Question about Samsung Digimax 4010 Digital Camera
I have a 128MB sd card and it says card is locked?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Mar 20, 2011
Sd card for hp 435
128mb. You probably have to order online.
Aug 22, 2012 | HP Photosmart 435 Digital Camera
Can i use sd card 128mb on my nokia 6600?
Your mobile phone can hold up to 1Gb memory card.
You may use your 128mb mmc to it :)
Nov 25, 2011 | Nokia 6600
Put 8gb sd card in but camera doesn't see it. fills 128mb internal and then says memory full.
The problem might be that the SD card is locked. I'll need your specific model number, if that does not solve your problem....:)
May 28, 2011 | Aiptek A-HD+ Flash Media Camcorder
Downloaded pictures to computer, when the card is in the camera it reads card set-up, card error. 128MB sandisk card for Olympus C3040zoom
Hello :
Look for a tiny switch on the side of the SD card . This switch indicated [ Locked or Unlocked ] . You need to unlock it . If that didn't help , then you need to format the SD card before using it . If that didn't help also , then the problem is with your Camera and not with the SD card . there also must be a sensor in the [ reader on the camera ] which detects the position of the switch. Maybe there is dirt in the sensor. The best way to check would be to try another SD card . but you could try blowing out any possible dirt and see if that fixes the problem.
e61d838.jpg PLEASE DON'T FORGET TO RATE !
GOOD LUCK .
Apr 08, 2010 | Opteka (OP-T32X-C3040KT) for Olympus...
How do i put music on a sd card . I purchased one
well if you don't have a sd card slot on your computer you won't be able to read it. or a mp3 player with a slot for sd if you meant to say that you did put it in and it told you that there is a code it is locked and useless till you get the lock code from the last owner
Jan 15, 2010 | PNY Technologies GeForce 6200 128MB AGP...
I have a pny optima sd card for my vivitar digital camera today when i tried to take a picture it says card protected and i dont know why is happening
SD cards have a small slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 30, 2009 | PNY Technologies GeForce 6200 128MB AGP...
Write proctected
I think you posted this in the wrong category. Your graphics card shouldn't have a write protection option on it as there is nothing to protect.
If the write protection is on a flash card (SD, XD, MC...etc), check to make sure the physical lock on the card is open (it will be small switch). If there is no lock, then it will likely have an encryption program preventing any writing.
If this is a file, right click the file and click properties. If read only is checked, uncheck it.
Oct 15, 2009 | PNY Technologies GeForce 6200 128MB AGP...
MEMORY CARD ERROR
Camera is not recognizing any memory card. The issue is with the camera electronics and not the cards.
Jun 20, 2017 | Sharp Viewcam VL-NZ150U Mini DV Digital...
IPAQ Backup on SD
Sounds like a potential problem with the SD card -- I'd try reformating the SD card and do another backup... If you still have the error, try another card...
Sep 11, 2005 | HP iPAQ HX2415 Pocket PC
128MB sd card not being recognised
Before you can say that there is some common problem it will be interesting to know if your PDA has the same problem with different SD cards (different producer). As far as I know it can happened that PDA has problem with some cheap SD cards that you can buy at every supermarket. If there is possibility to check it with different cards it will be very useful. If this issue occur with different card in this case it is possible that there is some hardware defect and you should contact a Service Partner! Please check this!
Sep 11, 2005 | Toshiba e400 Pocket PC
Samsung Digimax 4010 Digital Camera Logo
56 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
