Question about Panasonic Televison & Video
I have a Panasonic 5 disc dvd/cd player, model CP67. Lately it has problems playing dvds and Its getting worse. I get the code H07 that appears on the display when it acts up. Not sure what this means and if I should just go buy a new dvd player. Thank You.
    Sergeant:
    Champion:
  • 234 Answers
First buy a lens cleaner dvd from wal mart to make sure that the lens is clean and able to pick up.
Posted on Mar 20, 2011
Cannot play certain dvd discs the make is panasonic model num nv vp33
Panasonic NV-VP33 is a DVD/VCR combo unit. These are good, but limited in DVD media playback formats. It depends on the types of DVDs you are trying to play, and their region codes (if they apply).
This model will NOT play:
DVD-ROM / DVD audio / DVD+R (unfinalised) / DVD-RW / Blu-Ray (obviously).
This model WILL play:
DVD-R (finalised) / DVD-RAM (no finalising required) shop-bought DVD movies / CD-R (for JPEG/MP3/DivX) / DVD-R DL (finalised) / DVD+RW (titled or with a top menu to make them compatible with other players, but again, finalising not required).
You didn't specify which DVDs do not play in your unit.
I would be very concerned if your player didn't read ANY DVDs at all. I assume the image below is what the model looks like. I have never had any problems with mine.
Mar 11, 2011 | Televison & Video
Dvd rv32 keeps saying hot and wolnt play dvds
I think you mean the front display shows 'H07' which means the laser/spindle motor assembly (as one part - also known as a traverse unit) has failed. H07 is a common error code with the Panasonic series of DVD playback decks. Because the traverse unit is a multi-operation device, and because the player is a budget model, the repair/replacement of this part to restore your player back to fully functional condition as well as labour costs could prove expensive - hardly worthwhile. It seems Panasonic have been using substandard components within their products for years now, designed to fail just outside their minimum warranty period.
Feb 10, 2011 | Panasonic DVD-RV32 DVD Player
Panasonic DVD player RV62 H07 message - disc
You can try to clean the laser by opening the unit and wiping gently with a cue tip or cotton swab, but if you are getting a H07 errorit may be somethng more serious and require a replacementof the dvd drive.I hope this helps. Good luck.
Sep 03, 2010 | Panasonic DVD-RV62EBS DVD Player
Panasonic dvd players error codes
I tried the WD-40 and it worked........thanks a million !!
Mar 28, 2010 | Panasonic DVD RV22K
Player stops. H07 appears.
This is a problem with the spindle motor,you can locate where the spindle goes into the motor and spray with wd40 leave for a few mins.
Nov 08, 2009 | Panasonic DVD-RV32 DVD Player
H07 on panasonic
hey I just messed around with mine it was showing that code H07 like the others its kinds the same except it holds 4 more disc, I took the top off then I took the thing that holds cd still off!, there should be a brass thing I think thats for the ground, so I ended up putting some synthetic oil on the rails silver poles that the laser slides on, and where the disc sits on that black circle under it, you can see the motor it has a white thing on the motores pole so I just put a few drops on there then spinds it put some more on hoping it works its way DOWN INTO THE MOTOR thats the H07 not spining fast enough!! I put a disk in while everything was apart and its playing right now, the oil I desided to use was the stuff I use for my paintball gun lol! its really thin and slippory and im sure it will last for awhile!.... going to add more after 15 minutes of playing just to make sure its really lubed! hope this helps!!!!
Jan 10, 2008 | Panasonic DVD-CP67 Multi-disc DVD Player
LG DVD player LG276
I picked up a LG DV276 DVD Player here in Australia but I am from the United States so I own region 1 DVDs. I unlocked my new player by instead 1. Open the tray. 2. Press 0 0 0 0 on the remote and a Menu will appear. 3. Press 0 for region free. 4. Press pause and power off.
I can play everything now, Aussie and US DVDs. Thanks LJ66.
Dec 01, 2007 | LG DV276 Recorder
Normal 0 This solution is most likely being submitted way too late tohelp "dingo 1295", but perhaps it will help others who run into thesame problem.
Just this past week, in January of 2009, I ran into the very same problem witha Panasonic DVD-CP67 DVD Player. The player would no longer play disks anddisplayed the H07 error. Now, I can't answer the question about what exactlythe H07 code is suppose to mean, but I can offer one possible solution for theDVD Player's inability to play disks and the subsequent display of the H07error. What happened in my case is that a film of dirt had built up between theelectrical contacts that are suppose to form a closed circuit when the player'sdisc drawer is closed. The two metal plates that make contact rub againsteach other and the abrasion eventually both creates and traps dirt where theplates touch. Therefore the player could no longer tell that the disk drawerwas closed because the dirt blocked the fragile electrical circuit from beingclosed. Since the player could not tell the drawer was closed it would not spinup and play any inserted disks. I'd also like to note that before the playerquite playing disks and started displaying the H07 error I was watching a DVDand did see the picture quality degrade until the video finally cut out and thedisk stopped.
The Solution in this instance was to carefully remove the cover from theplayer, after removing seven screws found on the back and sides of the player's case,and to clean the metal contacts with a non-abrasive eraser. The pink eraser ona NO. 2 pencil works perfectly.
On the back of the disk drawer, on the right side is a silver metal plate andat the back of the player, mounted on the plastic frame work around the platterthat picks up any disk placed in the player, is a folded copper plate held down with ascrew. Simply unscrew the copper plate and clean it with the eraser were itnormally touches the silver plate on the drawer when the drawer is closed,being sure you do not get any eraser dust inside the DVD player. Although thecopper plate will most likely be the plate with the most dirt on it you canalso clean the silver plate without removing it. Once cleaned, you can reattachthe copper plate with its screw.
Testing... You must place the cover back on the player before it will playdisks. The cover must be fully seated, but does not necessarily have to bescrewed on. You may have noticed when cleaning it that the copper plate has anupward folded tab that presses against the player's metal cover when the coveris closed. Without the copper plate touching the player's metal case throughits cover the previously mentioned electrical circuit won't be closed and theplayer won't play disks. With the cover properly back on the player go aheadand try and play a disk. If it works then the problem is solved and you canfinish screwing the cover back on. If the player still doesn't work thensomething more serious may be wrong and I would suggest contacting a servicecenter.
I hope this helps.
Oct 18, 2007 | Panasonic DVD-CP67 Multi-disc DVD Player
Panasonic DVD playerS35 error H 07
HELLO
H07 is the fault code for the disc motor and here is what you need to do to remedy it.
The cover of the player will have to be removed to do this. Locate the the actual motor shaft and where it goes into the motor itself, put a little drop of light oil or WD40. Let it soak in for a little while and try it again. I'm sure you will find it now works.
I had this problem on Panasonic NV-VP31 DVD/VCR unit and I have had no more trouble since!
HOPE THIS HAS HELPED - ENJOY!
Aug 18, 2007 | FEC RKMV5 Custom Rackmount Kit for JVC...
Troubleshooting -- Displays H07 code
While stopped, press and hold REWIND and PAUSE on the unit and then also press and hold OPEN/CLOSE on the unit until Initialized appears from the display. Turn the unit off and on again. If it is still not working, Panasonic Consumer Support recommends having the product checked by an authorized Panasonic service center.
Dec 23, 2005 | Panasonic DVD-CV37 Multi-disc DVD Player
Open Questions:
Televison & Video Logo
100 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
