The fn key on my Toshiba A205 stopped working.
    Sergeant:
  • 154 Answers
Thats a hardware issue. You should take it to a repair center. Its just a matter of replacing the contact or the bubble of that key. Shouldnt cost much at all.
Cheers
Posted on Mar 20, 2011
My Satellite A100 laptop has no numerric key pad so how can I type special characters?
you should have numbers on the keyboard which you can access using the Fn button... you can also use these without the FN button by htting the NumLock button, then use as normal keypad....
other that that try using the Alt button and the Fn with the corresponding digits.So hold down Alt, FN and tap the corresponding digits/letters on the keyboard.
If you need to use a numpad a lot, then can purchase a USB numpad - often included with USB kits from gadget shops.
Nov 29, 2013 | Toshiba Satellite A205-S4617 Notebook
What's your protoshiba satellite A205-S5880 display function keysblem?
Remove the battery. Keep pressed power button 30 seconds. Reinsert the battery. Try again.
If not let it start like this - black screen. And press ONE TIME FN and F5 until the screen comes back again. OR FN and F9.
Apr 11, 2013 | Toshiba Satellite A205-S5880 Notebook
My fn key will not work on my laptop. it did but then just stopped I have a toshiba , windowns 7
Dear User,
Kindly check in the bios if you have swapped Fn key with Ctrl Key.
Also check if Ctrl key works as Fn key.
If the settings are fine then it could be hardware issue with the Fn key.
Regards,
Tech_Comp
Feb 23, 2011 | Computers & Internet
Connect TOSHIBA SATELLITE A205-S5855 Laptop to TOSHIBA 40H80 TV
You can use the VGA cable which has 15 pins at both ends. For sound, you will need mini stereo phone plug at both ends.
You will have to use the combo key Fn and either F5, 6, or 7 to select the internal, external, both.
Make sure to set the video resolution to the native resolution of this TV otherwise you will get 'Format nor supported' on the screen.
http://s807.photobucket.com/home/budm/allalbums
Jul 02, 2010 | Gateway FPD2275W LCD Monitor
How to connect my toshiba satellite a205 s5804 laptop to my hd tv.vga input on tv.
you should be able to get a VGA Lead that you can plug into your laptop and the other end of the VGA cable into the VGA input on the TV
ON the TV :- Select the PC input ON the LAPTOP :- use the FN + one of the F keys, these vary by manufacture but F4 or F5 - look for a symbol of a Screen - each time you press this F+F? key, this will then toggle the out put to <Laptop><Laptop and TV out ><TV out >
Mar 20, 2010 | Toshiba Satellite A205-S5804 PC Notebook
Sattellite A205-S4577
pls restore ur system like this pls rate me FIXYA for this help
BEFORE TURNING ON THE LAPTOP, press and hold the 0 (zero) button on the keyboard, then turn on the computer while holding the 0 (zero) button down. When the Toshiba logo screen appears, you can release the 0 key.
Mar 06, 2009 | Toshiba Satellite A205-S4617 Notebook
Touchpad not working
First check: Control Panel -> Mouse -> TouchPad On/Off
Second check for a button near the mouse pad, often there are buttons that will enable/disable the touchpad
Thrid use the shortcut key FN+F9(or what ever F key that is used by your laptop) to disable/enable the TouchPad.
Fourth try this software: http://www.kingzm.com/eng/files/download/MouseManager.zip
Fith
- Select Start, Settings, Control panel.
- Open System, click on Hardware, and Device Manager.
- Expand "Mice and other pointing devices", and double click on the entry below, that may be called "HID-Compliant mouse", or "Alps Pointing Device".
- Under "Device usage", choose "Do not use this device in the current hardware profile (disable)", and click OK.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/thomas_b78b4251cd160cd2
Jan 20, 2009 | Toshiba Satellite A205-S4617 Notebook
Curser on laptop frozen
Press the "Fn + F9" keys to enable and disable the touch pad at will.
best regards
Nov 18, 2008 | Toshiba Satellite A205-S4617 Notebook
Computers & Internet Logo
Alun Cox
David Payne
David Payne
