWARD ME YOU EMAIL ADDRESS I CAN FOWARD THIS TO YOU. tashd@polka.co.za
Dec 27, 2009 | Kitchen Appliances - Others
The bread only rises about half way.
After its mixed the ingredients and before it cooks, it should sit for a while to allow the mix to rise. Check that the heater is on in this period, otherwise, if its cold, it wont rise
Feb 14, 2009 | Betty Crocker BCF1690 Bread Maker
Bread machine (41088 model started thunking noise while kneading on occassion...now it will not completely knead the dough. Do I need new bearings? Kneading bars or is there a belt in there to replace? ...
We thought it was the fan belt at first ... however, when my husband took the bread machine apart he found out the it was the motor-mount sleeve ..
In order to fix the problem, you will need to take the machine apart and get to the motor ..
When you get to the motor, you will take the 4 nuts off the bottom of the motor-mounts ..
Then slide the 4 plastic sleeves out of the motor mount rubber garments ...
Grind or file an 1/8 of an inch off of the narrow end of the plastic sleeves ..
Replace the sleeves back into the rubber mount garments ..
Replace the nuts and snug them up being careful not to overtighten them ..
While you are in this far .. it would be a good time to replace the plastic fiber fan belt .. the part number is P25-236 Breadmaker Belt and you can purchase it at http://www.focuselectrics.com
The belts are the same for several of the westbend 2lb machines .. this will fit 41080 thru 41088 ..
Ok, put the housing and everything back together and your done ..
If you mechanical and careful, this should take you about an hour to complete ..'
Warning ... do not attempt to simply tighten the nuts on the bolt mounts .. this will only result in damaging the motor-mount and will not fix the problem .. you have to grind or file the sleeves 1/8 inch shorter .. there is no other way to do it ..
Hope this helps ..
Linda
Sep 02, 2008 | West Bend 41053 Bread & Dough Maker
Bread machine hums and sounds like it's stuck when starting
it was located near the powersupply area, & also check for the continuity on the resistor & capacitor on that area also..
let me know here again
Aug 02, 2008 | West Bend 41053 Bread & Dough Maker
Bread making
I had the same problem with a loaf of whole wheat bread. I also am a new bread machine user and followed directions explicitly. What I figured out was that the pan was not seated all the way into the clips so the paddle mechanism wasn't connected to the motor.
Feb 18, 2008 | Cuisinart CBK-200 Bread Maker
Kitchen Appliances - Others Logo
80 people viewed this question
Top West Bend Kitchen Appliances - Others Experts
Jim Goldsmith
Jim Goldsmith
Irene Tulloch
Oloyede Monsuru
Are you a West Bend Kitchen Appliances - Other Expert? Answer questions, earn points and help others
