Question about Acer (90.18612.36B) Computer Speakers
Model 4738Z. no sound in speakers. but sound available wiith headphone
  • 492 Answers
Sound from the headphones means the speakers have an open circuit in the jack. If your are skilled at soldering you might be able to repair them but they don't cost much to replace. I buy speakers at the thrift stores and have found some terrific deals for a few bucks!
Posted on Mar 20, 2011
  • Acer Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
  • jacobtheru Mar 28, 2011
    I recently brought the same laptop and had a similar problem. go to Real tek HD sound effects in the control panel. select the mixer tab. make sure all the volume controls are set the maximum. mine was set way down by default. sound became alright once that was corrected.
    hope this helps..
Does acer aspire 4738z have wi-fi inbuilt ?
yes its certified WiFi, check in system hardware manager to see if the WiFi is installed correctly, if so see the manufacturers manual available online.
Jan 28, 2014 | LotFancy Lotcy Black keyboard for Acer...
Speakers not working headphones
If your regular speakers are working, then your headphone jack is broken and must be replaced. If neither has sound, try reinstalling the sound card driver available from the laptop manufacturer's website.
Oct 16, 2013 | Acer Aspire 4530-5889 Notebook PC
There is a screeching sound coming from acer aspire 4738Z we can hear our own voice when the headphones are put on and when we take the headphones off the sound starts coming again sometimes it stops on...
LOL you hear feedback noise, it's feedback! Go into the sound settings and in the mixer for audio output, mute MIC. (the built-in microphone for webcam conferencing, evidently.) Don't worry that it will keep you from using the mic (pron. 'mike') in the input mixer, because that's a whole other section of the 'board'.
It could of course also be some other app doing the ill-filtered mixing, but see the mixer settings first.
Jun 06, 2011 | Computers & Internet
My view sonic monitor has no sound
Troubleshooting Sound Issues Verify that the audio cable is connected to the AUDIO OUT or LINE OUT output on the Sound Card and plugged into the AUDIO IN or LINE IN of the Monitor.   Make sure there are no cables connected to the Headphone Jack (located next to the AUDIO IN port) on the monitor. If there is, please disconnect that cable and try the speakers again. Connecting a cable to the Headphone Jack disables the speakers. If there is no cable connected into the Headphone Jack, test a pair of headphones into that jack to see if you can hear sound out of the headphones. If you are able to hear sound out of the headphones, disconnect the headphones and try the speakers again.   Verify that the Mute on the monitor is not on or the Volume is not turned down.    Verify that the Mute on the computer is not on or the Volume is not turned down.<    If there is still no audio from the monitor's speakers, connect the Audio cable to another audio source like a portable CD player or tape player headphone output. If audio can be heard through the monitor's speakers, then there may be an issue with the computers sound card.    Connect another set of computer speakers (if available) or headphones to the AUDIO OUT or LINE OUT output on the Sound Card. If NO audio can be heard then there is an issue with the sound card. Verify with the computer's manufacturer for additional assistance.   LCD TVs Troubleshooting No Sound from a LCD TV No Sound when using RGB (when connected to a PC) Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the computer. Note: On the N1700W use the GREEN mini-jack; on this model Audio is SHARED between DVI and RGB, there is only 1 audio channel for data connections. The N1700w is designed to take a 1.0v RMS audio signal for optimal sound quality.   Confirm that both the LCD TV Mute and Windows Mute are off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the monitor or remote to confirm the Volume is not set to zero.   Confirm that PC volume is sufficient by using Windows/Macintosh Volume adjustment settings.   Try plugging another audio source such as a CD or Cassette Player directly into the Audio port on the LCD TV to confirm the speakers work, or try plugging headphones or external speakers into the sound card on the Computer. If the Headphones or External Speakers do not work, contact the manufacturer of your Computer for further support. No Sound when using S-Video/Composite/ Component Video Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the S-Video, Composite, or Component Video device.   Confirm Mute is off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the LCD TV or Remote to confirm the Volume is not set to zero.   Try plugging headphones or external speakers into the audio port on the S-Video, Composite, or Component Video device. If the Headphones or External Speakers do not work, contact the manufacturer of your S-Video, Composite, or Component Video device.   Note: Some ViewSonic monitors do not include speakers.
Nov 23, 2010 | ViewSonic E70f 17" CRT Monitor
My speakers have no sound at all
Check the headphone jack with headphones to see if sound is available at the jack. If not, then check your Device Manager in the computer to see if the sound card with driver is listed.
Oct 31, 2010 | Compaq Audio Players & Recorders
My deaf father has been recommended to use headphones when watching TV. However, when his stereo headphones are plugged into the headphone jack socket, the internal speakers of his Sony KDLS32A12 are muted...
This is not a typical setup for most TVs. There are ways around it though. If your set has a set of audio output jacks, than those can be used to power a separate sound source for the headphones. There are adaptive listening systems available for this purpose what use either infra-red transmitters or RF transmitters to matching headphones. The key here is whether or not the TV has the audio output available.
Please check that and update this with what you find and I'll try to provide a solution within the context of your specific set. Post the TV model number too.
Thanks,
Dan
Nov 12, 2009 | Sony Televison & Video
Sound problem
ok me too, since i install the win 7 in my sony vgn-fz15g, the sound is also coming from speaker too while headphone is connected, and earlier in vista it disable the speaker automatically, i check the sound window, in win7 speaker/headphone is given together, i can not disable one at a time, i think its a driver problem, sony customer care people told me that they have still not tested this model on windows 7 so thats why they are not releasing the driver, if any one have the link for he latest sigmatel high definition driver then let me know that, because this is the complete problem
May 27, 2009 | Sony VAIO Notebook
My computer speakers just went silent in the middle of a song
Do the speakers have power? Check the fuse.
Where are you plugging your headphones?
Where are the speakers connected? Is it the same jack as the headphones?
Have you tried plugging the speakers into the headphone jack vs the soundcard?
Mar 13, 2009 | Harman Kardon HK695 Computer Speakers
Sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Mar 01, 2009 | Dell Latitude D410 Notebook
174 people viewed this question
Top Acer Audio Players & Recorders Experts
NOEL
NOEL
Are you an Acer Audio Player and Recorder Expert? Answer questions, earn points and help others
